Liberals Vow to Cancel Jet Fighter Project
Mrs.Robinson
Re: Liberals Vow to Cancel Jet Fighter Project
Post by Mrs.Robinson »
modi13 wrote:
Mrs.Robinson wrote:"First, we have 103 F-18s left, not 80; 80 are in operational use. Second, the F-18s are 1970s technology, so assuming that the F-35s will become inoperable at the same rate is idiotic"
Assuming F-35's will not become inoperable at the same rate is idiotic again. Stuff happens and I don't think 65 will be enough for a 40 year life of the program. After 30 years we have 103 f-18's from 138 a loss of 35. or you can say 138-80 (which have the upgrades for modern combat) loss of 58
What will 7 f35 do for us in 30 years from now? Well it will not, we will buy another aircraft to replace it
Comparing modern airliners to military aircraft is a terrible analogy. first most modern airliners airframes are based on the same technology as 20 years ago, A 737 NG is more or less then same as an older one but has upgraded avionics and engines. When a commercially airliner is designed they three main considerations are 1. dispatch reliability, economics and safety.
When a military aircraft is built it has one priority , Mission parameters. Can is do the mission so required of it. Every thing else is built around this. This is why the V2 failed, it failed because safety was an after thought. I guess old reliably Russian migs are 6th generation fighters as they require less maintenance then newer ones.
Why did you think military jets have ejection seats? Because they have comprised safety so much that it is needed.
Do you actually think Boeing and Lockheed-Martin intend their fighters to be disposable? Compare the safety record of each generation of fighters to the one before and you'll find that fewer and fewer are crashing; the air forces of almost every country have shrunk dramatically, not just because of the end of the Cold War, but because their equipment is more reliable and capable. Engines, regardless of whether they're military or civilian, have become exponentially more reliable, as with extensions of ETOPS requirements. I didn't say anything about the 737, I said the 777 and A330, which are both modern designs using technology that's less than 30 years old.
Military jets have ejection seats because it enhances safety, not because it's expected that they're going to crash. Try putting ejection seats in an airliner's cockpit which doesn't have a canopy; if you were designing passenger aircraft would you give the pilots the option of bailing out and leaving hundreds of passengers to die?
You have nothing on which to base the assumption that we'll only have 7 F-35s after three decades of service. Here's a little math for you: 138 F-18s purchased, 103 remain. That's 75% remaining. Even using a more conservative calculation based on the number which still remain operational, it's 58%. 7 of 65 is 11%, which is simply absurd. Even if the aircraft will spend more time in maintenance, which there's no reason to believe they will, that doesn't mean that they'll have to be permanently taken out of service. On the contrary, modern aircraft will have the potential to remain airworthy indefinitely, so long as they're properly maintained and parts are replaced. The F-35 will become obsolete before it gets worn out.
"Stuff happens and I don't think 65 will be enough for a 40 year life of the program." That's why no one asked you; your uninformed opinion is irrelevant. We should leave the decision up to DND and the people who actually know the specifications and capabilities of the aircraft under consideration.
This is a public forum, people don't need to be asked for there opinion . I guess this simple concept is t too hard for your conservative mind. Instead of responding you attack the person.
So DND preplans how many aircraft will crash? You are the most uniformed, irrelevant poster I has ever seen. No one know how many will be left. I am just responding to your fud like " Our fighter pilot hove said the want and needthe f35", I ask if you can Back that UP. What do you say, " I never said that" You claim that a all modern aircraft are more reliable" basing this on civilian aircraft. Show me a statistic that a gen 5 fighter is more reliable then a gen 4. If it is more reliable how much more reliable is it.
"On the contrary, modern aircraft will have the potential to remain airworthy indefinitely, so long as they're properly maintained and parts are replaced"
Can you back up this statement. So an f35 can last forever. You can have an f35 pull 9 g's 20 hours a day for 40 years and it will still be good to go?
please back up this staement
modi13
Post by modi13 »
Mrs.Robinson wrote:This is a public forum, people don't need to be asked for there opinion . I guess this simple concept is t too hard for your conservative mind. Instead of responding you attack the person.
