Ban of Handheld Lasers within 10k of airports
B208
Re: Ban of Handheld Lasers within 10k of airports
Post by B208 »
photofly wrote: Thu Jul 05, 2018 5:45 am
B208 wrote: Thu Jul 05, 2018 5:37 am
photofly wrote: Thu Jul 05, 2018 3:51 am Permanent eye damage is caused by (as far as I know) retinal heating, which is caused by a high power per unit area of the direct beam hitting your eye.
Your retina can’t be damaged by laser light reflected off objects close to you: once the beam hits a rough object it spreads out and the power delivered to the area of your cornea (which is focused onto the retina) is very small.
Don't forget wavelength. A sufficiently short wavelength, (near the U.V. end of the spectrum), will break the chemical bonds in the molecules of the rods and cones of the retina. This applies to both direct and reflected light.
Ultraviolet light does cause retinal damage, which is why you should wear only good quality UV filtering sunglasses, but laser pointers being nearly monochromatic (which is the point of a laser after all) produce radiation that's visible light and not ultraviolet. So I don't think that is a danger in circumstances of lasers being shone at aircraft.
No arguments about laser pointers being a virtual non-issue for eye damage. I was speaking more about the home-brewed versions (i.e. the ones built from scavenged CD burners etc....).
goldeneagle
Post by goldeneagle »
B208 wrote: Sun Jul 01, 2018 11:18 am All of the laser pointers on the market today are low power and red.
Green laser pointers are very common. 5mw glp on ebay runs 10 bucks with free shipping. We use them all the time at astronomy events, great for pointing out constellations and such for folks that dont know their way around the sky.
Agreed, you'd just see the red/green dot on the object the laser is pointed at. I'm not too sure what you are getting at in a "blind the pilot" scenario though? I don't think the glass from the windshield reflects the laser in sufficient amount to have any effect on the possible damage/discomfort the pilot experiences.
digits_ wrote: Thu Jul 05, 2018 6:07 pm I'm not too sure what you are getting at in a "blind the pilot" scenario though? I don't think the glass from the windshield reflects the laser in sufficient amount to have any effect on the possible damage/discomfort the pilot experiences.
I don't know either; it wasn't me that used that phrase.
B208
Post by B208 »
goldeneagle wrote: Thu Jul 05, 2018 5:35 pm
I stand corrected.
AirFrame
Post by AirFrame »
Someone will correct me if i'm wrong, but I was under the impression that the "blinding" of the pilot was more due to the sudden intense light coming in, not because of any physiological damage occuring (ie. laser burning out rods/cones in the eye). Not much different than someone sitting next to you in the cockpit suddenly shining an LED flashlight in your face. I'm not completely convinced that a common red, green, blue laser that can be bought for $100 or less would have good enough optics to keep a beam collimated well enough to maintain its damage-causing potential up to flight altitudes.
Outlaw58
Post by Outlaw58 »
Jumping in without reading the whole thread here so apologies if my contribution is minimal.
I was hit by a green laser last evening and inadvertently stared straight into the beam. Take-off phase of flight initial climb below 1000, PF with autopilot on. Let me just say it was VERY incommoding although the discomfort only lasted for a few seconds. After that I had a dark blind spot that while it did not impair my vision enough to abort the flight, it did persist while steadily fading until early this morning. I was able to see a doctor and ophtalmologist tech this morning which confirmed there was no damage to the retina to my relief.
Lessons learned from that incident:
1) While I wasn't injured, I believe Lasers CAN physically harm a pilot's vision
2) There are people out there that maliciously purchase powerful lasers and intentionally target aircrafts (I was naively believing to this point that incidents were of the inadvertent or negligent kind)
3) the discomfort and disorientation it causes definitely can cause a serious accident
4) I am seriously pissed and would very much like to find a laser user so I can inflict a large amount of physical pain to that person. (Well, I would settle with screaming very loudly at that person)
58
Outlaw58 wrote: Fri Jul 06, 2018 5:11 pm
Sorry to hear that happened to you, but why did this event make you believe they wanted to intentionally blind you?
Outlaw58
Post by Outlaw58 »
digits_ wrote: Fri Jul 06, 2018 5:45 pm
I and 1 other crew member saw the origin of the beam (reported btw). From the way the laser was used, our aircraft was clearly the target of the user. There was not a iota of a doubt amongst the crew.
58
AirFrame
Post by AirFrame »
Outlaw58 wrote: Fri Jul 06, 2018 8:13 pmI and 1 other crew member saw the origin of the beam (reported btw). From the way the laser was used, our aircraft was clearly the target of the user. There was not a iota of a doubt amongst the crew.
The question asked was "how do you know they were trying to blind you?" I think we can all agree that they were intentionally trying to target the airplane with the laser, especially if it stayed with the plane for more than a fraction of a second. What's not clear is whether any malicious intent was there... That the holder of the laser wanted to harm someone with it.
Do you think if your co-pilot had reached over unexpectedly and turned on one of those high-brightness LED flashlights right in your face, that the effect would have been any different? Apart from you being able to immediately reach over and pummel him in person, that is? I still think that the effect of the laser at altitude is more of a "flash blindness" due to the intensity, and not a risk of "burning the retina" like one would get by accidentally looking into a laser in a laboratory. Temporary blindness due to sensory overload, but not permanent due to physical damage.
The end result could be the same, temporary blindness leading to loss of control and a crash, so the point may be moot, but i'm hoping to better understand the long-term effect in the event one lives through it. Good to hear you'll recover!
Outlaw58
Post by Outlaw58 »
AirFrame wrote: Sat Jul 07, 2018 8:39 am
It's one of those you had to be there thing. What I didn't mention was that it was a military crew with operational experience. All I can offer is that we know from experience what being engaged feels like and that there wasn't any doubt amongst the crew that it was what happened.
Before it happened to me I didn't think that lasers were more than an annoyance with minimal odds of causing major damage. Not so sure anymore.
I don't know if it can damage a retina. From my experience, I think it's a possibility and I also think that no one in the aviation community should have to find out from experience before something is done about it.
Just because one doesn't like that trucks driving by their house are noisy and dusty, one shouldn't start trying to shoot the driver in the face with a BB gun!
58
B208
Post by B208 »
Outlaw58 wrote: Sun Jul 08, 2018 5:15 am It's one of those you had to be there thing. What I didn't mention was that it was a military crew with operational experience. All
58
Where do you fly out of?
