As for the price of a CL65, AC paid between $28-31 million per. I don`t know were the that fellow who said an A320 was $30 mil. got his info from. That is very wrong. If memory serves me correctly, I believe we paid approx. $80mil. for the Airbuses.
Air Canada's Embraer ERJ-175
b767jetmec
The ERJ`s did come with leather seats but AC didn`t want them. Don`t know why though!
Boeing just does it better!
- Jaques Strappe
ERJ
Air Canada bought ERJ in order to get routes into S America and secondly to take advantage of alliance purchasing agreements. The CRJ 705 they bought were ordered by US Air who cancelled and ACE got the machines by default.
The CRJ 700/705/900 is a far better aircraft than previous100/200 models and will do OK in a market which is changing into high efficiency single isle from a more regional outlook.
The CRJ 100/200 were good aircraft in there time but they are essentially disposable and not "Heavy Metal" like a F28-100 or MD90.
Plugs or no plugs the type has evolved into a very effective aircraft.
- Jaques Strappe
Re: ERJ
KKboy wrote:Air Canada bought ERJ in order to get routes into S America and secondly.....................
Who told you that? I haven't heard anything more inaccurate in awhile. It amazes me how this stuff appears.
Which South American routes did AC acquire as a result of going with Embraer? It wasn't Sao Paulo, that came with Canadian. AC flies to Lima, Santiago and Buenos Aires, non of which are in Brazil.
b767jetmec
- Jaques Strappe
The ERJ will be a good jet for the AC fleet even though its more of a regional jet than a mainline aircraft, the speed and cargo capacity on these are crap. As for them being more comfortable than the new Jazz 705's thats wrong! The 705 has more room than most of the larger jets with a 36" seat pitch(leather seats)throughout the aircraft and once the video on demand systems are installed the 705 will be the aircraft of choice. I am looking forward to the ERJ's because it will alow AC to expand back to the way it was a few years ago.
- Jaques Strappe
The E190 is the same weight as a DC9, cruises at Mach .82 with a 2200 mile range and has a seat pitch of up to 38 inches with video entertainment in each seat back.natedog wrote:The ERJ will be a good jet for the AC fleet even though its more of a regional jet than a mainline aircraft, the speed and cargo capacity on these are crap. As for them being more comfortable than the new Jazz 705's thats wrong! The 705 has more room than most of the larger jets with a 36" seat pitch(leather seats)throughout the aircraft and once the video on demand systems are installed the 705 will be the aircraft of choice. I am looking forward to the ERJ's because it will alow AC to expand back to the way it was a few years ago.
Gurundu the Rat
Captn Flex
- Jaques Strappe
Gelbisch
Right now we have an E170 endorsement which covers the 170/175.
There will be a differences course but nobody seems to know if there will be a seperate 190 endorsement.
I would imagine that there would be because I had to do a differences course to get a 757 endorsement based on my 767 and except for weight and an extra fuel tank, the 75/76 are virtually identical but show as different type endorsements.
duplicate2
I see. Thanks for the info!
On a completely different topic of no relevance to this thread, just curious... how do upgrades work at AC? Is experience ever a factor, or is it strictly seniority? How about performance in the right seat? And also, I've heard mention a couple times of direct-entry captains... does that ever actually happen at AC? With the seniority system, I'm curious as to how that'd be possible.
And one last question...
WHEN ARE THEY GOING TO CALL???
Anyway, head out of the clouds... back to work tonight so I guess I ought to start thinking about the company I work for as opposed to the one I do not.
- Jaques Strappe
Gelbisch
The most recent direct entry Captains were hired back in 1995/1996 with the RJ. There was so much expansion going on, that at the time, left seat RJ was the second most junior position to be in anyway.
As for getting an upgrade, you can bid whatever you want and when your seniority allows it, you go there. So you could do your upgrade to the left seat on the A340 for example but you would be waiting a long time.
When you are able to hold your first command at Air Canada, you will do a command ground school, then the groundschool and simulator for the aircraft you bid. Then you will do traditional line indoc with a command initial line check.
Now you are qualified as an F/O to fly from the left seat with a right seat qualified Capt. You do this for about 50-75 hours. (There was another line check here but I think it has since been discontinued.) If they are happy with the way you are running your operation, you then go back to the simulator for some "Command Sims" which are basically lofts, summer and winter scenario and here they will try to put you into a corner with either weather, fuel, multiple failures or all of the above, just to see how you deal with pressure and prioritize tasks. (You will probably deviate from SOP or throw down the QRH at some point in this excercise.)
After that you will go back on the line for your "command final" check which is usually a 4 day cycle. At some point on day 3 or 4 if all goes well, you will be promoted and given the 4th stripe. The name on the flight plan will change to yours and Captain pay starts from that point.
If I remember correctly, it took about 3-4 months.
Just curious... how many Embraers are on-line now? And how many crews does AC usually put on an a/c? I heard rumours that the current and later courses could have some folks going RP, and was just wondering if a lot of the Embraer spots are filled 'til new a/c arrive?
Just thinking out loud...
- Jaques Strappe
Gelbish
I think there are 5 or 6 online now and the arrival rate will be rapid. The 190 arrives in November. Normally the airline is crewed to 7 crews per aircraft I believe but the Embraer will be 5.
As for RP spots coming up, that could be quite possible. Not due to the Embraer F/O spots being filled but because awarded Captain spots are leaving a vacuum on the larger aircraft F/O lists which has a downline effect thus requiring RPs.
Clear as mud?
Clear as mud?
I heard that the Air Canada ramp staff really dislikes the Embraer jets that Air Canada are recieving. Something about the cargo hold's height, and the fact that the cargo hold is a real bitch to load. They also say that the CRJ's cargo hold is a heck of a lot more easier to load, and the rampers prefer them over the Embraers.
Well put grammer boy!!! They can certainly give it but they certainly can't take it!grammar boy wrote:Uncalled for. You make yourself, and other WestJetters look like idiots when you pull crap like that. Something to think about next time you ponder hijacking a thread...WS739 wrote:Pretty shitty pay scales for those new F/O's!!!!!
http://www.airlinepilotcentral.com/content/view/102/11/
