AVCANADA
It is currently Fri Oct 20, 2017 8:44 pm
Post new topic  Reply to topic  [ 7 posts ]
Author Message
 Post subject: IFR Rating in the US
PostPosted: Mon Aug 28, 2017 3:41 pm
Offline
Does anyone know what the procedures are to get IFR rating in the US for a Canadian commercial
License ?
Would I have to convert my license to FAA or just do the flying and do the flight test and written in Canada ?
Top
 Post subject: Re: IFR Rating in the US
PostPosted: Mon Aug 28, 2017 5:35 pm
Offline
If you want to fly your C reg aircraft in the US, your Canadian CPL+IFR is all you need (plus EAPIS, CBP sticker, POE for customs, and all that jazz)
If you want to fly a N reg aircraft, you generally need a FAA Certificate (Licence). You get the FAA to verify your Canadian licence and rating with AFS760 (Form AC 8060-71).
Then, if you're after private privileges, you can get a certificate based on your Canadian licence and medical. If you want your instrument rating on it, you'll have to write the US IFR conversion test (not sure if there's a flight test component for the IFR rating conversion - don't think there is.).
Alternately, you could convert to a full FAA Private Certificate. Pretty much all the above plus a US Medical and then it doesn't depend on your Canadian licence.
For commercial, you must do a full conversion + medical + test + fllight test.
For ATPL, you must do more tests and a special course (that I know little about - search for it).
Top
PostPosted: Mon Aug 28, 2017 6:00 pm
Offline
If you don't have a Canadian IFR rating yet, the cheapest way would be to go back to Canada and do it there. You'd still need to write the INRAT, and that's usually at a Canadian flight school or TC. Then you'd need a TC flight test examiner to do the flight test. And most of your IFR training must be by a TC flight instructor. The initial rating is relatively closely controlled. (Though if you had all the above in the states, you could certainly do it all there.)
The other approach would be a full conversion to a FAA CPL, then train for and get a FAA IR. Then convert the FAA IR to a TC IFR (which I believe still requires the INRAT and a TC flight test for the conversion). All you really save here is the requirement for doing your training with a TC flight instructor.
Cornwall Aviation has a good reputation for purposeful training (though I haven't been there): http://www.cornwallaviation.com/en/serv ... t-off.html
Top
PostPosted: Mon Aug 28, 2017 6:14 pm
Offline
Convert to FAA cpl
Once you complete training in US
Flight test not required on return
INRAT not required either
A simple 20 or 30 question exam
I did this and it was a lot more cost efficient
Top
PostPosted: Thu Aug 31, 2017 7:17 pm
Offline
When I convert to FAA do I still keep my Canadian CPL or it becomes US license ?
If so than I'd have to convert back to Canadian CPL upon return ?
Top
PostPosted: Sun Sep 03, 2017 9:43 am
Online
You keep your Canadian licenses. It's not like with Driver's Licenses- you are issued an additional US Pilot Certificate, which is a legal requirement to fly N-registered aircraft.
_________________
-President Ronald Reagan
Top
PostPosted: Sun Sep 03, 2017 3:07 pm
Offline
Thanks for the info. So where do I start with the conversation process ? How long does it take ?
Any additional info would be greatly appreciated.
Thanks.
Top
Who is online
Users browsing this forum: Exabot [Bot], Google [Bot], youhavecontrol and 22 guests
Search for:
Jump to:
[ GZIP: Off ]
avcanada@gmail.com
AvCanada Topsites List
