AVCANADA
It is currently Wed Oct 18, 2017 6:57 pm
Post new topic  Reply to topic  [ 3 posts ]
Author Message
PostPosted: Wed Mar 18, 2009 3:33 pm
Offline
Quote:
U.S., Canada order grounding of Bell civilian helicopters
by bob cox, Fort Worth Star-Telegram; Fort Worth, TX
FORT WORTH, Texas _ U.S. and Canadian aviation safety regulators have ordered the immediate grounding and inspection of the most popular Bell Helicopter civil aircraft models to inspect for and repair an improperly installed control mechanism.
The action by the safety agencies comes on the heels of a service bulletin issued by Bell on March 10 alerting operators of the aircraft models to the potential problem.
Federal Aviation Administration officials, following the lead of Transport Canada, issued an emergency airworthiness directive Tuesday mandating that operators immediately inspect the Bell 206, 206B and 206L models, as well as 407 and 427 models before further flight.
The 206 and 407 models are Bell's most popular selling civil helicopters and are widely used for air medical, police, fire and television news gathering operations. The FAA said 2,715 are registered in the U.S. and more than 6,500 worldwide.
The order requires immediate inspection of a critical bearing that may have been installed backward, which could lead to failure of the aircraft's cyclic control that regulates the directional movement of the helicopter.
Aircraft operators must inspect and, if necessary, replace the bearing before the aircraft are flown again.
http://dailyme.com/story/2009031800003022/
Here's a link to the TCCA AD: http://www.caa.co.uk/docs/33/20090312TCADCF200910.pdf
_________________
"The world is not dangerous because of those who do harm but because of those who look at it without doing anything." - Albert Einstein
Top
PostPosted: Wed Mar 18, 2009 9:04 pm
Offline
I think the DailyMe is making mountains out of molehills with a headline like that.
The ASB only applies to aircraft with less than 50 hours in service or with a cyclic control lever assy installed within the last 50 hours.
It's not like the entire fleet is grounded for weeks, Bell is calling the fix 2-4 man-hours to ascertain/rectify.
The 206 ASB (the other models read nearly the same):
http://www.bellcustomer.com/files/Storage/ASB_206-09-121.pdf
Top
PostPosted: Mon Apr 06, 2009 9:44 am
Offline
Quote:
Posted on Fri, Apr. 03, 2009
Bell Helicopter urges inspections on thousands in fleet
By BOB COXrcox@star-telegram.com
Bell Helicopter has warned customers and government safety officials that urgent inspections need to be made on potentially thousands of helicopters to check for an improperly installed bearing in a critical flight control component.
It's the second time in less than a month that Bell has issued an alert to check for a potentially hazardous problem that covers much of the Bell manufactured fleet.
Bell spokesman Greg Hubbard said the company issued two types of service alerts affecting the Bell 206, 407, 427, 222, 230 and 430 model helicopters, which would comprise much of the active Bell fleet.
The 206 and 407 are widely used in the U.S. and around the world for many purposes including law enforcement agencies, air medical services and private transport.
The service bulletins were issued after a helicopter owner discovered the problem and notified the company and the Federal Aviation Administration.
Hubbard said Bell was communicating the alerts directly to helicopter owners and operators and to officials of Transport Canada and the FAA. The government agencies will likely soon follow-up by issuing airworthiness directives mandating the inspections.
The service alerts advise helicopter owners to immediately inspect the aircraft for an improperly installed bearing in the swash plate mechanism that controls the rotor. The inspections, depending upon the part involved, are to be completed within the next five or 10 hours of operation of the helicopter.
On March 10, Bell issued a similar service alert after discovery of an improperly installed bearing in the cyclic controls of a new helicopter assembled at the company's plant in Montreal. Transport Canada and the FAA followed that up with directives ordering that all similar aircraft be inspected before their next flight.
After completing hundreds of inspections, Hubbard said no additional problems were found with that particular part. The alerts all involve "staked bearings," which refers to an approved procedure for properly assembling parts containing the bearings.
In addition to advising immediate inspections of the swash plate bearing, Bell also issued a safety notice for all bearings of the same type installed in any part of any Bell helicopter. The notice requires operators to inspect these bearings during their next regular required phased inspection.
Hubbard said appropriate alerts have also been sent to the military services covering any affected military aircraft.
"Bell’s rapid and thorough response to this situation clearly demonstrates that our safety and inspection processes are robust and effective," Hubbard said.
BOB COX, 817-390-7723
http://www.star-telegram.com/topstories/story/1297906.html
_________________
Top
Who is online
Users browsing this forum: Exabot [Bot] and 10 guests
Search for:
Jump to:
[ GZIP: Off ]
avcanada@gmail.com
AvCanada Topsites List
