FLYGTA Rumors
FLYGTA Rumors
So I have heard two rumors, and would like verification.
1) Did one of there ho's have an engine fire?
2) Are they going under? Been hearing they are planning on selling all their office shit, aircraft, parts inventory etc?
Re: FLYGTA Rumors
They shut down one engine immediately after takeoff and landed three minutes later, that much is in a CADOR, so no secret. Well done to the crew, from what I hear. As to the rest, no idea.
Re: FLYGTA Rumors
CADORs reference please.
Accident speculation:
Re: FLYGTA Rumors
Re: FLYGTA Rumors
Thanks Goshawk
Re: FLYGTA Rumors
photofly, the CADOR doesn't say engine was shutdown, it says there was an engine issue.
Re: FLYGTA Rumors
You're right!
Perhaps it wasn't shut down after all.
Re: FLYGTA Rumors
The engine was shut down. It was a blown turbo. I talked to the pilot involved
Re: FLYGTA Rumors
Why would you shut down the engine for a blown turbo? It still makes plenty of power, somewhere around 70% I believe.
Re: FLYGTA Rumors
I mean, why did they even need to RTB? With 71.2% power available they should have completed the flight, obviously.goingnowherefast wrote: ↑Fri Feb 02, 2018 6:19 pm Why would you shut down the engine for a blown turbo? It still makes plenty of power, somewhere around 70% I believe.
Re: FLYGTA Rumors
It is a very difficult call. It might be something simple like aconnector broken, or it could be burning through the spar.
Better to get back on the ground ASAP and have it looked at.
Flight Safety’s recommendation is to shut down, as if it is going through the spar it apparently takes about 45 sec to burn through to failure.
Re: FLYGTA Rumors
True, but you will also -most likely- be loosing a ton of oil, which creates a lot of smoke. Not easy to determine at that point if it is a blown turbo or if your engine is on fire. If it happens just after take-off, probably with low time pilots as well, I'd probably would have shut it down as well.goingnowherefast wrote: ↑Fri Feb 02, 2018 6:19 pm Why would you shut down the engine for a blown turbo? It still makes plenty of power, somewhere around 70% I believe.
From an economic's point of view: shutting down might aslo save the engine.
- rookiepilot
Re: FLYGTA Rumors
I actually know of at least one company that did exactly that. Including 2 take-offs. It was not a good dayphotofly wrote: ↑Sat Feb 03, 2018 7:45 amI mean, why did they even need to RTB? With 71.2% power available they should have completed the flight, obviously.goingnowherefast wrote: ↑Fri Feb 02, 2018 6:19 pm Why would you shut down the engine for a blown turbo? It still makes plenty of power, somewhere around 70% I believe.
Re: FLYGTA Rumors
The smoke/oil would be going out the exhaust and not visible from the cockpit. Definitely take it back to land at the nearest airport, but it is a Navajo, not the best single engine reputation. If it's still making power and not on fire, leave it running.
Also, it's not going to burn through the spar in 45 seconds, there's a firewall in the way. Plus the whole engine compartment is mounted above the wing. You might toast some stuff in the wing lockers AFTER the firewall is compromised, but that's it.
I will also say this. They were two low time pilots in a Navajo, experiencing an abnormal scenario, with or without visible troubling signs from an engine. Whatever they did clearly worked as everybody is alive and well with the airplane still intact.
Re: FLYGTA Rumors
How many arm chair quarterbacks remember the NavAir Navajo on departure out of Comox? A blown gasket spewed oil on the turbo and the crew turned back to land. They did not make it.
Re: FLYGTA Rumors
You do not know about that of which you speak.
I
1. Not withstanding the need to get back on the ground ASAP, a Navajo flies fine on one engine...if you have a properly trained and competent pilot.
2.if the turbo charger become disconnected it is like a super blowtorch, wiser people than you say 45 seconds. Dont wait around to find out if they are correct, even if you and others need to read about an accident to learn
3. Lastly, there is avery visable grating you can see right into the turbo from the cockpit. Your claim that it is not going to be visible makes me wonder if you have ever flown a ho, as Indont know a ho pilot who was not mesmerized by the glowing turbo at night.
Btw...some of those wing lockers are nacelle tanks...just sayin...
Anytype of engine issue, get it back on the ground. Diagnosising and engine issue while flying is foolish. If even a hint of fire, shut it down, and get the fuel off to that engine..
Free advice..take it for what its worth....or wait until you can get a fresh accident if that is the only way you learn
Re: FLYGTA Rumors
I have to agree 100% with Trey Kule on this one. I am graduate of Flight Safety's Navajo pilot course and I am an AME with years working on the "Ho". I have seen the effects in pictures, first hand, and actually talked with the lead Navajo production engineer from Piper about this very subject. If you suspect any turbo or exhaust or fuel or fire issues land ASAP. If you fly a navajo please heed this advise. Hopefully it will end like this event did. Many have not. Please all Navajo pilots have a close look through those access grates on the nacelles on walk around at the Turbo and all visible connections for anything out of the ordinary.
- rookiepilot
Re: FLYGTA Rumors
Trusting you're not serious? Complete the flight?photofly wrote: ↑Sat Feb 03, 2018 7:45 amI mean, why did they even need to RTB? With 71.2% power available they should have completed the flight, obviously.goingnowherefast wrote: ↑Fri Feb 02, 2018 6:19 pm Why would you shut down the engine for a blown turbo? It still makes plenty of power, somewhere around 70% I believe.
Likely sarcasm but on this site one never knows. Sure that's been done, too.
