Sukhoi Superjet on fire Moscow
shimmydampner
Re: Sukhoi Superjet on fire Moscow
Post by shimmydampner »
Must be important stuff in it.
Therein lies a lot of the problems. People are selfish and value their easily replaceable belongings more than strangers' lives. They are willing to place others in danger if it means retrieving their toothbrush and iPad. Airlines should be compelled to stop charging for every checked bag and start enforcing the carry on bag size limits (which should be smaller: no bigger than a ladies handbag or a laptop case) so that all the sweatpants and flip flop wearing mouth breathers don't feel compelled to, and are not allowed to bring all of their "valuables" in the cabin with them. If the morons want their belongings so badly, let them endanger only themselves and run into the belly of a burning plane they just evacuated, to get them.
Roadrunnersmother
Post by Roadrunnersmother »
shimmydampner wrote: Sat May 11, 2019 7:41 am
Your mental state is questionable.
shimmydampner
Ok.
plhought wrote: Thu May 09, 2019 7:31 pm I doubt the SSJ has any facilities to jettison fuel.
Thank you. Was genuinely curious as saw that point raised in an article.
I did not know some jet aircraft cannot jettison fuel.
jakeandelwood
Post by jakeandelwood »
That's half the problem right there, those flip flop wearing mouthbreathers in sweatpants :lol: are to friggin cheap to pay the fee to check an extra bag so they lug this giant bag onto the plane that they have no reason to need in the cabin and they can barely fit them in the overhead while all the time there is a half empty cargo area underneath. I've never understood why airlines charge to check the bag but not carry it on. Either charge for both checked and carry on or charge for neither of them. The bag is still on the plane either way you slice it, so what difference does it make in the end?
goingnowherefast
Post by goingnowherefast »
Because if you carry it on, it's part of your carry-on weight allowance. Ya know, everybody weighs 200lbs. If it's checked, it gets weighed and adds to the baggage weight. The less baggage weight there is, the more cargo they can carry, the more passengers, excess baggage, etc. Basically more revenue potential when they force the crap into the cabin.
Plus they don't have to pay rampies to load carry-on bags.
Not that I agree with it, but that's the way it works.
A346Dude
Post by A346Dude »
For a short trip I can bring a carry-on, pay $0 and be off the plane and into an Uber right away. Or I can check it, pay $25 and wait 20+ minutes at the carousel, and that's if it didn't get lost or damaged along the way.
Kind of a no brainer why people might bring a carry-on.
goingnowherefast wrote: Sat May 11, 2019 2:03 pm
Yup. Airlines want it that way. So do grocery stores. Self serve everything. Personally I hate that model.
They would have pax load bags themselves and eliminate flight attendants If they could.
jakeandelwood
They should just start weighing passengers at the ticket booth, there is already a scale right there, then if you only weigh 160 ibs you get to check your 40 lb bag for free. The over 200 pounders would have to pay extra for their own rump. Like that would go over well, lawyers would be having a field day.
shimmydampner
A346Dude wrote: Sat May 11, 2019 4:28 pm Kind of a no brainer why people might bring a carry-on.
Of course it's a no brainer WHY they might bring a carry on. No one is questioning the why. The point is that perhaps it makes more sense to do everything possible to restrict people's access to their belongings if it turns out that easy access to their stupid belongings is what endangers other people's lives in an emergency. The fact is that safety generally panders to the lowest common denominator imbeciles (which are over-represented on the average flight) so perhaps we should treat cabin safety the same. MAYBE, just MAYBE this is the exact time and place where playing to the morons makes sense.
Illya Kuryakin
Post by Illya Kuryakin »
Roadrunnersmother wrote: Sat May 11, 2019 7:53 am
Been saying this about him for years.
Illya
Full landing sequence shown in this video.......
https://www.youtube.com/watch?v=gkNoLSr ... e=youtu.be
I am not sure what damage was caused by the lightning strike that resulted in the return to the airport. Perhaps they had failures in the flight control system or other reasons to insist on remaining on the ground once they had touched down.
Certainly under normal operations, one wants to go-around when porpoising like this. Pushing forward on the controls is the worst thing you can do in this situation. Happened at my company on a large aircraft many years ago. Wrinkled the fuselage and the aircraft never flew again. Hold pitch steady for the second touchdown(or as per instructions in the manual) or go-around if the bounce is high enough.
Jet Jockey
Post by Jet Jockey »
The first bounce was at 2.55Gs. The second bounce was at 5.85Gs and the third and final one was also above 5Gs... No wonder the aircraft broke apart and the fuel started to come out of the ruptured fuel tanks and ignite.
More info...
