Boeing Max.
C.W.E.
Re: Boeing Max.
Post by C.W.E. »
“Boeing has many decades of experience working with supplier/partners around the world,” a company spokesman said. “Our primary focus is on always ensuring that our products and services are safe, of the highest quality and comply with all applicable regulations.”
Ahhhh, now I feel better about this Boeing Max issue.
It is not Boeing that is responsible for these crashes it is the pilots just were not capable of figuring out what it was doing and sort of got a little behind what it was doing.
GoinVertical
Re: Boeing Max.
Post by GoinVertical »
C.W.E. wrote: ↑Thu Aug 29, 2019 12:24 pm How many airline category airplanes require a computer driven ( load alleviation ) device to stop a pitch excursion caused by the engine thrust needed to take off and climb that is so powerful it can cause the airplane to crash if it is handled improperly?
How many transport category aircraft have any form of automation that effects primary flight controls without redundant input? Stick pusher that takes data from only one source? Even the stab trim switches need redundant input to function.
Whoever designed the MCAS system to take information from only on AOA sensor and not compare to the other should be taken out behind the barn, as far as I'm concerned.
Oh, and then let's not tell pilots that the system exists, let alone how poorly it's designed.
imcool
Re: Boeing Max.
Post by imcool »
GoinVertical wrote: ↑Thu Aug 29, 2019 2:06 pm
that too programmed by 9$ per hour programmers to save the cost :/
boeingboy
Re: Boeing Max.
Post by boeingboy »
There is so much wrong with this statement - it makes me wonder if you understand anything of the actual problem
boeingboy
Re: Boeing Max.
Post by boeingboy »
The on-again off-again aspect of MCAS seems unusual. Stick pushers, stick feel adjustment systems, load alleviation systems - isn't it unusual for them to run for 5 seconds, then shut down for 10 seconds, then magically start up again? Wouldn't they be either active at a given point in the flight envelope or inactive? Anyone know?
Generally speaking - A stick pusher/stall warning will remain active until the stall has been counteracted. In the case of the max - As it only had one AOA input and the vane was damaged by a bird (Ethiopian) the AOA told the plane he was at 74 degrees nose up. The system operated as designed, except that the AOA input to the computer never changed so the plane thought it was still stalled.
The on again off again that you refer to is due to the fact that Boeing - in addition to being able to turn it off altogether - basically said if the pilot wants to over ride the system - he can with the electric pitch trim, which is what the pilots of both flights were doing. Although I still cant figure for the life of me why they just didn't trim the plane back to level flight. Theywould only trim for 2 or 3 seconds after the system trimmed for much longer than that
Eric Janson
Re: Boeing Max.
Post by Eric Janson »
boeingboy wrote: ↑Thu Aug 29, 2019 8:25 pm Although I still cant figure for the life of me why they just didn't trim the plane back to level flight. They would only trim for 2 or 3 seconds after the system trimmed for much longer than that.
This is one possible explanation:-
It's apparent that both crews had to apply increasing force on the yoke in an effort to maintain level flight. If you really need to exert maximum force on the yoke then your hands will need to move down slightly from their normal position. That is just enough to make accessing the trim switches difficult.
FICU
Re: Boeing Max.
Post by FICU »
The Ethiopian Captain used control wheel force to bring the nose up rather than the nicely placed electric trim switches by his thumb. He forgot about controlling the thrust and then he got tired. In the Lion Air crash the pilot used the electric trim switches many, many times to bring the nose up and it worked it would seem until he handed control over to search the checklists.
fish4life
Re: Boeing Max.
Post by fish4life »
The craziest part is the Ethiopian crew had it fixed but instead of manually trimming the airplane after turning off the electric trim they turned it back on causing the MCAS to run again.
mijbil
Re: Boeing Max.
Post by mijbil »
Hey F4L, From reading the initial crash investigation report I think that they did try to trim it manually but the force from the CA hauling back on the elevators to try and counteract the Aircraft Nose Down commanded by the stab was too much for the manual trim wheel to overcome. The analogy I was told was that it's like having a really big fish on a line that you can't reel in (trim manually) The only way to trim manually is to release back pressure momentarily, trim like mad manually, haul back on the yoke again and repeat as necessary. It's similar to lowering the rod tip while reeling in the fishing line and then hauling up the rod again.
Here is a brief excerpt from the Ethiopian crash report : At 05:41:46, the Captain asked the First-Officer if the trim is functional. The First-Officer has replied that the trim was not working and asked if he could try it manually. The Captain told him to try. At 05:41:54, the First-Officer replied that it is not working."
And from the Boeing FCTM : Excessive air loads on the stabilizer may require effort by both pilots to correct the mis-trim. In extreme cases, it may be necessary to aerodynamically relieve the airloads to allow manual trimming. Accelerate or decelerate towards the in-trim speed while attempting to trim manually.
What isn't mentioned is that you might need a fair bit of altitude to relieve that airload.
The link posted by Flying Low written by an engineer is the best explanation so far that I have seen of the MCAS system.
boeingboy
Re: Boeing Max.
Post by boeingboy »
Oh please - it's his own opinion and works for Airbus.....half of what he states is a crock.
Flying Low
Re: Boeing Max.
Post by Flying Low »
Fair enough. Now what is incorrect in the article?
DH82EH
Re: Boeing Max.
Post by DH82EH »
boeingboy wrote: ↑Thu Aug 29, 2019 8:10 pm
The answer is simple. One, although it is not currently in service.
lostaviator
Re: Boeing Max.
Post by lostaviator »
Once you get yourself into the situation of having that much nose down trim, at such a low altitude, you are done.
