Technician, Non-Destructive Testing- YUL //Technicien(ne), Essais non destructifs- YUL
AvCanada's free job forum. Please read the first topic in this forum to learn how to post a position opening.
Moderators: ahramin, sky's the limit, sepia, Sulako, avcanada
Message
Author
Skyservicemontreal
#1 Post by Skyservicemontreal » Fri Feb 09, 2018 12:21 pm
SKYSERVICE—“AIR TRAVEL. EVOLVED. |OUR PRIORITY. YOUR SAFETY.”
Skyservice Business Aviation Services provides a full range of services from its modern Fixed Base Operation (FBO) facilities in Montreal, Toronto , Calgary and Ottawa. These bases offer full line service and complete aircraft maintenance and support for today’s most popular business aircraft. The personal and friendly service and technical expertise have earned Skyservice industry recognition as Canada’s top FBO. Skyservice has the people, services, and infrastructure to offer corporate and private clients all levels of aircraft management from complete turnkey operations to specific support services for a single airplane or fleet. People and values are the inseparable assets that drive our dedication to Quality, Safety, Respect, Commitment and Efficiency. These are the core values that guide us every day and help build our reputation as leaders in aviation services.
We are looking for individuals who possess a strong drive for results and a passion for understanding and meeting the needs of our customers in a safety focused environment. If you want to challenge your technical expertise then this is the right team for you!
Technicians report to the Supervisor, NDT (or Team Lead, in the absence of the Supervisor) for the certification of inspections to aeronautical products as may be assigned to them and which are within their scope of authority;
SUMMARY OF RESPONSIBILITIES:
Carry out procedures contained in the Maintenance Control Manual;
Review test orders to determine which type of test is requested, test procedures to follow and part acceptability criteria;
Determine test equipment settings according to: type of metal, thickness, distance from test equipment and related variables, using standard formulas;
Calibrate test equipment, such as: magnetic particle, x-ray and ultrasonic contact machines, to standard settings, following manual instructions;
Set up equipment to perform tests and conducts tests on parts, following procedures established for specified tests performed;
Examine surface-treated materials during penetrant and magnetic particle tests to locate and identify cracks or other defects, using black light;
Evaluate test results against designated standards, utilizing knowledge of metals and testing experience;
Prepare reports outlining findings and conclusions;
Within their scope of authority, carries out the duties of the Team Lead, NDT in his absence.
Carries out any other duties as may be assigned by Skyservice’s Manager, NDT, Supervisor, NDT or Team Lead.
QUALIFICATIONS AND SKILLS REQUIRED:
EDUCATION:
Technical training diploma from either a recognized Aircraft or a recognized Non-Destructive Testing training institution.
Apply Here: https://app.jobvite.com/j?cj=oPmV6fwW&s=AVCanada
SKYSERVICE—“L’ART DE VOYAGER. AMÉLIORÉ. | NOTRE PRIORITÉ. VOTRE SÉCURITÉ. ”
Skyservice Business Aviation Services offre une gamme complète de services à partir de ses terminaux corporatifs à Montréal, Toronto et Calgary. Ces bases offrent un service clé en main complet et la maintenance complète des aéronefs et supporte les appareils d'affaires les plus populaires d'aujourd'hui. Le service personnalisé et amical et l'expertise technique ont apporté à Skyservice la reconnaissance de l'industrie en tant que meilleur terminal corporatif au Canada. Skyservice possède les personnes, les services et l'infrastructure pour offrir à ses clients, corporatifs et privés, tous les niveaux de services reliés la gestion d’aéronefs : d’un service clé en main à des services de soutiens spécifiques pour un seul avion ou une flotte. Les gens et les valeurs sont des atouts inséparables qui animent notre engagement à la qualité, la sécurité, le respect, l'engagement et l'efficacité. Ce sont ces valeurs fondamentales qui nous guident quotidiennement et nous aident à construire notre réputation en tant que chefs de file dans les services de l'aviation.
Nous recherchons des personnes orientées vers l'obtention de résultats et une passion pour la compréhension et la satisfaction des besoins de nos clients dans un environnement sécuritaire. Si vous désirez mettre votre expertise au défi, alors nous sommes la bonne équipe pour vous!
SOMMAIRES DES RESPONSABILITÉS:
Réaliser les procédures contenues dans le manuel de contrôle de maintenance;
Réviser les commandes pour déterminer le type de test requis, les procédures à suivre et les critères d'acceptabilité d’une pièce;
Déterminer les paramètres de l'équipement du test selon le type de métal, l'épaisseur, la distance de l'équipement et les variables connexes, en utilisant des formules standards;
Calibrer l'équipement des tests, tels que : particule magnétique, rayons X et les machines à contact ultrasons, d’après les réglages standards, en suivant les instructions du manuel;
Installer l'équipement afin d’effectuer les tests et effectuer les tests sur les pièces en suivant les procédures établies dépendamment des tests effectués;
Examiner les surfaces traités des matériaux, lors des tests de pénétrant et de particule magnétique pour localiser et repérer les fissures ou autres défauts, à l'aide de lumière fluorescente;
Évaluer les résultats des tests par rapport aux normes désignées, en utilisant ses connaissances des métaux et son expérience du/des test(s);
Préparer des rapports décrivant les résultats et les conclusions;
Dans leur champ de compétence, exercer les fonctions du Chef d'équipe, END en son absence;
Effectuer toutes autres tâches pouvant être assignées par le Chef de service, END, Superviseur, END ou Chef d'équipe, END.
QUALIFICATIONS ET COMPÉTENCES REQUISES:
Acquérir, au minimum, les formations de l’ONGC ou NAS 410 et obtenu avec succès les certifications Niveau II dans 3 des 5 méthodes de END.
Posséder une formation en assurance de la qualité, un atout;
Posséder de bonnes capacités analytique et avoir le souci du détail;
Être capable d'utiliser un large éventail d'outils et d'instruments;
Être capable de communiquer clairement par écrit et verbalement;
Avoir une bonne vision ainsi qu’une bonne perception des couleurs;
Comprendre les questions de santé et de sécurité;
Posséder un permis de conduire valide.
SCOLARITÉ:
Posséder un diplôme d’études technique d’une institution reconnue en aéronautique ou en essai non destructif.
Appliquer ici : https://app.jobvite.com/j?cj=oPmV6fwW&s=AVCanada
Return to “Aviation Job Ads (Free)”
