Coffee in a Thermos and security
FighterPilot
Post by FighterPilot »
Getting really sick of the on board coffee and I'm looking at taking my own Thermos to bring my own coffee with me. I have a 1.9L Stanley, so it's a little on the large side and completely metal. Anyone have any problems with security, specifically internationally?
Re: Coffee in a Thermos and security
In Canada and in most countries, no problem working/dhing/commuting in uniform.
In the UK, it's a problem.
flyinhigh
Post by flyinhigh »
May I recommend something like this.
https://www.sportchek.ca/product/gsi-co ... =331810659
Bring your own beans and change it up.
yycflyguy
Post by yycflyguy »
flyinhigh wrote: Mon Aug 05, 2019 6:48 pm May I recommend something like this.
Interesting idea but unfortunately you'd still be using airplane hot water :vom:
flyinhigh
Post by flyinhigh »
yycflyguy wrote: Tue Aug 06, 2019 8:35 am Interesting idea but unfortunately you'd still be using airplane hot water :vom:
Oh come on, airplane water is 100% pure and clean :smt040
Old fella
Post by Old fella »
Are you suggesting tis best if I drink beer in lieu of yer airline coffee.
FighterPilot
altiplano wrote: Mon Aug 05, 2019 6:38 pm In Canada and in most countries, no problem working/dhing/commuting in uniform.
Thanks, that's what I figured... Leave it at home for the UK layovers.
Interesting, I may give that a try. For $25-30 its not a bad option. Like YYCFlyGuy said you'd still be using the aircraft water, but the option of having your own fresh ground beans might mitigate that. Each FIN seems to be different, some the on board coffee/water seems OK, others it's completely undrinkable.
schnitzel2k3
Post by schnitzel2k3 »
Old fella wrote: Tue Aug 06, 2019 5:06 pm
Make it red wine, for the ol' 3.6 Roentgen ☢
S.
yycflyguy
Post by yycflyguy »
Every single time! :drinkers:
HavaJava
Post by HavaJava »
schnitzel2k3 wrote: Tue Aug 06, 2019 6:31 pm
Make it red wine, for the ol' 3.6 Rotgen ☢
S.
Old fella
Post by Old fella »
yycflyguy wrote: Wed Aug 07, 2019 7:41 am
Duly noted. Since you cockpit flight crews mentioned yer company coffee I have to say as a passenger noticed over the past few years AC coffee is putrid at times. Tastes and smell burnt like it has been recycled for a great number of hours. As the sign says in the aft lavatory on yer B767ER “ only need to flush once it’s a short distance to the galley” :wink: :wink:
Willirim
Post by Willirim »
I understand you perfectly. Also, I'm not particularly eager to drink coffee on airplanes, but at the same time, I can't do without coffee. So I decided to order a reusable thermos cup inspired by the article https://starbmag.com/best-starbucks-k-cup-flavors/. Such cups are very convenient precisely because you can take enough coffee for a trip and to drink your coffee when you want. I also like that Starbucks pours my coffee into such a cup, which is very convenient.
Arnie Pye
Post by Arnie Pye »
I have found several of those travel french presses at value village for $2.00.
My next move is to get a silicone pour over funnel and bring my own beans. I'll put up with the onboard water but bad coffee can't be tolerated.
Col. Panic
Post by Col. Panic »
I flew with one guy who had a Handpresso manual espresso pump. www.handpressocanada.ca
He swore by it, and the carrying case was… a conversation starter?
What a bunch of addicts here :lol:
Arnie Pye
Post by Arnie Pye »
Col. Panic wrote: Thu May 26, 2022 6:59 am I flew with one guy who had a Handpresso manual espresso pump. www.handpressocanada.ca
I have one of those. Found it didn't work well with the reduced cabin pressure. Also one big device to carry around. Pour over is the way to go. more caffine than espresso and better tasting coffee.
McKinley
Post by McKinley »
I take my thermos and make my own lattes…
I’ve had mine dumped out …
I also usually pack my own meals to save perdiems… it’s common to have CATSA/ ACSTA to go through the contents of my lunch/ they’ll confiscate my cutlery .. at which time they get an earful.. after they go through my food I usually don’t feel like eating it.
FYI I define “going through food” as in removing the covers of my meal Containers / touching contents ..
EPR
Post by EPR »
Arnie Pye wrote: Thu May 26, 2022 7:38 am
You may have confused your Swedish penis pump for the Handpresso!
Keep the dirty side down.
AirFrame
Post by AirFrame »
I've used an Aeropress for the last 10 years for 99% of the coffee I make at home and on the road. Best coffee i've had from a hand-operated unit, and i've tried everything but a handpresso.
I ordered a Coffee Jack from the indiegogo campaign a year and half ago, they're just about to ship them. I'm looking forward to seeing how well it works.
TrilliumFlt
Post by TrilliumFlt »
AirFrame wrote: Sat May 28, 2022 7:44 am I've used an Aeropress for the last 10 years for 99% of the coffee I make at home and on the road. Best coffee i've had from a hand-operated unit, and i've tried everything but a handpresso.
I like the look of this device, I'll be getting one when they become available
Did you read the review at the bottom of the link you provided? :lol:
A LEAKY DISASTER
Seems like a good idea, but just another example of how GSI should stick to making metal dishes.
Pros:
-Looks pretty
-Can be hung from a bag
Cons:
-Perforated lid that leaks as fast as you can pour it on yourself or your gear
-Mouth piece lid also doesn't seal, not sure why it even has one when there is a big hole drilled through the main lid. Maybe that wasn't a big enough leak to meet GSI spec.
-Also leaks out the o-ring seals inside the cylinder, will shoot boiling water at you on occasion.
-Almost every other review says it deforms and begins to leak so bad it won't even make coffee.
Hilariously poor.
I bring the large Contigo mug, It holds a Large McD's coffee perfectly. Never had an an issue with it with CATSA.
