Looking for advice on LED position lights
Message
Author
ctmorawetz
#1 Post by ctmorawetz » Tue Sep 19, 2017 8:28 am
Does anyone have experience replacing incandescent bulbs on a 172 with LED position lights? What do you recommend? Thanks!
Keep your stick on the ice - Red Green
robertw
Re: Looking for advice on LED position lights
#2 Post by robertw » Thu Sep 21, 2017 7:41 am
You can't just order up some new LED Nav lights as installing them would constitute a change in the type design. In this case I would think that it is a major modification per CAR 571.06, which means that you would need an STC to approve the installation of LED nav lights. There are some business jets I've seen out there with LED nav light STC's, but I've not seen an older GA aircraft out there with them. Mind you, I haven't been looking either.
Chris M
#3 Post by Chris M » Thu Sep 21, 2017 9:20 am
There are actually numerous retrofit options - Whelen, Aveo...
https://www.aircraftspruce.ca/menus/el/ ... ights.html
STC's are available to cover just about any LED swap (Nav, beacon, strobe, taxi, landing, etc). I believe some are even PMA replacements, no STC required.
all_ramped_up
#4 Post by all_ramped_up » Thu Sep 21, 2017 4:10 pm
^ This. Just like Taxi/Landing Lights there are basically drop-in LED replacements available.
wrenchturner
#5 Post by wrenchturner » Thu Sep 21, 2017 5:44 pm
Whelan lights are STC'd for most common GA aircraft already. They fit right in to the current installation. Only thing to remember is they are polarity sensitive
adam325i
#6 Post by adam325i » Fri Nov 17, 2017 7:02 pm
If your still looking, here is an option that's Canadian.
http://www.navstrobelighting.com/
https://www.aircraftspruce.ca/catalog/e ... key=110392
FrozenWrench
#7 Post by FrozenWrench » Sat Nov 18, 2017 6:55 pm
Have done the change many times with Whelen parts. Straight up replacement and no STC needed. As said before, just watch the polarity.
#8 Post by PilotDAR » Sun Nov 19, 2017 5:27 pm
ct,
The advice you've been given here is good. If it won't work, you can PM me. I've STC'd these before.
AirFrame
#9 Post by AirFrame » Mon Nov 20, 2017 7:45 am
Only legally an option on amateur-builts, I expect. NavStrobe lighting "...have been designed to meet the requirements of TSO-C30c." ie. they believe it meets requirements, but they've never been formally tested for approval. The Aircraft Spruce page has a Q&A tab where this is addressed as well.
HiFlyChick
#10 Post by HiFlyChick » Fri Dec 22, 2017 1:53 pm
Haven't checked into position lights, but in the last year or so had to replace a rotating beacon (assy), and even though it required an STC, the LED beacon from Whelen was still cheaper (including the STC paperwork!) than buying the old assy. The only down side is that it is freakishly bright, especially after dark.... :)
JasonE
#11 Post by JasonE » Sat Dec 23, 2017 5:42 pm
Replaced the Whelen strobe assembly on my Cherokee last winter. It was less than half of what they want for an LED unit. Too bad the bulb didn't last more than 6 months and Aircraft spruce won't warranty it!
Heliian
#12 Post by Heliian » Wed Dec 27, 2017 5:45 pm
Check the wiring and grounding, poor connections will shorten the life considerably.
Return to “Maintenance”
