Government of Saskatchewan - Ministry of Environment - Aircraft Maintenance Engineer II - TRA000958
AvCanada's free job forum. Please read the first topic in this forum to learn how to post a position opening.
Moderators: ahramin, sky's the limit, sepia, Sulako, avcanada
GovSask
Post by GovSask » Tue Sep 10, 2019 9:11 am
Position: Aircraft Maintenance Engineer II - TRA000958
Company Name: Government of Saskatchewan - Ministry of Environment
City: La Ronge
Province/Territory or State: Saskatchewan
Country: Canada
Web Address: https://govskpsc.taleo.net/careersectio ... =TRA000958
Job Description:
The Ministry of Environment takes a team-based approach to protecting Saskatchewan’s environment for the well-being of the province, its people, and its future. We use science-based solutions and environmental laws to help safeguard communities and to protect our air, land, water, and habitat. We are committed to high citizen and client satisfaction through workplace excellence, continuous improvement, and innovation.
Saskatchewan Environment requires an Aircraft Maintenance Engineer Crew Chief for Aviation Operations in La Ronge. Under the direction of the Director of Maintenance, you will supervise a crew of Aircraft Maintenance Engineers performing periodic inspection on airframes, engines and systems in fleet of 17 firefighting aircrafts including CL215's, CL215T's, CV 580A's, Baron 55's and Twin Commanders assessing deficiencies in airframe, engine, electrical, hydraulic and instrumentation systems and repairing or replacing deficient components in accordance with Transport Canada approval standards.
As Crew Chief you may be assigned to any aircraft type, but at this time we require a Crew Chief to oversee the CV580 program. To qualify for this position you will possess an Aircraft Maintenance Engineer M1 and M2 License with Aircraft Certifying Authority for the CV580 and Twin Commander ideally on all Aviation Operations aircraft types. A valid Saskatchewan drivers license is also required.
Salary: $32.412 to $39.437 per hour
Closing Date: September 24, 2019
Return to “Aviation Job Ads (Free)”
