FLYGTA Rumors
FltLvl190
FLYGTA Rumors
Post by FltLvl190 »
So I have heard two rumors, and would like verification.
1) Did one of there ho's have an engine fire?
2) Are they going under? Been hearing they are planning on selling all their office shit, aircraft, parts inventory etc?
Re: FLYGTA Rumors
They shut down one engine immediately after takeoff and landed three minutes later, that much is in a CADOR, so no secret. Well done to the crew, from what I hear. As to the rest, no idea.
trey kule
Re: FLYGTA Rumors
Post by trey kule »
CADORs reference please.
Accident speculation:
Goshawk
Re: FLYGTA Rumors
Post by Goshawk »
trey kule wrote: Tue Jan 30, 2018 5:12 pm CADORs reference please.
CADORS Number: 2018O0215
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/2/c ... d2018O0215
trey kule
Re: FLYGTA Rumors
Post by trey kule »
Thanks Goshawk
kgams
Re: FLYGTA Rumors
Post by kgams »
photofly wrote: Tue Jan 30, 2018 5:04 pm They shut down one engine immediately after takeoff and landed three minutes later, that much is in a CADOR, so no secret. Well done to the crew, from what I hear. As to the rest, no idea.
photofly, the CADOR doesn't say engine was shutdown, it says there was an engine issue.
Re: FLYGTA Rumors
You're right!
Perhaps it wasn't shut down after all.
172_Captain
Re: FLYGTA Rumors
Post by 172_Captain »
The engine was shut down. It was a blown turbo. I talked to the pilot involved
goingnowherefast
Re: FLYGTA Rumors
Post by goingnowherefast »
Why would you shut down the engine for a blown turbo? It still makes plenty of power, somewhere around 70% I believe.
anofly
Re: FLYGTA Rumors
Post by anofly »
i guess it depends where all the heat is going...
Re: FLYGTA Rumors
goingnowherefast wrote: Fri Feb 02, 2018 6:19 pm Why would you shut down the engine for a blown turbo? It still makes plenty of power, somewhere around 70% I believe.
I mean, why did they even need to RTB? With 71.2% power available they should have completed the flight, obviously.
trey kule
Re: FLYGTA Rumors
Post by trey kule »
It is a very difficult call. It might be something simple like aconnector broken, or it could be burning through the spar.
Better to get back on the ground ASAP and have it looked at.
Flight Safety’s recommendation is to shut down, as if it is going through the spar it apparently takes about 45 sec to burn through to failure.
Re: FLYGTA Rumors
True, but you will also -most likely- be loosing a ton of oil, which creates a lot of smoke. Not easy to determine at that point if it is a blown turbo or if your engine is on fire. If it happens just after take-off, probably with low time pilots as well, I'd probably would have shut it down as well.
From an economic's point of view: shutting down might aslo save the engine.
Re: FLYGTA Rumors
FltLvl190 wrote: Tue Jan 30, 2018 5:02 pm So I have heard two rumors, and would like verification.
PDW will buy them out.
Re: FLYGTA Rumors
photofly wrote: Sat Feb 03, 2018 7:45 am
I actually know of at least one company that did exactly that. Including 2 take-offs. It was not a good day :roll:
goingnowherefast
Re: FLYGTA Rumors
The smoke/oil would be going out the exhaust and not visible from the cockpit. Definitely take it back to land at the nearest airport, but it is a Navajo, not the best single engine reputation. If it's still making power and not on fire, leave it running.
Also, it's not going to burn through the spar in 45 seconds, there's a firewall in the way. Plus the whole engine compartment is mounted above the wing. You might toast some stuff in the wing lockers AFTER the firewall is compromised, but that's it.
I will also say this. They were two low time pilots in a Navajo, experiencing an abnormal scenario, with or without visible troubling signs from an engine. Whatever they did clearly worked as everybody is alive and well with the airplane still intact.
oldtimer
Re: FLYGTA Rumors
Post by oldtimer »
How many arm chair quarterbacks remember the NavAir Navajo on departure out of Comox? A blown gasket spewed oil on the turbo and the crew turned back to land. They did not make it.
trey kule
Re: FLYGTA Rumors
Post by trey kule »
You do not know about that of which you speak.
