I had Lightspeed 30 3 G's. As I've posted earlier, good points: cell phone/music interface. Noise attenuation- very good, but you will get crackle on take off in a beaver!. Batteries are AA, I use rechargeable's. 30 hr on a battery charge. Comfortable. Great customer service.
The bad is, limited warning when the battery starts to die or dies. Unless you put the annoying blinking light in front of you. (Almost impossible in a Dehavilland). When the battery dies in flight, remove the headset and talk directly to the radio, because it will sound quieter. Lightspeed decide to redesign the plug ins. The don't work in some situations. (I had to turn my headset off in a couple of aircraft when I was a passenger, due to interference. Even blanked out the whole intercom system on 1 plane) Just plane don't work in other aircraft.
I tried the Bose. I thought they sucked. I got a head ache after 2 hr. I have a small head (don't need much cranium to be a pilot). Noise attenuation was not as good.
I fly noisy twin turbines with the new David Clark's. Comfortable after 17 sectors and 8.5 hr flying time. Work good with or without the noise cancel on. Work in ALL aircraft. The biggest set back is the bulky 9V battery pack (30 hr on a battery) and no external interface.
Bottom line is, if your going to buy a high end headset, try before you buy. Your expectations, environment etc may determine the best choice.
