Industry Standard..."Dot Above" vs. "Dot Below"?
single_swine_herder
Re: Industry Standard..."Dot Above" vs. "Dot Below"?
Post by single_swine_herder »
Canoehead wrote:What Donald said
Exactly what Donald said.
I'm rather surprised to see folks interested in describing the relative position of the desired signal, not the position of the aircraft.
SSH
bald seagull
Post by bald seagull »
Your position relative to glideslope.......then the glideslope position relative to you.
:shock:
AuxBatOn
Post by AuxBatOn »
I would rather describe what I see in the cockpit (ie: 1 dot above when below g/p). That way, what I see matches what I hear.
Going for the deck at corner
Donald
Post by Donald »
AuxBatOn wrote:I would rather describe what I see in the cockpit (ie: 1 dot above when below g/p). That way, what I see matches what I hear.
In that case, you will see what you heard.
IE expectancy
BTD
Post by BTD »
In soviet russia, glideslope calls you.
tavca
Post by tavca »
glides(lope) alive
Tavca