I
1. Not withstanding the need to get back on the ground ASAP, a Navajo flies fine on one engine...if you have a properly trained and competent pilot.
2.if the turbo charger become disconnected it is like a super blowtorch, wiser people than you say 45 seconds. Dont wait around to find out if they are correct, even if you and others need to read about an accident to learn
3. Lastly, there is avery visable grating you can see right into the turbo from the cockpit. Your claim that it is not going to be visible makes me wonder if you have ever flown a ho, as Indont know a ho pilot who was not mesmerized by the glowing turbo at night.
Btw...some of those wing lockers are nacelle tanks...just sayin...
Anytype of engine issue, get it back on the ground. Diagnosising and engine issue while flying is foolish. If even a hint of fire, shut it down, and get the fuel off to that engine..
Free advice..take it for what its worth....or wait until you can get a fresh accident if that is the only way you learn
Addicted4life
Re: FLYGTA Rumors
Post by Addicted4life »
I have to agree 100% with Trey Kule on this one. I am graduate of Flight Safety's Navajo pilot course and I am an AME with years working on the "Ho". I have seen the effects in pictures, first hand, and actually talked with the lead Navajo production engineer from Piper about this very subject. If you suspect any turbo or exhaust or fuel or fire issues land ASAP. If you fly a navajo please heed this advise. Hopefully it will end like this event did. Many have not. Please all Navajo pilots have a close look through those access grates on the nacelles on walk around at the Turbo and all visible connections for anything out of the ordinary.
Re: FLYGTA Rumors
Trusting you're not serious? Complete the flight?
Likely sarcasm but on this site one never knows. Sure that's been done, too. :roll:
Re: FLYGTA Rumors
Post by 2112 »
digits_ wrote: Sat Feb 03, 2018 10:09 am I actually know of at least one company that did exactly that. Including 2 take-offs. It was not a good day
I think I know that place too, did the same pilot later crash said plane while attempting a T/O on empty outboards? Guessing it's the same guy that tried to get me to fly with a known oil leak? If someone want's you to fly with a blown turbo or oil pissing out of a 540 onto the turbo then it's time to seek new employment.
goingnowherefast
Re: FLYGTA Rumors
rookiepilot wrote: Sat Feb 03, 2018 4:25 pm
Quite certain that was sarcasm. Any Navajo with an engine problem belongs on the ground ASAP.
Trey, have you ever flown a Navajo at gross on a hot day? Also, that grate looks at the exhaust manifold, before the turbo. During the day, it's pretty dark in there and you won't see anything through the grate anyway.
You say don't diagnose the engine problem in the air, yet you are diagnosing a turbo plumbing failure and shutting off an engine. As far as you can likely tell, it just isn't making proper manifold pressure. Now yes, if there is any hint of a fire, follow the checklist and shut it off.
Re: FLYGTA Rumors
No, no, I’m quite serious. I ran the equations and calculate they had 71.2234% of rated power available.Plenty to complete the flight.
trey kule
Re: FLYGTA Rumors
Post by trey kule »
Yes.
Though I expect you are actually referring to high density altitude take offs, and not just hot days. And yes to that as well.
As to the assertion I diagnose in the air, I believe that is what is referred to as a logical fallacy.
I think what we need to do here is have a new accident so everyone can respectfully speculate and, of course learn. No sense in learning from the accident history of the type from the past accidents...that’s no fun at all.
Btw. I ran Photo’s numbers again , and I can confirm them correct. So to summarize the wisdom of the crowd , an engine failure on a ho is a non event. No need to return to land, and the problem can be looked at during the next maintenance event. As to fire...,heck,,,fires are for barbeques, exhaust connections never fail, and after 1 hour of riding around in the right seat of a navajo one can learn to accurately determine the severity of the situation..not that it matters. No need to land.
Btw. Kudos to the crew that ignored the wisdom here and got the little rascal back on the ground. Regardless of what the problem was...
kgams
Re: FLYGTA Rumors
Post by kgams »
The fact anyone would consider continuing a flight with an engine issue rather than return to land on the perfectly good runway directly behind you boggles my mind.
