Good Hands n’ Feet vs. Operational Experience
youhavecontrol
Re: Good Hands n’ Feet vs. Operational Experience
Post by youhavecontrol »
JetSetter87 wrote: Wed Aug 15, 2018 6:33 pm Instructors don't do much stick flying. The student does. Ho captain any day...
We demonstrate maneuvers constantly that the students then practice as we watch. They have to be perfect. We also have to take control frequently when things go too far for the student to correct on their own. That takes quick thinking and near perfect control responses. I can demonstrate a power-off 180 from the right or left and make my spot within 10 feet in any wind condition the aircraft is certified to fly in. I can look out my window at the clouds and predict what airspeed we are flying at within 5 knots, and if the student forgot to raise his flaps or not, and if he's using too much or too little rudder. If that's not stick flying, I don't know what you're talking about.
That being said... why not both? Controlled flight into terrain is a thing that stick flying can't save.
Zaibatsu
Post by Zaibatsu »
This is like one of those dumb facebook polls.
“Which would you rather wipe your ass with?”
Choose one:
[Steel Wool] or [Sandpaper]?
Normally I’d say sandpaper because if it’s higher than 400 grit it would be easier on my rectum, but steel wool is more absorbant so I won’t just be pushing shit around everywhere. Truth is I just want TP. Even one ply is better, or paper towel, or napkins, or socks.
You’re rarely ever going to have a 900 hour Navajo pilot with bad hands and feet. No or very basic autopilot. Short and frequent legs. Turbulence. Crappy strips. Bad approaches. No beta or reverse. Substandard equipment.
A flight instructor isn’t going to have any experience except for VFR Flying in simple aircraft.
So supposun this is like the worse Navajo pilot in the world. Only flies when it’s calm, can’t handle a crosswind, can’t fly a stable approach, et cetera.
Well, I’d choose the Navajo pilot. Obviously his experience and decision making have kept him alive. Compare that to the flight instructor who’s lack of experience in all but the best weather will have them painted into a corner and the aircraft doomed minutes or even hours before it actually crashes.
Decision making always trumps hands and feet. Sometimes that decision is to not fly at all.
But the reports of the death of hands and feet are greatly exaggerated.
youhavecontrol
Zaibatsu wrote: Thu Aug 16, 2018 11:25 am
Not saying I completely disagree with all you wrote, but this part is crap. Every tried to fly actual IMC with a student? We do it regularly and it's a lot of work when you have a weaker student. You not only need to know your procedures, but you have to fix his and explain why at the same time. The work-load can be quite high.
Rockie
Post by Rockie »
B208 wrote: Thu Aug 16, 2018 9:55 am I have written rubrics that evaluate both motor and cognitive skills in great detail.
Engineer right?
Even in a controlled simulator environment no two exercises are the same. There are always differences, some subtle, some not so subtle, that change the grading parameters. Not least of these are human factors which play at least as much a role as technical ability and are ever changing, and then there are crew concept factors outside one individual's ability to control.
In an airplane it's even more of a wild card making disciplined, consistent grading different from one pilot's exercise to the next. The only way to bridge that gap is to use subjective judgement, which circles us back to the word "good".
Is "good" a level 3? What if a guy gets a 3 in difficult circumstances but the next guy gets a 4 in ideal circumstances? Who's better? If you say the guy with the 3 you're applying subjectivity which is the bane of experts like B208. If you say the guy with a 4 then you make no allowances for circumstances which is hardly an accurate assessment of ability.
The best pilots I've ever seen mixed good judgement in all circumstances with hand flying skills commensurate with the job. Lack either and you shouldn't be flying airplanes. There are people who boast about being the best stick (and maybe they are), but I would never get in an airplane with them because they utterly lack judgement. Conversely great judgement won't help you if you can't keep the airplane going where it's supposed to.
C.W.E.
Post by C.W.E. »
There is also another important factor that should be considered in this discussion.
We have listed hands and feet and experience and a few other things and I would like to add another one.
Luck.
That can play a large part between disaster and survival.
I carried a horseshoe in my flight bag and a rabbits foot in my pocket for my whole career and it would appear that it worked because I never damaged an aircraft fixed or rotary wing during the over half a century I flew them for a living.
Zaibatsu
Post by Zaibatsu »
youhavecontrol wrote: Thu Aug 16, 2018 11:33 am Every tried to fly actual IMC with a student? We do it regularly and it's a lot of work when you have a weaker student. You not only need to know your procedures, but you have to fix his and explain why at the same time. The work-load can be quite high.
Sounds easier than being a new Navajo or King Air captain who’s with a new FO with hardly any more experience than your student flying a much more complex aircraft into much worse conditions.
