Westwind
Illya Kuryakin
Re: Westwind
Post by Illya Kuryakin »
Zaibatsu wrote: Thu Dec 14, 2017 2:56 pm
swordfish wrote: Thu Dec 14, 2017 2:43 pm "dirty little secret in Canada's North"....
The amount of shit on the wing of a plane - and it still climbs and flies just fine - will amaze you if you haven't flown "up North" very much. Did they teach you in surface contamination and airborne icing that "there's no such thing as a little ice"? They don't have a clue and are totally fucked up.
Not sure if you’re being sarcastic or not but it’s attitudes like that why we have planes crash. And there’s no point in having proper de icing facilities for fools who take off in FZRA.
Sarcastic or not, he has a valid point. Some will carry an amazing amount of crap, some will carry almost nothing at all. Since this knowledge comes at the cost, of sometimes getting it wrong (hello YPL Basler) we have adopted the clean wing concept
As far as waiting for the “ official”report, the LEAFS might have 2 Stanley Cups by then.
Speculation is a learning exercise. Let people learn.
Illya
bald seagull
Re: Westwind
Post by bald seagull »
https://aviation-safety.net/database/re ... 19941031-1
https://aviation-safety.net/database/re ... 19820113-0
https://aviation-safety.net/database/re ... 19890310-1
Re: Westwind
Well I have flown " up North " quite a lot and find that statement to be down right frightening.
A lot of low time pilots read these forums and those kinds of statements are setting a bad example to them.
Obviously you have not flown many different types of airplanes, the DC3 for instance will not tolerate any surface contamination such as frost, frozen snow or ice on the wings from being parked outside.
Ypilot
Re: Westwind
Post by Ypilot »
Cat Driver wrote: Thu Dec 14, 2017 5:12 pm
Who flies DC3?
:mrgreen:
With global warming, FZRA that was more a matter for guys down South, it is slowly becoming a problem for us. We need to adapt.
Gilles Hudicourt
Re: Westwind
Post by Gilles Hudicourt »
bald seagull wrote: Thu Dec 14, 2017 4:28 pm
https://aviation-safety.net/database/re ... 19851212-0
This comment is just in reply to a previous comment and does not mean I adhere to any theory or speculation on the cause of the crash
Last edited by Gilles Hudicourt on Thu Dec 14, 2017 6:29 pm, edited 2 times in total.
Jean-Pierre
Re: Westwind
Post by Jean-Pierre »
DC-3 and ATR not the kind of plane I would choose for Canadian northern flying if required to operate in icing condition.
montado
Re: Westwind
Post by montado »
YOU know you northern cowboy are right! It can be done!
https://m.youtube.com/watch?v=925MgqyU2 ... r_embedded
A video we can all laugh at right? Would you want to be deadheading on this flight?
All I can think of is that scene from the movie Annapolis where Tyrese Gibson puts one of the plebes in a body bag and says “I want you all to remember what that bag looks like with a body in it, because if you become officers this is where they're going to put your mistakes.”
That scene really sticks with me in the gravity of how precious life is.
Re: Westwind
One thing I really don't miss about flying up north is the de-icing issue. These turboprops have a lot of surface area that is considered critical and the operator has a 45 gallon drum of fluid that has to be heated a significant time in advance. Of course you call in advance to have it heated up based on the weather but the weather is good. Too bad you picked up some ice on the descent that remains after landing. And then the pilot is expected to go way up in some unsteady looking telescopic lift and spray the aircraft. And pilots with this equipment have it good compared to a lot of other pilots.
And what about the holdover time for your de-icing procedure which starts when to start applying fluid. And these communities have no type IV with extended holdover time. And it seems the de-icing rules get more complicated every year. Have recently read about only 90% holdover time if the flaps are extended during taxi, type IV required for active frost, complicated holdover tables that don't always apply to said operation, snowfall rate versus visibility tables, etc, etc.
Then you are dispatched to short strips with max payload for a landing with no airframe ice but if you have even a little bit of ice left on your icing indicator(and the ice never seems to sublimate off of it), you are not legally allowed to land with your payload because you are supposed to use much higher approach speeds and your legal performance requirements don't allow it.
Yet thousands of flights get done year after year but you have to be careful. I'll stick to the de-icing bays now.
Re: Westwind
While all the above are icing related accidents, there are significant differences. Here is an ATR accident that could have some closer alignment to what people are speculating about although the type of contamination could be different. Of note, this aircraft got airborne and was climbing until the flaps were retracted. Something to think about from an aerodynamic interest point of view.
https://reports.aviation-safety.net/201 ... VP-BYZ.pdf
ChrisEvans
Re: Westwind
Post by ChrisEvans »
Photos of the crash show flaps are still set at 15 degrees.
Re: Westwind
Who flies DC3?
:mrgreen:
There was a time when the DC3 was the most used airplane of its type and arguably one of the best designed airplanes ever built.
Even though it has been replaced by more modern turbine airplane it s still in use in a few places.
For instance Borek chose the Basler conversion of the DC3 for their work in Antartica, probably the most demanding difficult place on earth to fly.
And of course I am biased because I flew them for over five thousand hours most of it on wheel ski's off airport in the far north and the Arctic.
It is a true pilots airplane.
Re: Westwind
Forgive a dumb question.
How is it jet aircraft can takeoff in FZRA?
(Not saying that's the cause here)
swordfish
Re: Westwind
Post by swordfish »
Ziabatsu, Not sure if you’re being sarcastic or not but it’s attitudes like that why we have planes crash. And there’s no point in having proper de icing facilities for fools who take off in FZRA.
