I would like to know PM or public where to get the PDF file you need to update your MMC pilotlog software. Is it possible to get it before the beginning of the monthcalendar so it is displayed on my calendar
thanks
anybody using MCC pilotlog at AC?
Re: anybody using MCC pilotlog at AC?
Hi
Not with AC but the process is probably the same.
If you can't use the airline interface online and need the work with offline mode, you will need to save your published roster from AC portal in HTM format (right click / save as)
Then you just go to MCCpilotlog airline interface and select the offline mode. Browse for your saved HTM file and start import.
Works the same way for both historical data and planned roster.
