Aircraft Service person
AvCanada's free job forum. Please read the first topic in this forum to learn how to post a position opening.
Moderators: ahramin, sky's the limit, sepia, Sulako, avcanada
Message
Author
Cargojet
#1 Post by Cargojet » Wed Oct 11, 2017 7:38 am
Primary Objective of the Position:
Under the general direction of the YHM Facilities Manager responsible for grooming and maintenance of Cargojet’s Aircraft Hangar and facilities.
Essential Position Functions:
 To maintain Cargojet facilities and aircraft as directed.
 To ensure Flight Deck cleanliness including cleaning flight deck windows and instrument panels.
 To prepare Flight Deck i.e. stocking of garbage bags, anti-bacterial wipes etc. General flight deck cleaning.
 To Empty/Refill the Aircraft Lavatories using the onsite Lavatory Truck
 To organize Lavatory servicing including cleaning the lavatories with anti-bacterial spray, replacing the air freshener and stocking all amenities on aircraft, and facilities as requested.
 To maintain internal cleanliness of the upper and lower cargo holds.
 To wash and wax external aircraft, landing gear etc. (weather permitting)
 Use and maintain all equipment to ensure that it is clean and operable.
 Empty all hangar garbage’s and sweep floor area.
 To safely operate the following equipment: floor washer machine (clean hangar floor), snowplough with attachment (to remove snow from ramp area) and lift machine (to provide access to higher points on the aircraft).
 Keep work areas clean and neat at all times.
 May be asked to assist with some Building Maintenance Tasks
 Perform any other related duties incidental to the work described herein.
Minimum Qualifications:
 Ability to obtain a Restricted Area Identity Card (RAIC) and an Airside Vehicle Operator’s Permit (AVOP).
 MUST have a Valid G Drivers Licence
 Ability to climb up and down ladders while cleaning the aircraft.
 Being handy with tools and light DIY work would be an asset but not essential
 Knowledge of Cargojet’s operation and maintenance of all required equipment is an asset.
 This position involves working in cramped spaces, lifting, and working with cleaning solutions and chemicals
 Ability to work shift, including days, nights, weekends and holidays.
 Excellent communication skills and problem-solving abilities.
 Detail-oriented, able to multi-task and work well under pressure and prioritize workloads in a high-pressure environment
Cargojet is an equal opportunity employer
Send Application (state the position in the subject line and station) to:
Att:Iona Rodricks, Project Manager Cargojet Airways
Email: irodricks@cargojet.com
Return to “Aviation Job Ads (Free)”
