AVCANADA
It is currently Tue Oct 17, 2017 11:41 pm
Post new topic  Reply to topic  [ 10 posts ]
Author Message
PostPosted: Sun Aug 20, 2017 1:56 pm
Offline
Indicated between 800-1400 on taxing...unstable... seems fine on run up... showed 2700 on take off should be about 2600...appeared steady and stable at cruise... and indicated about 700 rpm after landing and taxing to dock. Which is it what it normally indicates...
Bad tach meter? Cable? Faulty governor?
Top
PostPosted: Sun Aug 20, 2017 2:15 pm
Offline
Gauge, cable, tach drive. Could be anywhere in the system. Was this done within the last year?
Quote:
Standard 625 APPENDIX C - Out of Phase Tasks and Equipment Maintenance Requirements
8. Tachometers
The accuracy of mechanical drag cup type tachometers, for fixed wing propeller driven aircraft, shall be checked on site annually, and be accurate to within the tolerances established by the aircraft manufacturer or, where no tolerance has been specified by the aircraft manufacturer, to within +\- 4% of engine RPM at mid-point of the cruise range.
Is there any reason to suspect the governor? Does anything else fluctuate?
Top
PostPosted: Sun Aug 20, 2017 2:26 pm
Offline
This a digital tach and yes it is checked every year. Never acted this way before...nothing else is fluctuating at all.
Top
PostPosted: Sun Aug 20, 2017 2:34 pm
Offline
Ah. Connected to a sender or hooked into the p-leads?
Top
PostPosted: Sun Aug 20, 2017 2:46 pm
Offline
I believe so but will have to check with engineer when he has time
Top
PostPosted: Sun Aug 20, 2017 2:50 pm
Online
tazin river wrote:
Could you actually hear the RPM fluctuations?
_________________
Control the horizon, control the airplane
Top
PostPosted: Sun Aug 20, 2017 3:31 pm
Offline
No
Bad connection?
Top
PostPosted: Sun Aug 20, 2017 3:33 pm
Offline
Had pile of rain while the plane sat at the cabin? Moisture related?
Top
PostPosted: Sun Aug 20, 2017 3:36 pm
Online
I spent ages (years, $$$$) chasing crazy intermittent fuel flow fluctuations. It turned out to be only instrumentation error caused by electromagnetic interference from a poorly shielded spark plug lead. I found it finally because it went away the instant I switched to run only on one mag.
Something to try in your circumstances.
_________________
Top
PostPosted: Sun Aug 20, 2017 6:21 pm
Offline
Sounds like an interference problems of some kind as photofly alluded to,
When its acting up try switching mags, power off the radio, turn off the alternator etc. see if you can find an offending source.
Did you have new electronics installed? Any new electrical work? That would be an obvious suspect.
A common problem is just poor grounds, that's often a good place to start. Sometimes the bolts where the common grounds attach gets rusty or loose.
A frayed connection is also possible, look for it at the point where the wire bends or where it is crimped, often the strands break one by one and pretty soon its making intermittent contact.
Top
Who is online
Users browsing this forum: No registered users and 17 guests
Search for:
Jump to:
[ GZIP: Off ]
avcanada@gmail.com
AvCanada Topsites List