This may be a public forum, and you have the right to express your opinion, but it should have no bearing whatsoever in the procurement process of military equipment. Here are some areas in which you've demonstrated your ineptitude: I told you that I've always voted Liberal, and you call me a conservative because you only hear what you want to; you asked me to back up my claim that our pilots "want and need the F-35", which I did with four independent sources and the opinions of my friends who will be directly affected by this purchase, and you ignored everything I posted because you didn't want to hear it. I base my claim that modern aircraft are more reliable on the accident statistics of Fourth Generation fighters compared to Third Gen. and Third Gen. compared to Second Gen.; engineering has been getting better, or is that concept too diffcult for you to understand? I never said an F-35 can pull 9 Gs 20 hours a day for 40 years, so it's not up to me to prove that. It simply wouldn't be possible for an aircraft to spend that much time in the air, what with fuelling and crew changes, let alone pulling aerobatic manoevres, so you've set your standards so high as to be impossible. Once again, you've demonstrated that you have no practical comprehension of the requirements of a fighter aircraft.
Expat
Post by Expat »
modi13 wrote:
Mrs.Robinson wrote:
modi13 wrote:
On the contrary, our fighter pilots have said that they want and need the F-35.
you said it not me
I messed up in my quote, again show me the info.
I have 2 friends who fly f-18 and they think the f35 is bad decision. It would be very unscientific for me to conclude that 100% of Canadian fighter pilot do not want the f35. In fact it would make me full of shit to conclude that.
You made a statement, can you back it up.
I didn't make the claim to have that poll, so I can't show you that, but on top of what I posted above: http://www2.macleans.ca/2010/07/16/one- ... love-them/ ; http://www.embassymag.ca/page/view/defence-09-08-2010 "On Aug. 31, Chief of the Air Staff Lt.-Gen. André Deschamps said the planned purchase is due to the F-35's stealth capability, so that Canadian pilots can sneak up on enemies. He told the Globe and Mail that stealth is a "deterrent" since knowledge of such capability would alter an enemy's strategy."; and I personally know more than half a dozen Canadian Forces pilots who all want the F-35, not to mention all the other members of the CF I served with who think it's the best choice.
I worked in procurement at NDHQ, and can say that many high ranking generals were wined and dined, and promised good jobs. They always had to convince their subordinates that they were right.
I was involved in the procurement of our super computers. Even though everybody wanted the Cray computers, we bought the IBMs, because they were the champions of wining and dining in Ottawa...
Never believe generals. :shock:
x-wind
Post by x-wind »
Looking forward to see how some people will respond to your testament Expat.
"If a man is offered a fact which goes against his instincts, he will scrutinize it closely, and unless the evidence is overwhelming, he will refuse to believe it. If, on the other hand, he is offered something which affords a reason for acting in accordance to his instincts, he will accept it even on the slightest evidence. The origin of myths is explained in this way."
-Bertrand Russell
Mrs.Robinson
[/quote]
I'm sure most top generals would like 200 f35's, 50 f 22's 30 more c17"s. They would also advocate we spend 40% of GDP on defense (I'm making this up not stating it as fact like you do). These decisions would have a positive short term benefits for the CF, in the long run it would would bankrupt the county with higher taxes, invoke a brain brain. We would have no more money to pay for any armed forces at this point.
DND should have a fixed portion pf GDP spending (excluding war costs), If they can't afford there purchases within this fixed budget then they can't have it.
I support the CF's I was an officer for 6 years in the forces, but I would pick universal health care and other social programs over DND any day of the week. Many Canadians would also support this.
Making irresponsible purchases today might effect other aspects as the Canadian forces tomorrow. If there are major cost overruns with this program and the liberals are in power they will cut other parts of DND, who do you think will feel this? Over worked front line troops, with no support, doing back to back tours. This is what has happened in the past and will happen again. Our weekend airshow fighter pilots will not feel much pain from these cuts but at least they will have shinny new state of the art demonstrators.
aviator2010
Post by aviator2010 »
which is used to recruit more troops to relieve the over worked troops in place
Panama Jack wrote:I'm afraid I will have to agree with aviator2010
Expat
Post by Expat »
Mrs. R,
We agree on this point.
Nothing worse than having contracts cancelled and re tendered at every change of government. As a country, when we sign a deal, we should respect it.
My main point is that we did not even look at other battle proven hardware available from Europe, which are probably a lot less expensive.
Going sole-source for foreign hardware is not a very good move in asserting our sovereignty, vis-a-vis the US.
It is no fun being in a foreign country, and hearing how Canada is just another state...
Even Belarus opposes Russia more than we the US.
The prime responsibility of our Forces is to protect Canada's sovereignty, including economic independance.