Actual IMC seems to be an instructor fixation. The plane doesn’t fly any different with respect to instruments. All it gains is a couple hours in a log book that means almost nothing in the real world getting your first IFR job. Thus, myself and most other instructors I know primarily taught IFR in VMC. Going into stuff like known icing or down to IFR minimums is best left for on the job training and line indoc on more capable aircraft.
C.W.E.
Post by C.W.E. »
That sounds like it would be a bit exciting, are you saying this from your own experience, is that safer than flying it by yourself??
FL007
Post by FL007 »
Flying imc on a nice smooth, non icing day is a little different than in solid imc, icing up, looking at your airspeed decrease and threading the needle in embedded cbs.
I don't know of a lot of trainers that are able to fly in known icing, or with weather radar, so 0 experience in those aspects is not a generalization.
HansDietrich
Post by HansDietrich »
What makes you think that a 900 hour Navajo captain does not have good hands and feet? I'd say the Navajo pilot would have more useful experience, flying operationally into small airports, more often than not with a basic auto pilot, IFR, etc. You don't need to teach slow flight, spins, spiral dives every day to develop what you call "good hands and feet". I think the skills you learn as a flight instructor are quite limited, IN REGARDS TO FLYING, but you do develop teaching methodology that can come in handy later in your career.
Das ist mir wurst...
C.W.E.
Post by C.W.E. »
I found the Navajo to be a poor IFR platform compared the the 400 series Cessnas, especially the 421 which was a delight to fly, nice and quiet and rock solid as an IFR platform.
valleyboy
Post by valleyboy »
Not sure where the 900 hours came from but in my experience a 900 hr ho captain has barely enough knowledge to get from a to b and instructors in this day and age are so low timed I can't believe they are allowed teach. In my humble opinion an instructor should not be allowed to start teaching until they have 1500 hours and detailed courses how to instruct. A "HO" captain should hold an ATP but it's the sign of the times and pilots with a new ATP think they should be in the money seat of a wide body --- time marches on, maybe full automation is the solution. :smt040 I'm not saying this generation of pilots are less capable. What I am saying the present situation is putting pilots into positions where they likely should not be for their experience level.
http://www.blackair.ca
MrTurbine
Post by MrTurbine »
mixturerich wrote: Wed Aug 15, 2018 5:25 pm What’s going to save your butt? 900hr flight instructor with super hands and feet? Or 900 Navajo captain who isn’t very coordinated, but experienced with storms, icing, wind shear, and crosswinds?
I’d pick a ho instructor.
I’ve trained some ho guys that shiver when they see some ice on the boots. I’ve trained some instructors that have terrible hands and feet. Experience is good, but at 900 hours, it means nothing to me. It’s all about attitude. And yes, if you don’t have good hands and feet, go find another job please.
Zaibatsu wrote: Thu Aug 16, 2018 5:04 pm
It is a world of difference for the student.
B208
Post by B208 »
Rockie wrote: Thu Aug 16, 2018 11:49 am
Engineer right?
Nope. You're thinking of Headley, (who extends a cordial invitation to come over to ..'s for a chat).
Rockie wrote: Thu Aug 16, 2018 11:49 am Even in a controlled simulator environment no two exercises are the same.
By this I assume that you mean no two instances of the same exercise are the same. The only thing that changes between iterations of a simulator ex are the pilot, (either a different pilot or a pilot that has hopefully learned something from the previous iteration). Any changes in the outcome of the ex in a simulator are due to the crew. This is fortunate given that what we want to measure is the pilot's ability. Detailed, well defined standards and rubrics will provide accurate discrimination with regard to just how good the pilot is.
Rockie wrote: Thu Aug 16, 2018 11:49 am The only way to bridge that gap is to use subjective judgement, which circles us back to the word "good".
No. The first step in evaluating performance is to write a detailed description of ideal performance, and then to write detailed descriptions of increasingly less ideal performance. The number of levels of performance you want to describe is up to you. Once you have written all of these detailed descriptions you place them in a ranked table called a rubric. You compare the observed performance to the described performance in the rubric. The more detailed the rubric, the less subjective the evaluation is.
To put this into terms you can understand, the current flight training evaluation rubric is not designed to differentiate how 'good' someone is. It is essentially designed to differentiate between inadequate, adequate, good and perfect. Don't misunderstand me; I'm not knocking the current rubric. It does the job for which it was intended, determining if someone is safe to have a license.
Rockie wrote: Thu Aug 16, 2018 11:49 amIs "good" a level 3? What if a guy gets a 3 in difficult circumstances but the next guy gets a 4 in ideal circumstances? .
That's easy. If you want to determine how 'good' a pilot is have them perform the same exercise under increasingly difficult circumstances. The further they get before they fail is a direct measure of how good they are. As has already been pointed out, the current flight training rubric is not set up to do this, nor does it need to be set up to do this.
