Good point about the CAT II and II ILS, Old fella. I had been thinking the same thing as tbaylx, but that's only from my limited perspective of the old garden-variety CAT I - I forgot about the guys with the fancy equipment
Skylease Cargo 747 Runway Overrun YHZ Nov 7, 2018
- HiFlyChick
Re: Skylease Cargo 747 Runway Overrun YHZ Nov 7, 2018
They (ILS) are also the main instrument approach at major international hubs. When’s the last time you’ve seen YYZ or LAX advertise Rnavs? They aren’t going anywhere anytime soon.
Are they getting closer to achieving lower RNAV RNP minimums? So far the lowest minimums I've seen are about 200' for RNP 0.1, and about 300' for RNP 0.3.
You would need 3/4 of a mile and just over 300’ to get in on 32 on anything other than an LPV. Which airlines are doing LPV approaches?
There are RNP approaches that come down to less than 300’, but you still need 3/4 of a mile vis to shoot them. ILS isn’t going anywhere.
- HiFlyChick
Are there seriously no airlines doing LPV?
(or did I misread a sarcastic tone that wasn't there? )
It would be nice if the Air Museum could snag the cockpit section of it for a static display
Wow. Good idea. I wonder if they have the room for it. And anyone thinking the same as you.
The replacement for ILS is GLS approaches. For instance the GLS approach 4L at EWR shows 200’ and rvr 1800 or 1/2 mile. Supposedly the Cat II and III GLS approaches are being developed.
Since they already have the installation - moving the installation can be done at a fraction of the cost of a new ILS system. Perhaps even upgrade it to a Cat II/III installation.HiFlyChick wrote: ↑Sun Nov 11, 2018 3:41 pmWhy would they spend all of that money on an ILS on 32, when the RNAV gets you down to 200 AGL?Eric Janson wrote: ↑Sun Nov 11, 2018 6:24 am Agree with you about Halifax - the ILS should be on 32 imho. Adding a few thousand feet would be a good idea as well imho...
In terms of extending the length, they just spent a bunch increasing the length of 23....
Perhaps they can attract more operators with both runways the same length.
- rookiepilot
Funny how this is such a hard concept. Improve the product and actually attract more business!Eric Janson wrote: ↑Mon Nov 12, 2018 6:04 pmSince they already have the installation - moving the installation can be done at a fraction of the cost of a new ILS system. Perhaps even upgrade it to a Cat II/III installation.HiFlyChick wrote: ↑Sun Nov 11, 2018 3:41 pmWhy would they spend all of that money on an ILS on 32, when the RNAV gets you down to 200 AGL?Eric Janson wrote: ↑Sun Nov 11, 2018 6:24 am Agree with you about Halifax - the ILS should be on 32 imho. Adding a few thousand feet would be a good idea as well imho...
A foreign concept in Canada.
Perhaps as an airline pilot you are not familiar with certification standards for Canadian Airports(TP-312) nor Instrument Procedure Design Criteria(TP-308). Let me assure you as a person who has been involved( probably just as long as you have been an international airline pilot) and trained in the noted standards and criteria manuals you simply can’t take a system from one end and plunk it down on the other side. There are many variables involved, studies required way to numerous to elaborate here, Categories 11/111 add more layers and complexities on top of it. Kindest regards.Eric Janson wrote: ↑Mon Nov 12, 2018 6:04 pmSince they already have the installation - moving the installation can be done at a fraction of the cost of a new ILS system. Perhaps even upgrade it to a Cat II/III installation.HiFlyChick wrote: ↑Sun Nov 11, 2018 3:41 pmWhy would they spend all of that money on an ILS on 32, when the RNAV gets you down to 200 AGL?Eric Janson wrote: ↑Sun Nov 11, 2018 6:24 am Agree with you about Halifax - the ILS should be on 32 imho. Adding a few thousand feet would be a good idea as well imho...
HiFlyChick wrote: ↑Mon Nov 12, 2018 3:10 pmAre there seriously no airlines doing LPV?
It was a serious question. I know WestJet does not, but I’m not sure otherwise.
Encore does LPV approaches..
There are plenty of LPV approaches in Canada with the same minimums as an ILS (200’ AGL DAs and RVR 2600’ or 1/2 mile vis).
Just to name one airport, CYUL, all the following runways have LPV minimums that match their ILS minimums... RWY 06L, 06R, 10, 24L and 24R.
IIRC, in the future (if not already available at certain airports) CAT II AND III minimums will be available with GPS/GNSS/SBAS type systems but they require an additional piece of equipment to be installed at the airport, LAAS or Local Area Augmentation System, now more commonly known as the Ground Based Augmentation System (GBAS).
We do LPV approaches at Jazz on the Q400. The whole fleet isn't capable but most are.
On another note did another 747 come and get the crustaceans?
Let’s Go Brandon
- HiFlyChick
They've been clearing out the debris so that on one side at least the gear is now visible:
- 20181112_154053 (ed).jpg (223.1 KiB) Viewed 2406 times
LPV is still considered a non-precision approach.Jet Jockey wrote: ↑Tue Nov 13, 2018 5:11 pm There are plenty of LPV approaches in Canada with the same minimums as an ILS (200’ AGL DAs and RVR 2600’ or 1/2 mile vis).
So for Jazz (not sure if same applies to other companies) on those YUL runways with HGS on Cat 1 ILS we only need 1200 rvr but for LPV we need 1/2m or 2400rvr
Thanks for the info - always good to hear from people involved in other aspects of airport operations.55+ wrote: ↑Tue Nov 13, 2018 7:31 amPerhaps as an airline pilot you are not familiar with certification standards for Canadian Airports(TP-312) nor Instrument Procedure Design Criteria(TP-308). Let me assure you as a person who has been involved( probably just as long as you have been an international airline pilot) and trained in the noted standards and criteria manuals you simply can’t take a system from one end and plunk it down on the other side. There are many variables involved, studies required way to numerous to elaborate here, Categories 11/111 add more layers and complexities on top of it. Kindest regards.Eric Janson wrote: ↑Mon Nov 12, 2018 6:04 pmSince they already have the installation - moving the installation can be done at a fraction of the cost of a new ILS system. Perhaps even upgrade it to a Cat II/III installation.HiFlyChick wrote: ↑Sun Nov 11, 2018 3:41 pm
Just a question - since there is an approach to R32 wouldn't a lot of the criteria you refer to already have been completed? Or does that vary with approach type?
All the best.
Yes, especially with Precision Approach designs. Studies on prevailing winds, wx patterns and the like to determine cost effectiveness. Then assessment on rwy certification to ensure the environment meets precision criteria as established in TP-312 aka take off/approach slopes, strip widths and other associated criteria. I would assume the former aka wind and Wx rw 32 was the driving force. Interesting item in YHZ was issues with GP installation rwy 05 due interference with terrain or what was in the ground. I did a stint many years ago at TC Atlantic Regional office and remember discussions on it. To overcome issues the GP slope or angle would have to be raised beyond standard 3.0 deg which would result in a higher HAT. I thought I did hear it would have been close to the BC MDA that was published at the time. There isn’t an ILS rwy 05 at YHZ so I guess issues still dominate. I retired recently so not privy to latest discussions.Eric Janson wrote: ↑Thu Nov 15, 2018 11:59 pmThanks for the info - always good to hear from people involved in other aspects of airport operations.55+ wrote: ↑Tue Nov 13, 2018 7:31 amPerhaps as an airline pilot you are not familiar with certification standards for Canadian Airports(TP-312) nor Instrument Procedure Design Criteria(TP-308). Let me assure you as a person who has been involved( probably just as long as you have been an international airline pilot) and trained in the noted standards and criteria manuals you simply can’t take a system from one end and plunk it down on the other side. There are many variables involved, studies required way to numerous to elaborate here, Categories 11/111 add more layers and complexities on top of it. Kindest regards.Eric Janson wrote: ↑Mon Nov 12, 2018 6:04 pm
All the best.
On a personal level I do enjoy hearing your commentary as an experienced international wide body expat pilot. It is certainly interesting to hear prospective on flying in different world locations like ME and Pacific Rim to name a few.
Cheers.
ICAO has changed this back in 2013 to: LPV with DH 250ft and above are considered a non-precision approach, however LPV with DH below 250ft are considered precision approaches. I'm sure TC will eventually follow suit.
Details here: https://www.icao.int/EURNAT/Other%20Mee ... 0Sep13.pdf and https://www.eurocontrol.int/sites/defau ... 17.pdf.pdf
Obviously to fly the LPV down to 200ft you need an approach with those minimums and equipment certified for LPV200 (SBAS Cat I) or better.
