* AvCanada's Home Page * Photo Gallery * Directory * Topsites *Weather *Enter Chat * Media Kit
It is currently Sun May 19, 2013 4:11 pm
Who is chatting
Who is chatting
Enter Chat
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Floatplanes Filing IFR?
PostPosted: Tue Jul 07, 2009 6:39 pm
Offline
If an operator like Harbour Air/West Coast Air departed Vancouver leaving for Victoria encountered unavoidable IMC along the way could they simply file IFR and if it cleared cancel IFR and land in the harbour?
Could they make this part of their normal operations, that is could they depart IFR and cancel? Would they have to be amphib to do this?
Thanks in Advance.
Top
 Profile
PostPosted: Tue Jul 07, 2009 10:31 pm
Offline
Alternate and fuel considerations aside, the only problem with filing IFR on straight floats out of Vancouver would be departing from within the control zone. You would need an IFR clearance, and I'm not sure how YVR Tower and Centre would coordinate this. You would want to talk to them ahead of time. You would also need to come up with your own departure procedure after assessing obstacles. Best bet would be spec vis and climb visual until you are at a safe route/altitude, again this would have to be coordinated with YVR TWR and Centre. For the arrival you would descend to a minimum IFR altitude and continue visual from there. No need to cancel IFR.
As for the inadvertent IMC encouter, yes a pop up IFR clearance can be issued but this should not be a normal procedure.
Top
 Profile
PostPosted: Thu Jul 09, 2009 12:52 am
Online
How about MRVA's and/or MEA's? Can an amphib really fly that high? (only half tongue in cheek)
Unless this float driver expected vectors all the way to his destination - he/she would be expected to climb up to IFR altitudes for the transit.
Top
 Profile
PostPosted: Thu Jul 09, 2009 2:36 am
Offline
Keeping in mind that it has been almost 10 years since I have done more than a half a dozen flights a year out of Vancouver, it used to be no problem to get radar vectors over the water and never have to be above 3000'. Great way to stay out of the ice in winter.
Top
 Profile
PostPosted: Fri Aug 07, 2009 9:39 am
Offline
Well for a float plane on the Vancouver Harbour -> Victoria Harbour crossing when the weather gets crummy they are more or less always in the process of landing ;) So can go at 200' if required. Way easier than IFR because if they can not break clouds and get visual reference to the ground they are SOL as they can not fly an ILS and land on the hard stuff, not to mention MEAs and Sector Altitudes are a tad high in the area because of all the cumuliousgranet around. Least that is how I would look at it. Mind you I don't fly floats.
Top
 Profile
PostPosted: Mon Aug 17, 2009 2:18 pm
Offline
Hello Shannon.
Having worked Vancouver FSS for 5 years, I can agree with Ahramin: Pop up IFR clearances should not be the usual procedure. You could file a composite IFR/VFR flight plan (letter "Y" in the type of flight box). Just be specific as to when and WHERE you plan to end the IFR and descend for the visual approach. As to transiting CYHC to CYWH at 200 feet in typical winter weather ? I seem to recall a C208 that tried that early one morning, and became "acquainted" with one of the Gulf Islands.....
Andrew Klinzmann
Top
 Profile
Who is online
Users browsing this forum: No registered users and 8 guests
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
webmaster@avcanada.ca
AvCanada Topsites List
While the administrators and moderators of this  forum will attempt to remove or edit any generally objectionable material as  quickly as possible, it is impossible to review every message. If you feel a  topic or post is inappropriate email us at support@avcanada.ca .  By reading these forums you acknowledge that  all posts made to these forums express the views and opinions of the author and  not the administrators, moderators or webmaster (except for posts by these  people) and hence will not be held liable. This website is not responsible or liable in any way for any false or misleading messages or job ads placed at our site.
  When you post a message, your IP is logged and may be provided to concerned parties where unethical or illegal  behavior is apparent. All rights reserved.
