Sunwing hiring update
JoeyBarton
Good evening folks,
Any update on the hiring forecast? Heard they are conducting a oct GS, is there anything planned for later on this year?
Re: Sunwing hiring update
JoeyBarton wrote:Good evening folks,
Sunwing hired 42 during April and May. Two classes of 10 out of 49 to be hired this fall are going through training right now. So 29 more applicants to be hired and to start training soon. We received a recent memo stating we will have non-stop hiring in the next 12 to 24 months.
Good Luck!!
Any carrier that has early start/late start long duty days will be affected by the proposed FTDT rules likely to come in to effect early in 2019.
SW and all other affected carriers will have 2018 to get staffed up. I heard that SW estimated a 17% impact on crew efficiency.
Sounds like massive hiring will start soon for next winter.
They prefer internal reference.
So if you have a buddy at Sunwing, use him/her !
Looks like we’re joining the race to find pilots. Should be around 100.
Good news you might get a WJ number and as a new hire you’ll get called for overtime first. A world first!
Is there an updated pay scale? The latest I can find only goes up to 2019.
DHC-1 Jockey
Minimum annual guarantee is 900 hours (down from 1000 hours in CBA 3).
You'll note there's some pay freezes from Year 1-2 on the Captain side and at the top end of the scale for both Captains and F/O's. There are some funky LOU's that deal with this issue that are too long to explain here.
FOD_Vacuum
Sunwing hiring portal is open for FOs and DEC!
https://jobs.jobvite.com/sunwing/job/ocWkjfwv
Good luck to all those who apply-I believe Interviews start next month.
goingmissed
WestJet and Encore use a five digit number. 1xxxx, 2xxxx, 3xxxx. They are used for all WestJet and Encore employees, including pilots, flight attendants, CSAs, and other staff.
Swoop uses a six digit number starting with 8. 8xxxxx. I am unsure if they are shared with other Swoop employees.
So? What’s your point?
I like the entertainment!
I believe he’s jokingly alluding to how WJ would love to slot the sunwing guys under the swoop LOU
Not only that, Westjet manline isn't hiring. But Swoop is desperate to hire non Encore pilots as quickly as possible before Encore pilots wake up and do something about it. Sunwing traditionally goes from 30 tails, down to 7 in the summer, yet they force recalled all of their pilots who were working elsewhere to do what? Are deployments happening? Maybe Westjet is recalling Sunwing pilots so they can give them pink ties, and pay them pink wages?
Yes deployments are happening and Westjet is not recalling swg pilots.
As for the rest...speculations...
Half our planes are going to Europe in summer. We have more than 7 planes in the summer.
Any updates on how the pilots will fit in into the list when the merger happens? I see SW is hiring. Is it worth it for a pilot to go to SW now without much knowledge of what the future holds for the pilot group? I guess for a new hire, it's not as critical as a senior SW pilot. I'm a bit out of touch with the merger.
mmm..bacon
Bumpity bump bump...
And...is that payscale still valid? If I'm reading it right: 900h (minimum annual) x $61.61 = $55449/yr. perdiems? base allowance? negotiable start level? Anything to make that salary higher than the Navajo pay I made back in 2002?
doiwannabeapilot
Per diem : yes
Work on GDO : X2
OT
Deployment : not sure it is going to happen again.
Work on GDO : X2
OT
DHC-1 Jockey
Negotiable start rate?: No. Payscales are as per the CBA.mmm..bacon wrote: ↑Thu May 19, 2022 10:26 am Bumpity bump bump...
Base allowance?: No.
Perdiems: I got about $700 per month doing multi-day trips. If you do single-day turns and receive crew meals, I don't believe you get perdiems at all.
Should you interview with Sunwing, be sure you ask the interviewers where they see themselves in five years. They are mostly likely going to ask you this but I think the question is just as notable when reversed in this case. Hopefully they are honest with you.
Dumb question….IMOfruz wrote: ↑Fri May 20, 2022 12:07 pm Should you interview with Sunwing, be sure you ask the interviewers where they see themselves in five years. They are mostly likely going to ask you this but I think the question is just as notable when reversed in this case. Hopefully they are honest with you.
The honest answer everyone should give no matter what airline they’re interviewing at should be “who knows”.
5 years ago nobody would have thought Canadian aviation would have been effectively shutdown…..
