cars question
MZUNGO
cars question
Post by MZUNGO »
ok I need help with a disagreement between Myself and a coworker.
when making a correction on a logpage you are supposed to draw a single line through the item and write "eie" on it and initial.
where in CARS does it specify this?
my Coworker says it also needs to be dated. I say no.
so of course we both have tried to look it up with no sucess. any help would be great
thanks
M
laserstrike
Re: cars question
Post by laserstrike »
If a simple line through the whole thing isn't enough I guess I've invalidated a lot of log books
Mach .28
Re: cars question
Post by Mach .28 »
I'll give you a hint....find it in.....605.XX It took about 30 seconds to google search it.
But keep in mind you COM or MPM may have a specific procedure for your company that may be more restrictive than the CARs. Take a look there too.
MZUNGO
Re: cars question
Post by MZUNGO »
found it. looks like I'm buying lunch.
@lazerstrike it looks like you are going to jail ;)
605.93 (1) Every person who makes an entry in a technical record shall
(5) Subject to subsection (6), where a person alters an entry on a technical record for the purpose of correcting the entry, the person shall do so by striking out the incorrect entry in such a manner that the underlying information remains legible, and inserting the correct entry together with
(a) the date of the alteration;
(b) the reason for the alteration, if it is necessary to clarify why the alteration was made; and
(c) the person’s name and signature or employee identifier or, where the record is kept as electronic data, the person’s user code or equivalent security designation.
(6) Where a correction referred to in subsection (5) is being made to a technical record that is maintained as electronic data, the correction shall be made in a manner that does not render the original data inaccessible.
AuxBatOn
Re: cars question
Post by AuxBatOn »
MZUNGO wrote: ↑Thu Jun 06, 2019 6:31 pm ok I need help with a disagreement between Myself and a coworker.
thanks
M
Logpage as in aircraft logbook or logpage as in pilot logbook?
Going for the deck at corner
MZUNGO
Re: cars question
Post by MZUNGO »
AuxBatOn wrote: ↑Thu Jun 06, 2019 7:02 pm Logpage as in aircraft logbook or logpage as in pilot logbook?
aircraft logbook