When I was in the military, we had riffles from Belgium, Otto Malara guns on our ships, German tanks, dutch sonars, etc...
And P.E.T. bought Airbus to replace our old 707s!
Let's just have shrewd politicians, that can use our purchases to gain respect worldwide, and not the opposite.
If I am not mistaken, Australia is backing out of the F-35 deal...
Happy Halloween from Af! :D
Expat
Post by Expat »
May be our new role in Af will be pipeline patrol, and we can send these guys there to do it in some small little planes... :lol:
Shiny Side Up
Post by Shiny Side Up »
Actually if we did have more aviation assets to send over the Afghanistan, it would certainly give us leverage so we would then be able to give our ground troops a well needed rest. Canada is currently expending its ground assets over there because, well, its the only thing when we started this that we could send and fulfil our commitments to NATO. How useful new fighter jets to such an area of operations is debateable, but the fact remains if we would have had the capability of deploying some we might then be giving our boys and girls on the ground a well needed rest. Looking to the future if we have shiny new F-35s to deploy, next time we can belly up to the NATO table and say "No, we're sending some aircraft as our commitment, your turn to pony up the soldiers."
fish4life
Post by fish4life »
well said shiny
Expat
Post by Expat »
Every country here has boots on the ground. No country is exempt from that. We could have volunteered our CF-18s. What is the difference with owning CF-35s? That would certainly not have helped our boys on the ground, whe were killed with IEDs, or ambushed in night patrols...
I do not know what the press is feeding in Canada, but one has to read the facts...
cdn
alctel
Post by alctel »
I kinda doubt we would send our shiny new planes overseas to run missions either. We'd be completely reliant on others for the infrastructure to run them and if one crashed or got shot down, thats a 1/60th of our air force gone. And ground troops are always going to be more important than just bombers for these kind of missions so we'd still have to send troops.
Also modi13, I have to say that I don't agree with you at all but I really appreciate you trying to explain your points in detail, since most of the time peoples arguments seem to consist of shouting nasty things about 'liberals' (of which I am not one) or yelling SUPPORT OUR TROOPS with their (proverbial) fingers in their ears, so its nice to actually have a discussion.
trampbike
Post by trampbike »
@Mrs. Robinson,
I have the regret to inform you that you are a troll. I stopped counting the logical fallacies you used after 2 pages.
I might suggest you take some time reading this 59 pages thread about the F-35 http://forums.army.ca/forums/index.php/ ... 415.0.html so you have a bit more knowledge, and I also suggest you read http://en.wikipedia.org/wiki/Fallacy (spend a bit more time on straw man) so one day you might be able to participate in a debate in a constructive way.
@Modi13, I salute your efforts. I can understand your pain...
Think ahead or fall behind!
alctel
Post by alctel »
trampbike wrote:@Mrs. Robinson,
I was reading that thread, and it seems to suggest that a lot of people have doubts about buying the F35 and that we were half-blackmailed into bidding on it by Lockheed-Martin so I don't know why you think it backs up your points.
Lots of interesting technical stuff in there though, and interesting information about the acquisition process so thanks for the link!
trampbike
Post by trampbike »
My point was not about wether f35 is the good choice or not for Canada. My point was that the way Mrs. Robinson "argues" guarrantees that whatever he says will not be valid
Mrs.Robinson
trampbike wrote:My point was not about wether f35 is the good choice or not for Canada. My point was that the way Mrs. Robinson "argues" guarrantees that whatever he says will not be valid
name me one thing that I said that was not valid? Can you back it up with fact.
Mrs.Robinson
modi13 wrote: On the contrary, modern aircraft will have the potential to remain airworthy indefinitely, so long as they're properly maintained and parts are replaced.
Can you or anyone here back this up?
If you statement is correct an f35 will remain airworthy if it flys 20 hours a day for 40 years pulling 9 G's the entire time as long as it has regular maintenance
If you don't link my analogy then stop making things up.
winds_in_flight_wtf
Post by winds_in_flight_wtf »
Interesting indeed, those useless CF18s which many demote through this thread happened to carry out yet another intercept over Canadian Airspace. Oh how the liberals look like idiots today! Just give it a few days though and the Ignatieff loyalist- conspiracy theorists will display their true colors
http://news.blogs.cnn.com/2010/10/29/no ... rt/?hpt=T1
I still am amused how people have the nerve to state that Canada should:
a) Adopt a platform that is obsolete as opposed to one which is state of the art
b) Use the threats we face in Afghanistan (IEDs etc) , as some sort of concrete fact against the purchase of a new fighter aircraft. (Would be nice for people to pull their head out of one’s ass, and actually understand the difference between air superiority, land forces, and naval forces.) We are a G8 nation, and the fairy tale peacekeeper shit really has to stop. I think the best medicine here for the trolls is to crack open the Canadian Military History books, rather get some psychiatric help to help restore some common sense.
