BC medevac contract
BC medevac contract
Who are the front runners for the new contract?
Does CarsonAir have a lock on it?
leftoftrack
Re: BC medevac contract
is rhe fling wing side open? Helijet might have trouble retaining it. are their any other operators bidding on it?
medi-whacked
I heard that some company from the Yukon is bidding on it, they do medevacs up north.
Cessna 180
Can-West bid on the contract from what I understand.
Alkan Air quite possibly , assuming Northern Thunderbird will bid as well.medi-whacked wrote: ↑Fri Jul 27, 2018 10:48 pmI heard that some company from the Yukon is bidding on it, they do medevacs up north.
Cessna 180
It will also likely depend on if they want an ALS service like Alberta or a BLS service like they currently have, or like Manitoba. As it is, they call Alberta when they have super critical patients or NICU/PICU trips (sometimes).
When I flew Medevacs for BCAS, the paramedics were critical care rated, which was a step above ALS. They also had transport planes the PCP rated guys would work, but the majority of the fleet was critical care. You’re likely getting calls because BCAS resources were tapped, or an Alberta based plane could respond quicker.
Cessna 180
I wasn't aware of that! Thanks.Go Guns wrote: ↑Sun Jul 29, 2018 8:02 am When I flew Medevacs for BCAS, the paramedics were critical care rated, which was a step above ALS. They also had transport planes the PCP rated guys would work, but the majority of the fleet was critical care. You’re likely getting calls because BCAS resources were tapped, or an Alberta based plane could respond quicker.