Crashed Superjet's pitch fluctuated before fatal touchdown
•18 May, 2019
•SOURCE: Flight Dashboard
•BY: David Kaminski-Morrow
•London
Russian investigators have disclosed that the Sukhoi Superjet 100 involved in a fatal accident at Moscow Sheremetyevo was 1.6t over its maximum landing weight, and experienced two impacts in excess of 5g as it bounced on landing.
The Interstate Aviation Committee says it has completed an initial analysis of information from the flight-data recorder retrieved from the Aeroflot jet after the 5 May event.
Investigators have revealed that the crew received windshear warnings on approach and that the aircraft experienced pitch fluctuations just before the fatal touchdown.
Federal air transport regulator Rosaviatsia, in a detailed outline of the flight, states that the aircraft suffered an electrical failure at 8,900ft – about 5min after take-off from runway 24C – while following the KN 24E standard departure pattern for a service to Murmansk.
The aircraft’s autopilot disengaged and the aircraft’s flight control system dropped into direct law.
Rosaviatsia does not specifically state that the aircraft was struck by lightning, but it does point out that the aircraft was flying within a “zone of thunderstorm activity”.
The flight recorder registered disengagement of the autothrottle, and Rosaviatsia says the captain manually controlled the aircraft for the remainder of the flight.
Unable to communicate on the approach frequency, the crew restored VHF radio links using the emergency frequency 121.5MHz, and was vectored back to Sheremetyevo while transmitting the squawk code ’7600’ for loss of communication.
The aircraft conducted an ILS approach, in manual mode, to runway 24L.
Rosaviatsia says the aircraft had departed with a take-off weight of just over 43.5t and that its weight upon entry to the glideslope was 42.6t – which, it says, exceeded the maximum landing weight by 1.6t.
As required for the overweight landing, and the direct-law control, the flaps were set to 25°. The crew also upgraded the squawk code to the emergency setting ‘7700’.
The aircraft remained largely stable on the approach – performed in a crosswind from the left of up to 30kt – with an airspeed of 155-160kt.
As the Superjet descended through 1,100-900ft above ground, the crew received five predictive windshear “go around” warnings.
The aircraft began to dip below the glideslope at about 260ft and, at 180ft, a glideslope alert sounded.
Thrust was subsequently increased, with the throttle levers alternately advanced and retarded between 18° and 24° as the aircraft descended to 40ft. This resulted in the airspeed increasing to 164kt as it crossed the threshold and 170kt at 16ft from touchdown.
As the captain retarded the throttle to idle, says Rosaviatsia, he made several alternating inputs to the side-stick with “large amplitudes” – up to the maximum – which resulted in the pitch varying between 6° nose-up and 2° nose-down.
While the aircraft had appeared close to touchdown at about 700m from the threshold, Rosaviatsia says the first three-point contact with the runway occurred at 900m from the threshold at 158kt, when the aircraft experienced an impact of more than 2.5g, and bounced to about 6ft.
Rosaviatsia says the aircraft’s spoilers did not deploy automatically. Aeroflot stresses that its procedures do not require the manual deployment of spoilers until thrust-reverse is activated and the aircraft is settled and stable on the runway.
“In the absence of a stable course the release of the spoilers was impossible,” the carrier adds.
Having bounced, the aircraft touched down 2s later on its nose-gear at 155kt, with a heavy impact of 5.85g, causing the Superjet to bounce a second time, to a height of 18ft. The third, and final, impact occurred at 140kt – reaching at least 5g – and was immediately followed by damage to the aircraft’s structure, a fuel spill and fire.
As the aircraft decelerated through 100kt, sliding along the runway, a fire alarm was triggered in the aft baggage and cargo compartment, followed by a fire alarm in the auxiliary power unit 16s later. The aircraft’s PowerJet SaM146 engines continued operating until the end of the flight-data recorder trace just after 18:31.
Rosaviatsia says the captain had logged 1,570h on type out of a total of 6,844h while the first officer had 623h on type.
The aircraft (RA-89098) had accumulated 2,710h over the course of 1,658 cycles.
Rosaviatsia says the fatalities comprised 40 of the 73 passengers and one of the five crew members, while six passengers and three crew were injured.
Aeroflot stresses that the preliminary information disclosed by Rosaviatsia does not reference errors by the crew or any violation of procedures, and that final conclusions have yet to be released by the investigating authorities
shimmydampner
I'm assuming that 25° is a reduced flap landing for this type? Anyone have any idea what the ref speed would/should have been?
Ki-ll
Post by Ki-ll »
shimmydampner wrote: Mon May 20, 2019 8:29 pm I'm assuming that 25° is a reduced flap landing for this type? Anyone have any idea what the ref speed would/should have been?
Direct law landings should be done at flaps 3 setting.
At max take off weight for an immediate return it is about 160kts. Reducing by roughly 3 knots per 1000kg.
