Multi-IFR license question
Moderators: ahramin, sky's the limit, sepia, Sulako, Right Seat Captain, lilfssister, North Shore
Message
Author
ahmed905
#1 Post by ahmed905 » Wed Feb 07, 2018 10:05 am
Hey guys,
Quick question for you. I am considering Confederation College for the Aviation program, which only provides me with a CPL and group 3 instrument rating. My question is, when I go to do my multi-ifr training elsewhere, do I just simply get my multi-engine rating, and then combine it and do a flight test to get my group 1 instrument rating, or do I need to do my multi rating, and then do another "multi-ifr" training program?
Please let me know If I need to clarify further.
Thanks!
flyingcanuck
Re: Multi-IFR license question
#2 Post by flyingcanuck » Wed Feb 07, 2018 11:12 am
Youre correct in the first statement, all you will need is a multi rating and then upgrade, so a few flights to get used to the plane and that's it!
Blackdog0301
#3 Post by Blackdog0301 » Wed Feb 07, 2018 11:44 am
If you went and did your group 3, and then decided to upgrade to a group 1, the the IFR portion should be nothing but a review. Remember, however, that you will have the added challenge of flying at least one approach and landing with a “failed” engine.
C.W.E.
#4 Post by C.W.E. » Wed Feb 07, 2018 6:37 pm
What is so difficult about flying an approach and landing with a simulated engine failure?
The question is meant to be genuine because I don't understand how it is a challenge.
flyingcanuck
#5 Post by flyingcanuck » Wed Feb 07, 2018 6:39 pm
It's not much more difficult, especially if you just did your ME rating before that... Just some added yaw and different power settings really.
AuxBatOn
#6 Post by AuxBatOn » Wed Feb 07, 2018 7:32 pm
Quick question for the ME pilots of Avcanada: with an an engine failed on a multi-engine aircraft (non-centerline thrust) and the ball centered, are you flying coordinated?
Going for the deck at corner
#7 Post by photofly » Wed Feb 07, 2018 8:20 pm
Why limit yourself to multi-engine airplanes?
If you're in *any* airplane, with the ball centred, does that mean you must be in co-ordinated flight?
“This isn’t flying, it’s falling. With style.”
youhavecontrol
#8 Post by youhavecontrol » Wed Feb 07, 2018 9:17 pm
Depending on the aircraft, co-ordinated flight with a failed engine requires you to bank the aircraft 3-5 degrees towards the operating engine, while keeping the turn co-ordinator ball half it's width (often centered on either the right or left black line) towards the good engine. This is done to counteract the slipping tendency caused by the operative engine. Again, it depend on the aircraft, but I believe the general rule can be applied to most light twins.
AuxBatOn
#9 Post by AuxBatOn » Wed Feb 07, 2018 9:52 pm
This is just gouge. The right answer is that it is not coordinated. There are some certification requirements that talk about up to 5 degrees of bank to define Vmca (which are determined through flight test). It is true of any assymetric configuration.
The "sideslip" indicator is really a sideforce indicator: it indicates how balanced the lateral forces are (for a well calibrated "sideslip" indicator, ball between the lines means no lateral force and, in a symmetrical configuration, no sideslip. Since no airplane is truly symmetrical (even single props will have unballanced airflow over its surfaces, depending on the side, the "sideslip" indicator never really indicate true coordinated flight.
youhavecontrol
#10 Post by youhavecontrol » Wed Feb 07, 2018 10:23 pm
...so your question was just a quiz.
Steve Pomroy
#11 Post by Steve Pomroy » Thu Feb 08, 2018 1:15 pm
No.
Not usually.
For anyone who's interested, there's more detail here: http://www.flightwriter.com/2012/09/step-on-ball.html.
Steve
http://www.skywriters.aero
C.W.E.
#12 Post by C.W.E. » Thu Feb 08, 2018 6:23 pm
How about sailplanes.
AuxBatOn
#13 Post by AuxBatOn » Thu Feb 08, 2018 6:54 pm
If they are not symmetrical (heavy side, assymetrical drag, etc) same thing applies. If you are using a string to coordinate your turn then a centered string means no sideslip but may not mean a centered ball..
C.W.E.
#14 Post by C.W.E. » Thu Feb 08, 2018 7:16 pm
Does a ball work in a gyroplane?
If not why not?
AuxBatOn
#15 Post by AuxBatOn » Thu Feb 08, 2018 7:18 pm
It will indicate sideforce, just like any other "sideslip" indicator.
C.W.E.
#16 Post by C.W.E. » Thu Feb 08, 2018 7:25 pm
Do pusher thrust gyroplanes have a turn co-ordinator in them to use when turning?
Do tractor trust gyroplanes have turn co-ordinators in them to use when turning?
C.W.E.
#17 Post by C.W.E. » Thu Feb 08, 2018 7:32 pm
Aside from the subject of determining balanced turns of all the flying machines I have ever flown the gyroplane was the most manoeuvrable and fun to fly.
And getting the Commercial Gyroplane Pilot License was the most difficult, exam and flight test wise, not to mention expensive.
AuxBatOn
#18 Post by AuxBatOn » Thu Feb 08, 2018 7:42 pm
For your gyroplane question, I am going by scientific intuition as I have not studied nor flown Gyroplanes.
I would say that, in practical terms, you do not need one as there are no surfaces to induce sideslip in a turn, the rotor is not driven and the stream from the prop and the airflow will make the airframe weathervane, coordinating your turns for you. The rudder only really acts as a mean to induce sideslip vs correcting for sideslip.
C.W.E.
#19 Post by C.W.E. » Thu Feb 08, 2018 7:59 pm
You are close , the gyroplane uses a yaw string to co-ordinate the turn.
However its flight characteristics are rather complex and vary from machine to machine mostly due to the thrust line in the vertical plane of the machine, the higher the thrust line the more unstable the machine can be depending on use of power in a given manoeuvre.
They do not stall but they can bunt over and that is always fatal.
Anyhow for pure fun they are hard to beat. :mrgreen:
C.W.E.
#20 Post by C.W.E. » Thu Feb 08, 2018 8:26 pm
AuxBATON, if you want some interesting reading research the fatality record of the RAF2000 a high thrustline pusher gyroplane with no horizontal stabiliser.
The designers of the gyro refused to add a H.S. to their product even after numerous bunt over fatalities.
Panama Jack
#21 Post by Panama Jack » Fri Feb 09, 2018 1:53 am
Each and every category of aircraft has its own characteristics. Each and every category of aircraft has its Achilles Heal.
-President Ronald Reagan
clairvoyant
#22 Post by clairvoyant » Fri Feb 09, 2018 8:48 am
Speaking about aircraft characteristics/curiosity, how hard is it to transition from Seminole to Seneca (aside from the Johnson bar flap to the electric flap)?
Thank you, folks...