What fully developed nation does not have a ready-able Military? I would rather piss money away with the DND as opposed to the modern day First Nations agenda.
alctel
Post by alctel »
winds_in_flight_wtf wrote:Interesting indeed, those useless CF18s which many demote through this thread happened to carry out yet another intercept over Canadian Airspace. Oh how the liberals look like idiots today! Just give it a few days though and the Ignatieff loyalist- conspiracy theorists will display their true colors
I don't really see what your point is here, since half of this reads like a Sun/Tory op-ed but I'll try to make sense of it.
The jets carried out an intercept on an airliner - something they managed perfectly fine, despite being 'useless' as you put it. This really doesn't seem a reason to buy the F35 since virtually any fighter aircraft made in the last 50 years could do this just as well. I don't understand the next bit about people looking idiots or conspiracy theorists so I'll pass on that.
What do you mean by 'obsolete'? No-one is saying we should buy a bunch of Sabres or Meteors or something like that. People are questioning sole-sourcing an extremely expensive stealth fighter/bomber as our only jet aircraft when its main use will be defending sovereignty/intercepts, often over some of the most extreme terrain on earth.
People are bringing up Afghanistan because it's the kind of war that is by far the most likely we will face in the future. Having a few expensive fighter/bombers will not do anything to help the guys on the ground and probably won't even be deployed over there. As to looking up history - if you are trying to compare the world today to pre-WWI or WWII then you should do some reading yourself! Again, I am not really sure what you mean by 'restoring common sense' so I'll skip that part.
As to your last point - if you want to see what happens to a country when they spend half their GDP on their military-industrial complex and virtually nothing on social services, just look south of the border. Extremely high crime rate, 1 in 10 kids on food stamps and wildly out of control (and untouchable) contracting and military waste.
Mrs.Robinson
I could not write it any better. As soon as you question the f 35, you are attacked with the following you don't support our troops, DND knows best, We need this for NATO integration (even though most of NATO will not have the f 35).
Nothing is wrong with a competitive bid, If the f35 wins we might get the aircraft on better financial terms, Might get 70 for the price of 65.
In my opinion the C17 was a great decision as it support out troops. We should invest in what Canada does most with it's CF's, that is troops on the ground. I'm sure a Gen 4.5 Fighter with longer legs would be more beneficial and if I'm wrong let the f35 win the competition in a competitive bid.
Shiny Side Up
Never said that everyone else didn't have boots on the ground, also never said having F-35 would help right now. The F-35s are for the future.
I've had how NATO works explained to me once as such. NATO is like a group of old women who like to throw a pot-luck dinner. Depending on the dinner, it will need a certain number of the old gals to do jobs - they can pick and choose which jobs they'd like to do, but when they're turn comes to cook they have to pitch in. Right now Canada can't cook, we can only wash dishes, So whenever our time comes to pitch in, guess what we get to do. Not to say that we don't wash dishes well, even if we have to get one of the other old ladies to give us a ride because we don't have our own car. Guess what we trade for the car ride? Maybe we help Mrs. Germany's turn to wash dishes. We could volunteer to bring potato salad sometime, but last time we did that we had to get Mrs. America to drop it off for us. See where this is going?
Enough with that analogy. I know some of those "boots on the ground" we've had to borrow everything from Land transport to helicopters since Canada has made its commitment to Afghanistan. They're wearing out, they're getting tired of washing dishes because all Canada can supply to her Allies right now is warm bodies. Don't kid yourself when you might think that we could have sent the F-18s over there - that would have required Canada yet again borrowing an Ally's assets and we're tapped out on our dish washing schedule. We're viewed slightly above the nations who send their soldiers on UN missions hoping the richer countries will kit them out when they go. I think we can do better than that. F-35s aren't going to save one of our boots on the ground from a night ambush or an IED. They're deffinitely going to give us some pull when it comes to the next time we have to send the boys and girls into a bad place in the world - especially over the other old ladies at the table who maybe didn't buy any jello salad. Maybe I'm not finished with that analogy - guess who we bought the Jello salad from - Mrs. America - the loudest voice in that group.