Your unsubstantiated statement is an insult to the intelligence, experience, and complex considerations pilots without anti-icing facilities carefully consider with their experience with the aircraft's performance and characteristics in these conditions. If you are not experienced in living and working in Canada's remote North for a long period of time, there is little point on commenting on things you know nothing about.
schnitzel2k3
Re: Westwind
Post by schnitzel2k3 »
Last I checked - Fond du Lac, Wollaston, and U City lack deicing facilities and are serviced daily in all but the lowest weather, in all seasons thanks to the RNAVs.
Now its been 4 years since I've flown in that neck of the woods so things may have changed, but I don't see the chiefs pitching in for ice trucks. Even the mines had minimal deicing support. God forbid you had to ask for a spray. That was the mentality.
Glad everyone made it out. Pilots may not make it out with their licenses on this one if it's chalked up to ice and PDM.
Stay safe everyone....
S.
swordfish
Re: Westwind
Post by swordfish »
Cat Driver, ...Obviously you have not flown many different types of airplanes, the DC3 for instance will not tolerate any surface contamination such as frost, frozen snow or ice on the wings from being parked outside.
I have 3200 hours on DC3 out of a Yellowknife base, and another 20,800 hours on many other types including Saunders, Metro, Jetstream, Beech 18, Conquest, Aztecs, 99s, King Airs of all flavours, and Beech 1900....for 44 years.
I have flown to every community and dew-line site in the North except Grise Fiord, and stayed in dozens of them overnight, or for days on end.
I am certainly qualified to say that it's complete bullshit that "there is no such thing as a little ice".
J31
Re: Westwind
Post by J31 »
rookiepilot wrote: Thu Dec 14, 2017 8:40 pm Forgive a dumb question.
Type 4 fluids have holdover times for freezing rain.
Re: Westwind
It's a bit of a double edged sword. On one hand it is great that people get trained / "indoctrinated" that any ice is bad, to avoid accidents and unsafe flights. On the other hand, it stops all further research and testing to figure out how much ice is actually too much.
It's silly sometimes. Light snow that is not sticking to the airplane, and a whole fleet of jets gets deiced. Because it is SOP I guess? The "turboprop guys" that are taxiing by the deicing bay get a bad name then because they are "unsafe". No they're not.
Eric Janson
Re: Westwind
Post by Eric Janson »
J31 wrote: Thu Dec 14, 2017 9:27 pm
Type 4 fluids are approved for use in Light freezing rain - operations in freezing rain are not approved at my airline and there is no holdover time published.
In reality the short time between the start of de-icing and the expiry of the holdover time makes it almost impossible to get sprayed and airborne.
av8ts
Re: Westwind
Post by av8ts »
It’s not just up North. There is a Dash operator out East that operates into airports with deice trucks that have type 1 and 4 yet they will not spray to remove ice on the wings from the previous flight. Hey, we flew in with it on, we must be able to fly out
Re: Westwind
ChrisEvans wrote: Thu Dec 14, 2017 7:53 pm
You might be looking at the wrong photos.
https://cdni.rt.com/files/oldfiles/news ... men.si.jpg
My advice still stands. If somehow caught in a situation like this, retract flaps cautiously.
"At 01:34:00 at height 640 ft and speed of 139 kt the flaps retraction was started. At 01:34:08 after the retraction had been completed, at 690 ft and at a speed of 150 kt uncommanded development of right bank started. At 01:34:10 the A/P was disengaged. The bank angle reached around 40° to the right within 3 s and after that was counteracted by ailerons and rudder deflection."
TG
Re: Westwind
Post by TG »
schnitzel2k3 wrote: Thu Dec 14, 2017 9:23 pm God forbid you had to ask for a spray. That was the mentality.
Well, this medieval's type of mentality has to change!
The same way we did about having sex with underage kids or goats. It is just not acceptable any more.
In civilized world that is :mrgreen:
schnitzel2k3
Re: Westwind
The support was there at most of the mines and Stony, but good luck trying to use it. It was never prepped, so an hour later someone is there warming a cold truck, and taking nearly the entire holdover window to spray. And if someone misprayed you'd be sure to hear about the cost of the spray.
People talk about northern flying as the golden egg in your logbook but I feel it brought on complacency with operators which in turn pushed pilots to comply while getting creative, because if you didn't, Leeroy J. would and you'd hear about forever. We all have that innate hero gene that sometimes overrides common sense. Get home-itis is also a big factor on long days.
A lot of great experiences, many wonderful friends, but just as many head shaking moments too. I am content I no longer fly up north.
S.
Mick G
Re: Westwind
Post by Mick G »
ATR42-300 lists minimum take off distance at 3576 ft. for Basic.
http://www.atraircraft.com/products_app ... re2014.pdf
Runway at Fond-du-Lac Airport listed at 3805 ft.
Not a huge amount of room for error, overweight or add a little ice to the wing............just saying.
Maynard
Re: Westwind
Post by Maynard »
pelmet wrote: Fri Dec 15, 2017 2:28 am
Chris was stating that westwinds flaps are still set in the picture, meaning that the accident you brought up about retraction, has no validity to this accident.
Dave Hadfield
Re: Westwind
Post by Dave Hadfield »
It's Dryden all over again, without the deaths, but that's pure luck.
The GFA showed freezing rain across the area. That means warm air aloft. The aircraft descended through the warm air and landed. The wings were thus above freezing.
The METAR showed light snow and -9C. So the snow stuck until the wings chilled.
The de-ice capability of the airport is almost useless. So they probably didn't.
So they took off with snow that would not slide off the wings.
Of course all the above is void and wrong if they de-iced. But... any bets?
As for letting the investigation take its course, look at the Halifax A-320. It took over 2 years and the conclusion is... simplistic.