The manual trim wheel won’t move with the opposing forces applied. The only way to trim is to release all force and let the nose fall. If you don’t have a few thousand feet, it’s all over.
pilotbzh
Re: Boeing Max.
Post by pilotbzh »
lostaviator wrote: ↑Wed Sep 04, 2019 3:45 pm Once you get yourself into the situation of having that much nose down trim, at such a low altitude, you are done.
Not true, first pull hard to bring the nose up respecting the stall warning, then release pressure to manually trim nose up, no need to loose altitude.... as long as you control the speed, it won't work if you let the speed go 350+Kts
GoinVertical
Re: Boeing Max.
pilotbzh wrote: ↑Wed Sep 04, 2019 4:09 pm
What if the stab is trimmed so nose - down that full up elevator only gives you level flight or just slightly better?
confusedalot
Re: Boeing Max.
Post by confusedalot »
With all respect to all, yer all missing the point. And the point is.....you still need to know how to fly a plane. These machines are now so dummy proof that pretty much any driver can operate them. Good, bad, does not matter, if you have a quarter of a brain of the average human, you can't get hurt. YET, they still crash.
Reminds me of the toyota incident where the lady had a gas pedal runaway but could not figure out that all she needed to do was push on the brakes. She was smart enough to call her husband though while all of this was going on, telling him how terrified she was.......go figure......So all toyotas have a convoluted kill system now.
Flew the ng only, not the max, but pretty much the same plane. Did max sim though.
You could kill the whole system with a flick of a switch, but that was not done. That includes the mcas. But then......you need to fly the plane.
Sure, there was an engineering lapse/mistake. How far do we need to go?
Remember air france who could not figure a out a deep stall in an airbus and flat stalled into the south atlantic?
And of course there is the media, they conviently forget to tell the whole story for a quick and lucrative story.
Cheers.
pilotbzh
Re: Boeing Max.
Post by pilotbzh »
GoinVertical wrote: ↑Wed Sep 04, 2019 4:58 pm
With full nose down trim, you still have full authority on the elevators to pull that nose up but the force required to do so increases with speed. The trim only adjust the horizontal stab... and juste like railing a fish you don’t have to give back any line as you lower the rod to rail or descent at all to manually re-trim a mis-trim situation, but speed control is crucial...
lostaviator
Re: Boeing Max.
pilotbzh wrote: ↑Wed Sep 04, 2019 7:19 pm
I don’t want to start an argument, but where did you get that information? Every conversation I’ve had with training pilots has been that the elevator can JUST keep the plane level with full nose down trim.
The shortage of max sims, and... the fact that Boeing doesn’t even know how the max handles, makes this a hard discussion to find real answers too.
pilotbzh
Re: Boeing Max.
Post by pilotbzh »
Did it in the max Sim.... Have 14000h TT just 400h on Max...
J31
Re: Boeing Max.
Post by J31 »
The sim will only simulate what is programmed. Boeing provided the parameters to the sim manufactures and originally never included the MCAS programming. Many of the world regulators have little faith in the simulator programming to accurately portray the extreme corners of the MAX flight flight envelope.
I know from experience that the manual trim forces in the simulator do not accurately represent the Boeing 737-200. The aircraft took much more strength to manually turn the trim wheel in flight.
I would not put a lot of faith in a MAX sim to accurately simulate the ability to climb with full nose down trim at this point in time.
Boeing is going to have to prove both in the sim and the aircraft that the trim forces do not need super strength or split second reaction to keep the MAX from becoming a lawn dart.
Re: Boeing Max.
The stab doesn’t just trim the stabilizer. It also trims the elevators via the feel and centering unit and the PCUs. So nose down, you have to overcome a lot more spring pressure than when it’s neutral... and have to deflect the elevator much more relative the to neutral set by the feel and centering unit to counter what the stab is doing. Add some speed in there and now you’re fighting hydraulic pressure from the feel system as well.
Flying Low
Re: Boeing Max.
Well....the Lion Air crew flew the airplane for around 9 minutes using the electric trim repeatedly and the Ethiopian crew flew for 6 minutes using brute force. Even if you say it's 3 minutes to get the flaps up (when the MCAS kicks in) that's 6 and 3 minutes respectively for each crew flying with the MCAS forcing the nose down. I think we can fairly say split second reaction time is not necessary and considering the electric trim works neither is super human strength. Please don't get me wrong...I'm not excusing Boeing from a badly designed system...I still do not understand how either crew lost the airplane.
mixturerich
Re: Boeing Max.
Post by mixturerich »
Flying Low wrote: ↑Thu Sep 05, 2019 10:28 pm ...I still do not understand how either crew lost the airplane.
What are you implying? That they were incompetent??
tbaylx
Re: Boeing Max.
Post by tbaylx »
mixturerich wrote: ↑Fri Sep 06, 2019 1:38 am
Assuming that the regulatory body maintained ICAO standards and that the crew passed their PPC's then the crew wasn't incompetent. That still leaves a lot of room between marginal and . Yeager however.
They were presented with a challenging situation outside of their training and weren't able to handle it. That doesn't mean they were incompetent, but they weren't up to the task of recovering a flyable aircraft outside the realm of their training. To say that crew response didn't have a part in it is as ignorant as saying Boeing MCAS design had no part in it. Both were contributing factors to varying degrees.
The point is that Boeing can't send an aircraft out with a non normal that X% of the worlds pilots are unable to recover from. Even if that's a small percentage it will lead to a hull loss every so often, which is obviously unacceptable.
Re: Boeing Max.
The thought certainly has crossed a few minds. An guy who "flew 8000 hours in 6 years", and a 200 hour FO? Not saying it outright, but questions of experience have to factor in to the discussion.
