Possible to bid for more than one base?
Moderators: ahramin, sky's the limit, Sulako, North Shore
Message
Author
Delta602
#1 Post by Delta602 » Tue Jul 18, 2017 1:12 pm
Thinking about starting the application process soon. Is it possible to bid for more than one base?
For example I expect I would likely get classic in Montreal, but could I put in a request for Vancouver and Calgary and then take the first one of those two that get approved?
Magnetron
Re: Possible to bid for more than one base?
#2 Post by Magnetron » Tue Jul 18, 2017 1:29 pm
You can put any base and any position you want in the order of your priority and it will get awarded that way whatever has open spots.
So if you prefer one over the other, you could put that 1st then the other 2nd and then your current position 3rd (if you don't want any other bases).
av8ts
#3 Post by av8ts » Wed Jul 19, 2017 6:19 am
Then once you are online you can bid any position in any base and even qualify ( the number of pilots below you in seniority in that position) that position. However you can't qualify your current position, although nobody seems to know why.
Delta602
#4 Post by Delta602 » Sat Aug 19, 2017 6:34 pm
Thanks for the replies.
Given the choice what would be the best equipment to get a base out west? Either YVR or YYC
Black_Tusk
#5 Post by Black_Tusk » Sat Aug 19, 2017 7:42 pm
Q400 or RJ.
There are so many vacancies right now, and things change every month. Just bid the plane you want/can get and you'll likely be at your preferred base within a few months. Keep in mind if you want a quick upgrade you'll likely have to go to YUL for it...
FL-280
#6 Post by FL-280 » Sat Aug 19, 2017 8:06 pm
Black tusk hit it spot on... try to avoid the classic if you can. Very small roster in YYC.
Any aircraft is great, you will like it here!
Good luck at the draw.
