Wabusk Crash
Wabusk Crash
No word on the crash at Wabusk? All got out ok but havent heard any other details...
Keep flying till the noise stops.
- bob sacamano
Where'd who go?
sprucemonkey
This is an interesting one..many versions of the story out there. This is the one I heard the most.
Night takeoff. Pilot says windshear. Pax say he was flying with no pannel lights and a flashlight on his head (read:head lamp), experienced an engine failure, rejected.
It could be BS. You all know how these get started. Glad everyone is ok.
bush pilot
- Wally3Wheels
Lucky!
The PA31 departed Kash at night, immediately after take-off, the aircraft's left engine failed, resulting in the aircraft crashing into a swamp. There were no injuries to the seven 7 pax's, the aircraft was substantially damaged.
Do not judge until you know the full story...
Wabusk Crash
Maybe both....maybe "really lucky" and "did a good job"....or, is there actually any place at all for luck in aviation?????
- oldncold
wabusk air
talked to the refueler ymo (funny they know more than just about anyone what happened) the above posts mainly are correct . 1 engine failed
reject and ruhbarb was the outcome.
what is interesting is they lost a contract for patient transfers and that
the locals are in a leary boycott mood so even if they hire 'NEW' it could be a very lean winter.
minus 37 to - 50 is hard on them hoe's
- bob sacamano
Hears what one of the passengers had to say...
http://www.wawatay.on.ca/index.php?modu ... 1&pid=1286
What a load of bull. Remoteness of the area? Give me a break. You can't get any more access to a crash site than that. At an airport serviced by a sked carrier.
This company needs to be investigated one way or another. Using the "remoteness" argument is pretty poor. An accident like this needs to be a field investigation, unless the TSB already knows exactly what happened. If the pilot says "yeah, I screwed up and had the wrong tank selected and it died", then that is pretty straightforward.
However, if I were in charge at TSB (or TC), knowing what I know about this company, I'd say "ok, but we're coming up anyway to check it out". At the same time I'd have the OPP guarding the scene.
I truly hope the people involved start screaming and yelling over this one. It shouldn't matter whether it happens in Kash or in Winnipeg or in Ottawa.
