Saying passing altitude
Message
Author
nightbird
#1 Post by nightbird » Wed Mar 30, 2016 6:09 am
Should you say your passing altitude every time you check in with a new controller? I usually just say it checking in with departure and with the next hand offs only the altitude I'm clear to
Ex. "Xy center ABC climbing FL250"
Once in a while they ask me what is my passing altitude but is very rare.
Re: Saying passing altitude
#2 Post by photofly » Wed Mar 30, 2016 6:38 am
I understood you should always report your current altitude (therefore, if climbing or descending, your passing altitude) so the controller can verify for themselves that your mode C reporting is within the required tolerance to rely on it for deconfliction purposes.
“This isn’t flying, it’s falling. With style.”
Changes in Latitudes
#3 Post by Changes in Latitudes » Wed Mar 30, 2016 10:23 am
photofly wrote:I understood you should always report your current altitude (therefore, if climbing or descending, your passing altitude) so the controller can verify for themselves that your mode C reporting is within the required tolerance to rely on it for deconfliction purposes.
Ditto.
A346Dude
#4 Post by A346Dude » Wed Mar 30, 2016 6:29 pm
My understanding is as long as the altitude is verified by one controller, the altitude verification is passed to the next just like radar identification is (which is why you don't have to squawk ident with each handoff). Thus it shouldn't be necessary, but I will defer to an actual IFR controller.
PostmasterGeneral
#5 Post by PostmasterGeneral » Wed Mar 30, 2016 7:26 pm
I usually do if I'm climbing or descending. Just habit I suppose.
nightbird
#6 Post by nightbird » Wed Mar 30, 2016 8:17 pm
A346Dude wrote:My understanding is as long as the altitude is verified by one controller, the altitude verification is passed to the next just like radar identification is (which is why you don't have to squawk ident with each handoff). Thus it shouldn't be necessary, but I will defer to an actual IFR controller.
That's what I thought and the reason I only say it checking in with the first guy until I get "you're radar identified". Hoping to get the input from some of the ATC guys here...
Braun
#7 Post by Braun » Thu Mar 31, 2016 1:59 am
Exactly, the controller who radar identifies an aircraft has the responsibility of validation the altitude of that aircraft and once it is done on radar identification you don't need to do it again. You may hear a controller ask if he thinks something is odd but you don't HAVE to check in with your altitude once you are radar identified.
#8 Post by photofly » Thu Mar 31, 2016 5:08 am
It also gives you a few extra syllables to say so the controller can key in to your voice/accent/intonation. Checking in with just a callsign sounds so 'wrong'.
Braun
#9 Post by Braun » Thu Mar 31, 2016 5:37 am
photofly wrote:It also gives you a few extra syllables to say so the controller can key in to your voice/accent/intonation. Checking in with just a callsign sounds so 'wrong'.
Yes and no. As an arrival controller I'd rather just know you are on my frequency as I don't care what altitude you are at because I can see it on my radar and I know your mode C is verified. If you absolutely want to give me an altitude give me your cleared altitude, at least that way I can catch it if someone made a mistake(either controller or pilot) but even then...I'm sure other controllers have their preferences but technically speaking you don't have to say your current altitude since it is already verified. I stand to be corrected though...
yeah yeah
#10 Post by yeah yeah » Thu Mar 31, 2016 7:17 pm
My unit (DXB approach) requires us to re-validate Mode C on initial contact, since our Area Control Centre feeding us works on a different radar system. We also check aircraft type on initial contact since some operators are famous at last minute equipment changes. PITA!
kevenv
#11 Post by kevenv » Fri Apr 01, 2016 4:44 am
The vast majority of aircraft I see either check-in in level flight with their altitude or they check-in with their passing altitude and their cleared altitude. As has been stated, I can use the fact that the guy next to me (or the one next to him etc) has validated your altitude. I don't mind at all when a pilot gives me the info.
