Question for Q drivers
Re: Question for Q drivers
How come the Q400's always have the GPU plugged in for starts? I thought there was an APU.
In part, fuel savings. At Jazz, the APU is only to be used when necessary i.e they would rather the aircraft be connected to a sub standard power cart that seldom puts out what Bombardier recommends and ground air that does just about SWFA on short turns. I also understand that there is a design flaw as well such that if the aircraft were always being started with the APU there would likely be a higher rate of servicing required.
Sorry to re-open this topic, but I have some questions for Q4 drivers as well.
Is it normal to take off with reduced torque whenever possible? Is 81% common?
What rpm/power setting is used in the climb?
Is MTOP ever used?
Are reduced NP landings common?
Thanks!
Is MTOP ever used?
Thanks!
Yes, unless first flight of day or other operational considerations
Is 81% common?
83% is the minimum RTOP we use
RPM for climb is 900, torque is whatever FADEC calculates is required for maximum climb power, or MCL as it's designated
Is MTOP ever used?
It's rare, but occasionally it is
Very common. The majority of landings are done with reduced Np. There are some operational restrictions and even airmanship might come into play (as much as it seems to be a dying art...) that could preclude an 850 landing
Is 81% common?
Is MTOP ever used?
Saw a Jazz Q400 taxi in in Toronto today with the left engine shutdown
Another "money-saving protocol" from the company.
I can't figure out how they went from "two-engine" taxi right into "one-engine-shutdown" taxi where before they wouldn't even do "one-prop-feathered" taxi like we do on the Classic.
Most likely an issue with that engine, no? I've never even seen them taxi with an engine feathered on the Q400, let alone shut down.
I know there is/was a feasibility test wrt single engine taxi (ie fuel savings.....) on the Q, not sure if its SOP yet or still ongoing.
Porter has been driving around with one engine shutdown for almost a year now I think. At least the times I saw them in YYZ due to IRROPS at YTZ.
SET-in (single engine taxi in) is now an approved procedure at Jazz on the Q.
SET-out is a possibility down the road, but it would require significant changes to current procedures.
Interesting. I haven't seen this YVR yet. I stand corrected!
It was official as of November 1. You will see it phase in slowly as people get comfortable with it I imagine. It's quieter, less vibration and saves gas. On the flip side I'm not sure what it will do to the brake use as it doesn't like to stop/slow with discing as well as with two running.
What are the procedures for landing with anti-ice on? Does the INCR REF switch have to be selected? Can it be switched off during the approach once clear of icing?
If you are in icing conditions and there is no visible ice on the wings you may select Increase Ref to OFF. This scenario would likely present itself when on approach, in cloud SAT 5 or below but above 0. The procedure is really only of significant value when operating onto a shorter runway. Though it may be anecdotal, the proedure was requested by Porter given the length of runway at YTZ and impact of operational performance with the added speed. As far as I know, it is only approved in Canada.JazzYVR wrote:What are the procedures for landing with anti-ice on? Does the INCR REF switch have to be selected? Can it be switched off during the approach once clear of icing?
Don't forget you also need to be 'stable' which everyone coveniently forgets. So if you are VMC and we have to be stable by 500' then you can't go REF switch off below 500' otherwise you would have a 15/20Kt speed change which means you are no longer stable.
If possible...Its better to stop then land...than land then stop!
