high flyer
Share ideas on building aircraft.
redlaser
high flyer
Post by redlaser » Thu Mar 12, 2015 9:21 am
Over the Atlantic Ocean
Don't let your wife talk you out of buying an airplane, :D
trampbike
Re: Damaged Grumman Cheetha AA5A
Post by trampbike » Thu Mar 12, 2015 9:30 am
Where is it?
Think ahead or fall behind!
AirFrame
Post by AirFrame » Thu Mar 12, 2015 11:08 pm
Only one problem... Transport is now taking a dim view of amateur-built aircraft using major portions from previously certified aircraft. You'd have better luck getting it re-certified with a sympathetic mechanic who is willing to check in on you while you restore it, and sign off the work when it's done.
goingnowherefast
Post by goingnowherefast » Fri Mar 13, 2015 7:33 pm
Engine and what's left of the panel are all that could be realistically used. Could be a steal of a deal looking at what Lycomings go for now a days.
redlaser
look up,way way up
Post by redlaser » Tue Mar 24, 2015 1:17 pm
Can you see me now!
redlaser
Rocket engine
Post by redlaser » Sun May 03, 2015 4:10 am
Up and away, :D
redlaser
delete
Post by redlaser » Sun May 03, 2015 4:27 am
trampbike wrote:Where is it?
It's now in level flight at 35000 feet, over the Atlantic ocean,
Taiser
Post by Taiser » Sun May 03, 2015 5:42 am
Engine is run every two weeks to keep it in top shape
NOOOOOOOOO....!!!! :shock: That's bad for an engine! Fog it, and do a proper storage. Video it for any possible viewings of how well it's running. Running it up on the ground just builds up moisture in it, especially on the lycosaurs which are really susceptible to moisture problems (camshaft). Beautiful candidate for an amateur built conversion, then you can tell TC to :smt014 off!!!
Wish I knew about this last fall, would be an excellent project! :(
redlaser
look up way way up
Post by redlaser » Thu May 21, 2015 7:39 pm
60, thousand feet and still climbing, space station now in view.
AirFrame
Post by AirFrame » Fri May 22, 2015 6:40 am
redlaser wrote:On the contrary Transport Canada would welcome aircraft parts taken from a certified aircraft and used in a homebuilt
That hasn't been true for at least 10 years. You would need to disassemble most of the airframe, opening every sealed cavity, before you could get it evaluated, let alone inspected, by MD-RA.
Return to “Homebuilders”
