1500 on flyover is same distance as 1000 ft mid downwindat least 500 ft above circuit altitude
Can you see the windsock?
Re: Can you see the windsock?
Even less, I think, unless you fly very tight circuits.
@CYRO
Not sure if you're referring to me or you, but I like this kind of problem, so here goes. (Since we're dealing with a small area, let's assume the world is flat, to avoid spherical geometry.)
Flying almost directly over the windsock at 1,500 ft AGL, 200 ft offset to the side (so that you can look down at it) = sqrt(1,500² + 200²) = 1,513 ft slant distance
Flying abeam the windsock at 1,000 ft AGL on a downwind 1/2 statute mile parallel to the runway = sqrt(1,000² + 2,640²) = 2,823 ft slant distance
So you're actually a lot closer when you're overflying the windsock at 1,500 ft (my "even less" was understatement). The question is whether the regs are allowing for the horizontal distance in addition to vertical (I seriously doubt they thought it through that far).
@CYRO
They probably just printed the necessary .. saved us the details ... to save paper back then (no luxury of PDAs .. limit-less gigs)I seriously doubt they thought it through that far
2813 ft slant ?
That's likely why ... flyover was trained 2000ft at our airport ..
It would still be odd to only require the sock be visible from 1000 ft above the sock as both situations are more than 1000 ft from the sock.