Rockie wrote: Thu Aug 16, 2018 11:49 am The best pilots I've ever seen mixed good judgement in all circumstances with hand flying skills commensurate with the job. Lack either and you shouldn't be flying airplanes. There are people who boast about being the best stick (and maybe they are), but I would never get in an airplane with them because they utterly lack judgement. Conversely great judgement won't help you if you can't keep the airplane going where it's supposed to.
Well done. You finally arrived at the position where I started. This proves that you are, in fact, trainable.
What about the Kobayashi Maru, eh?
B208
Post by B208 »
photofly wrote: Fri Aug 17, 2018 8:04 am What about the Kobayashi Maru, eh?
Kirk was a God......
Rockie
Post by Rockie »
B208
There’s just no nicer way to describe it, but to people in this business who actually know what they’re doing you are a limited resource.
confusedalot
Post by confusedalot »
Over time, a long time now, I have been judged at one end of the goalpost as really good, and at the other, really bad. So it is widely subjective, and sadly, sometimes good old office politics play a role in the assessment when it should not. Not always and not alot, but it does happen.
I've learned quite a bit as a 300 hour instructor, a 1000 hour piston twin pilot, a 5000 hour offstrip pilot, a 6000 hour commuter turboprop pilot, and a fancy pantsy big jet pilot.
All experience is different, but it is all good. Discouraged to see that so many feel the need to pidgeonhole into black and white, good or bad, operators.
B208
Post by B208 »
Rockie wrote: Fri Aug 17, 2018 3:31 pm B208
Rockie,
It would appear that we have, once again, reached the point in the discussion where your debating skills are no longer up to the task and you resort to name calling. This is most likely why more and more of your posts are getting zapped on here of late.
You are right. I am a limited resource. So far this year I have turned away five requests, (see, precision of speech), for my services in both flight instruction and curriculum design. The truth is that I'm running flat out and I'm having to choose between doing what I like and spending time with my family.
Given that we are trading personal opinions of each other, I will offer you my (admittedly subjective) opinion of you. You seem to have a very brittle sense of self esteem; any implication that you could be wrong on even the most trivial of matters spurs you on to efforts which are simply out of proportion to the importance of the subject at hand. You are a narcissist; you hold forth on matters where you have limited experience and refuse to accept the wisdom of people who are trained experts in the said areas. This makes you the most dangerous kind of fool; You are a fool that thinks you are wise.
With that, I will give you the last word. All the fun has gone out of baiting you and watching you run around. I will leave you with the following bit of advice. Stop obsessing with Trump; it's starting to make people wonder if you are stable.
C.W.E.
Post by C.W.E. »
Great post B208. :mrgreen: :mrgreen: :mrgreen:
mixturerich
Post by mixturerich »
So most of you are saying a 900 hr ‘ho driver automatically has good hands n feet and thus is better than the 900 instructor? Seems to be a lot of disagreement on this.
Rockie
Post by Rockie »
I should clarify, I was referring to the industry beyond the aircraft circuit. Outside of that a crew is faced with innumerable decisions and cirumstances having to do with weather, aircraft component servicability and MEL, high density airports, schedule, personel, passenger, medical, and so on and so on. They also deal with human factors operating 24/7/365 working with people they know, or have never met before in their life. It's complicated and challenging.
Experience is just one of the things that brings you the essential knowledge to safely navigate all the hazards present in this extremely dynamic and evolving industry. As I said earlier, both manual flying skills and experience, and so much more are equally important.
No disrespect intended B208, I'm sure you produce very fine powerpoints on how to do steep turns and you fulfill an essential service doing so. Keep up the good work.
Squaretail
Post by Squaretail »
Personally the discussions on pilot A vs Pilot B are sort of pointless, since almost never, unless one could rig the circumstances are you going to be able to compare such fictitious people who would also adhere to the stereotypes presented. Its becoming my experience that nothing that a pilot presents him or herself as on paper is going to be representative of how they are actually going to perform. So 900 hour guy doing this vs 900 hour guy doing that is simply a moot point. You can take two guys with identical time experience and find two wildly different pilots, to guys who impress you all around and guys who make you wonder how on earth they survived that many hours in an airplane.
confusedalot
Rockie wrote: Sun Aug 19, 2018 8:24 am
I did all of that, yet I am nothing more than one mere number out of billions of homo sapiens on the planet. Started out in a cessna 150 like everyone else.
C.W.E.
Post by C.W.E. »
You should bookmark this B208 and read it when you feel discouraged with your lowly position in aviation.
Not many people here get such support from one of aviation s true sky Gods.
Just reading that long list of almost superhuman challenges people like Rockie have overcame makes me stand in utter awe of someone that talented.
And you, you lucky bast.rd got a personal message of support from him.
It is inspirational to say the least. :prayer: :prayer:
