Time for Transat pilot future poll
Now that AC is within 30 days of purchasing Transat, I guess it is time for a poll to see what do you think will happens to Transat pilots if this deal goes through.
Re: Time for Transat pilot future poll
OR here is a wildcard, AC goes to a B list scale, Transat to top of list as a consolation prize. Its not like that hasnt happened before.
				Goldencondor
Realistically it might not be DOH neither BOTL. AT group employees will not loose anything most likely protected on status/equipment/base and keep vacation entitlement. Negotiations will happen and some sort of ratio will come up to transfer some sort of seniority. Pay will be topped up for some and some will even get a raise depending on where they are on the pay scale. When it comes to equipment bidding or a move down due to a down turn in the economy seniority is everything and both groups will defend their own. I do have skin in the game but both AC and AT pilot did not asked for this. This is only a really good business decision for both companies. Now lets figure the human variable in the equation. Both sides will have to give up something, that is the recepie for a good contract. I forecast an end of the flat pay at AC to sweeten the pot.
				Duke Point
Choice #4 is dumb because Calin already said that TransAT will be folded into Mainline should this pass.
People who chose that option have no idea how the Mainline/Rouge ratio works either.
DP.
DP.
				leftoftrack
Duke, Are you just now figuring out that avcanada should be viewed as entertainment and not a true source of information?
No he didn't.Duke Point wrote: ↑Thu May 16, 2019 5:15 pm Calin already said that TransAT will be folded into Mainline should this pass.
It can't all go to Rouge.
No WB growth room at Rouge so the 330s have to go Mainline and won't be counted as WB growth aircraft for the LCC growth ratio.
The 320/321s could go to Rouge within any growth ratio room available. I'm not sure where we're at on that, you'd have to check with Scope committee or your elected rep. But I don't think there is room for much... several Rouge 320s have been added already, more are coming.
If they went to Mainline they won't be LCC ratio growth aircraft either.
Most of these aircraft are coming to mainline.
I’m surprised to see such close result and BOTL been the very last.
Did ACPA and other Canadian pilot finally learn from past mistakes? I guess will see next year where everyone are standing.
The BOTL vote is split 3 ways. It's a poorly crafted poll.
From what I can figure out,1.05 Merger or Change of Control
On each occasion that the Company and/or its Successors or Affiliates are involved in a merger or in the event of a Change of Control of the Company, the following will apply:
1.05.01 Within 10 days of the Company’s decision to effect a Change of Control or enter into a Merger, the Company will notify ACPA of the same and will provide updates as significant information becomes available. Any confidential information shared with ACPA in relation to a Change of Control or Merger will be the subject of a proper confidentiality undertaking.
1.05.02 This Agreement will remain in full force and effect and the recognition now in effect issued by the Canada Industrial Relations Board (Board) will not be affected in any way except as otherwise governed by the Canada Labour Code or as directed by the Board.
1.05.03 The Company will enter into negotiations with ACPA relative to protection of employees' seniority and other existing or new conditions of this Agreement. Failing settlement, provisions of the Canada Labour Code will apply.
1.05.04 No Pilot who suffers a reduction in his or her Position as a result of a Change of Control or Merger will suffer any loss of pay.
1.05.05 No Pilot will be involuntarily relocated from one Base to another as a result of a Change of Control or Merger.
1.05.06 ACPA has the right in its sole discretion, upon written notice to the Company within 60 days from the date of the Change of Control or Merger event and, subject to the requirements under the Canada Labour Code, to either:
1.05.06.01 extend the duration of this Agreement for a period of one, two, or three years at ACPA’s option, beyond its original expiration with annual across-the-board wage, expense, benefit and MPU increases equivalent to the increase, if any, in the consumer price index plus 2% to be effective on the original expiration date and on each annual anniversary of the original expiration date thereafter; or,
1.05.06.02 amend the expiration date of the Collective Agreement to an earlier date; such date will be no earlier than 60 days from the date of the aforementioned written notice to the Company.
1.05.07 Air Canada mainline ASMs will be consolidated, if applicable, with the mainline ASMs of the other carrier and its affiliate(s).
1.05.08 Air Canada’s Capacity Purchase Agreement ASMs will be consolidated, if applicable, with the other carrier’s and its affiliate’s Capacity Purchase Agreement or Regional Carrier ASMs;
1.05.09 Any such new consolidated Mainline/Capacity Purchase Agreement ASM ratio will be maintained as the new Mainline/Capacity Purchase Agreement carrier ratio.
1.05.10 If Air Canada is involved in a merger or acquisition and the pilots of the merged or acquired carrier are consolidated with Air Canada’s Pilots, then any aircraft of the merged carrier that are added to the mainline fleet shall not count as Mainline Baseline WJA, Mainline Baseline NJA, Mainline Growth WJA, Mainline Growth NJA, or for the Growth Ratios as defined in L74.01.
1. The seniority list gets negotiated and if the pilots can't come to an agreement, the arbitrator will impose one. Certainly the AC pilots will insist on BOTL, as per 4.01.02
2. The union can unilaterally cut the current Collective Agreement short and renegotiate, but will probably be too busy trying to thrash the incoming TS pilot's working conditions to bother improving their own.For greater clarity, in the event of any future declaration of common employer status and/or declaration of sale of business; purchase or merger of airlines or parts thereof; or other combination of flying operations under the Company, the seniority of employees who are to be added to the seniority list as a result of such an event will commence no earlier than the date of the issuance of any CIRB order regarding the declaration of common employer status and/or sale of business, the date of the future purchase or merger of airlines, or the date of such other future combination of flying operations, as the case may be.
3. If the TS pilots get anything other than BOTL, Montreal becomes a much more senior base, but anyone currently holding it cannot be displaced. If Montreal is your goal, maybe it's time to bid it now.
- confusedalot
Ummmh........
Jazz never got a pilot merger. Neither did Sky regional, Georgian, or EVAS, or anyone else for that matter. Canadian got a horrible almost, but not quite, botl deal shoved down their throats. Something like a 1 in5 deal, can't quite recall right now. Worse still, all approved by a federal judge.
I am missing something? Maybe I did not get the astrophysics memo about the universe changing?
Attempting to understand the world.  I have not succeeded.
Is Jazz, Sky Regional, Georgian, or EVAS owned by Air Canada? Were they ever declared common employer? If not then I don't see the relevance Confusedalot.
As for the Canadian merger, I think it could be highly relevant but I don't know the details. I've seen the aftermath as I still run into the odd lunatic raving about it, but does anyone have the actual details?
I think Trump calls that fake news. On the other hand you do freely admit you are confused a lot.confusedalot wrote: ↑Fri May 17, 2019 7:46 pm Ummmh........
The bottom 1/3 of the AC/Canadian list was merged at a ratio of 8:1. Thats 8 AC pilots for every 1 Canadian. The bottom 1/3 of the list comprised of 800 AC pilots and 100 Canadian pilots.
The Canadian pilots primarily merged with the top 2/3 of the AC list.
It’s a perfect example of how off the rails things can go if left in the hands of an arbitrator.
This is simple.
Fair. And I don’t mean that in a biased way.
Welcome AT pilots. Don’t take the BS on this forum as the average AC perspective.
First Air Canada Rouge, now Air Canada Blue
- confusedalot
So 8 to 1 is a fair deal..........Fanblade wrote: ↑Fri May 17, 2019 8:41 pmI think Trump calls that fake news. On the other hand you do freely admit you are confused a lot.confusedalot wrote: ↑Fri May 17, 2019 7:46 pm Ummmh........
This is simple.
I say again.....8 to 1 is a fair deal.
What was that about fake news?
Victors always rewrite history for their own purposes.
Of course, they busted their chops for decades and they deserve 8 to 1.
Yeah......right......
Now I'm confused. Probably serves me right for engaging.confusedalot wrote: ↑Sat May 18, 2019 7:16 pmSo 8 to 1 is a fair deal..........Fanblade wrote: ↑Fri May 17, 2019 8:41 pmI think Trump calls that fake news. On the other hand you do freely admit you are confused a lot.confusedalot wrote: ↑Fri May 17, 2019 7:46 pm Ummmh........
This is simple.
The bottom 1/3 of the the combined AC/CDN list was 88% AC pilots.
This is what you wrote and it is completely fabricated. You have it backwards.
Completely false
It was an 8:1 AC pilot end tail
I guess you have one part right.
				leftoftrack
what happened to the top 2/3rds of the list?
				thesimplelife
If I remember what I was told a while ago some were relative seniority, some DOH formula and then the bottom 8:1.
Varying ratios based on WB CA, NB CA, WB FO, and NB FO.
But it’s more complicated than that. After that ratio was established a re ratio was placed on top. The re ratio skewed the original intent as it moved down the list to the point that there was hardly any CDN left to merge with for the bottom 1/3 of the AC list.
nd The AC/Cdn merger left everyone with a bad taste in their mouth because it was the forced marriage of two failing businesses that watched their combined market share dwindle. It's noteworthy that no pilots who lived through it have commented here, they've moved on, it was nearly two decades ago.
AC's purchase of TS isn't another chapter in the story its a different genre. No doubt there will still be pilots who feel they didn't get a fair deal and will make outlandish demands, so be it. Hopefully the leadership of both groups can get together and find common goals, figure out the key objectives and focus on achieving them.
				thesimplelife
Merge the lists, get rid of 4 year status pay, 5-10% bump across the board, improvements to the reserve rules and pension and I'd be content. It's a lot to ask for but hey, get all that and we're still well behind every carrier in the USA. Oh, and no more 10 year contracts.TheStig wrote: ↑Sun May 19, 2019 9:25 am nd The AC/Cdn merger left everyone with a bad taste in their mouth because it was the forced marriage of two failing businesses that watched their combined market share dwindle. It's noteworthy that no pilots who lived through it have commented here, they've moved on, it was nearly two decades ago.
When I got my offer letter I remember it saying something about wanting to be a top 10 global airline. Well, maybe it's time to start paying like a top 10 global airline.
The top scale Transat A330 captain has a lower pay rate than a A320 captain at AC.  Essentially Transat Seniority #1 currently makes less on paper than a seniority number 3200ish that holds a A320 captain position at AC.
Let that sink in. The Transat pilots have landed a windfall of a lifetime. Even a DOH merge would be a huge upside for these guys/gals.
Is a top rate AC 320 more than 224/hr? I'm not quite sure if this is accurate. Plus, the schedule was the BIG draw at TS.RVR6000 wrote: ↑Sun May 19, 2019 9:13 pm The top scale Transat A330 captain has a lower pay rate than a A320 captain at AC. Essentially Transat Seniority #1 currently makes less on paper than a seniority number 3200ish that holds a A320 captain position at AC.
Regardless, hoping for positivity all around.
It’s $220/hr (day/night blend).DanWEC wrote: ↑Sun May 19, 2019 10:26 pmIs a top rate AC 320 more than 224/hr? I'm not quite sure if this is accurate. Plus, the schedule was the BIG draw at TS.RVR6000 wrote: ↑Sun May 19, 2019 9:13 pm The top scale Transat A330 captain has a lower pay rate than a A320 captain at AC. Essentially Transat Seniority #1 currently makes less on paper than a seniority number 3200ish that holds a A320 captain position at AC.
www.airlinepilotcentral.com shows Transat Capt. tops out at approx. $175K.