modi13
Post by modi13 »
Mrs.Robinson wrote:If you statement is correct an f35 will remain airworthy if it flys 20 hours a day for 40 years pulling 9 G's the entire time as long as it has regular maintenance
When has this ever been a requirement for any aircraft? I never said it would be able to do this, and you can't just make up arbitrary requirements. The F-35 is more capable than Gen. 4 fighters, but that doesn't mean it can handle absurd, completely unrealistic loads. That's like refusing to buy a new car because it can't pull a train 20 hours a day for 40 years. Once again you've made a ridiculous strawman argument and declared yourself the winner because supporters of the F-35 program don't meet your particular, completely idiotic demands. :?
As for an aircraft remaining airworthy indefinitely: http://www.pprune.org/military-aircrew/ ... -life.html second answer: "That's technically true of every aircraft! Any ac fully maintained could have fatigued components replaced with new ones, allowing the ac to continue flying safely. It is possible to replicate and replace any ac component (apart from the original crew!). Now, whether it is finacially vaible to do so is another story, when you reach the point of lathing individual items to order etc, the cost of the maintenance will outweigh the value of the ac." and http://uk.answers.yahoo.com/question/in ... 509AAwegcw second answer: "An airplane can remain airworthy indefinitely as long as it's properly maintained. As it gets older, more and more maintenance is required, and at some point the owner usually decides that it's cheaper to buy a new aircraft rather than continue to maintain the old. However, an owner who is determined to fly an airplane forever can theoretically do so if he can afford the maintenance. Eventually very major parts of the aircraft have to be replaced, and ultimately the aircraft is practically rebuilt.
Pressurized aircraft often have a useful lifetime measured in cycles, with each cycle being a pressurization followed by a depressurization. Pressurization stresses a large part of the airframe, so once a certain number of cycles has been reached, a major overhaul is required to keep the aircraft airworthy, although anything is possible if the price is right.
Airliners are inspected and maintained in an escalating series of checks, ranging from very simple, frequent maintenance that might only require an hour, to very extensive maintenance that might take weeks and nearly represents a complete rebuild of certain parts of the aircraft.
If your car were as well maintained as an airliner, you'd be able to buy just one car and drive it for the rest of your life, and it would never have so much as a flat tire. And you'd be able to trace every part of the car all the way back to the factory that made it."
Mrs.Robinson
When has this ever been a requirement for any aircraft? I never said it would be able to do this, and you can't just make up arbitrary requirements. The F-35 is more capable than Gen. 4 fighters, but that doesn't mean it can handle absurd, completely unrealistic loads. "
So know the f35 can't pull 9 g's, even more reason not to get it
You said
"On the contrary, modern aircraft will have the potential to remain airworthy indefinitely, so long as they're properly maintained and parts are replaced."
In the English language that means it can last forever or at least 20 hours a day at 9 g's for 40 years.
You stated it lasts forever (On the contrary, modern aircraft will have the potential to remain airworthy indefinitely, so long as they're properly maintained and parts are replaced.)
Now you tell me the f35 can't do 9 g's
I have one question. Do you make up everything you say?
You where denying something you wrote yesterday even after I quoted yourself 3 times. I know fact and logic confuse you.
alctel
Post by alctel »
Let's leave the personal attacks out of this hey?
modi13
Post by modi13 »
Mrs.Robinson wrote:So know the f35 can't pull 9 g's, even more reason not to get it
WHAT?!?!?!?! Are you mentally handicapped? At what point did I say that the F-35 can't pull 9 Gs? A load isn't just force, it's force over time, and pulling 9 Gs over 20 hours is a significant load. And how could you possibly extrapolate "it can last forever or at least 20 hours a day at 9 g's for 40 years" from "modern aircraft will have the potential to remain airworthy indefinitely, so long as they're properly maintained and parts are replaced"? How long an aircraft can last says nothing about what loads it has to handle. 737s can be maintained indefinitely; does that mean they have to be able to pull 9 Gs 20 hours a day for 40 years? Nothing you say makes any logical sense.
I corrected myself and apologized for my mistake. If you're still on that then you're an immature imbecile, and I have no problem bringing up the post you made that angered me in the first place: according to you, Canada didn't contribute anything to the Second World War. I know a few vets who are selling poppies for Remembrance Day who would take issue with that stupidity.
