Swoop Terrain Warning
tbayav8er
Re: Swoop Terrain Warning
Post by tbayav8er »
AuxBatOn wrote: Sat Dec 28, 2019 8:39 pm
Edelweiss air wrote: Sat Dec 28, 2019 7:13 pm
losercruiser wrote: Sat Dec 28, 2019 6:47 pm
Wrong. Not in terminal airspace. The post above me is correct.
Not so sure about that, legally speaking the only time atc takes terrain responsibility is when they give you a vector. Unless you can show me a reference otherwise. The only thing I’ve ever seen black and white atc takes terrain responsibility is in the aim when it discusses radar vectors. Otherwise it’s up to you to decide. Now in Canada ATC isn’t going to clear you down to an altitude that’s below the minimum for that sector but direct responsibility for terrain clearance is the PICs in that case.
AIM RAC 1.5.5
Minimum radar vectoring altitudes (lowest altitude at which an aircraft may be vectored and still meet obstacle clearance criteria), which may be lower than minimum altitudes shown on navigation and approach charts, have been established at a number of locations to facilitate transitions to instrument approach aids. When an IFR flight is cleared to descend to the lower altitude, ATC will provide terrain and obstacle clearance until the aircraft is in a position from which an approved instrument approach or a visual approach can be commenced.
Yes, but if you're cleared to descend to an altitude let's say below the MSA, on a STAR, then following the STAR guarantees terrain clearance. If you deviate from the STAR and get too close to terrain as a result, it's not ATC's fault. They could clear you for the approach as soon as you crossed the first waypoint on the STAR if they chose to do so. By my interpretation anyways.
AuxBatOn
Post by AuxBatOn »
tbayav8er wrote: Sat Dec 28, 2019 9:33 pm
AIM RAC 1.5.5
This isn’t what this says. It says if you are on an IFR flight and ATC clears you at an altitude below the published MSA, you should clear obstacles and terrain until an approach can be commenced.
Going for the deck at corner
Eric Janson
Post by Eric Janson »
lostaviator wrote: Sat Dec 28, 2019 9:20 am
Eric Janson wrote: Sat Dec 28, 2019 1:20 am One thing that struck me looking at the Abbotsford plates (Jeppesen).
SID and STAR plates do not have an MSA on them or a terrain map showing the highest elevation. This is now standard on Jeppesen plates.
All that is listed is a 100nm safe altitude.
This is a serious safety deficiency imho.
Which Jepp plates are you looking at? They all have the MSA box on my set.
In the case of the custom RNP's, sector altitudes are not even really needed, because they were not designed to be a DCT IAF approach. The routing notes on both RNP's state how to connect and fly the approach from the STAR. The At or above altitudes provide terrain guidance all the way down.
Edit
Sorry, I misread your post (speed reading before coffee) and thought you were writing about the Jepp Approach plates.
I think Jepp is in the process of upgrading their plates with colour terrain profiles etc, but I think the 100 nm safe is the standard on most charts. I don't think I have ever seen 25 MSA's published on STARS or SIDS.
They've been published for years for airports all over the World (nice to have the 25 MSA on the SID/STAR charts) - I see other Canadian Airports now have the updated Jeppesen chart format. Given the high 100nm safe altitude you would think they would put some more information on the SID/STAR charts.
When you're cleared for an approach, in Canada, your clearance is to descend only to the lowest published IFR altitude, unless you're being radar vectored.
That's some basic shit.
No matter where you're cleared direct to, or if you were cleared to descend previously on a STAR and now you're going direct, The minimum published IFR altitude is all, unless ATC is providing vectors.
I think lots of people are complacent on it, or just aren't experienced flying in the mountains and are used to MSAs that are more or less the same as the altitude over the transition or IAF so it always worked out... "the fix I was cleared to says 3000' so I descended to 3000'"
AuxBatOn wrote:This isn’t what this says. It says if you are on an IFR flight and ATC clears you at an altitude below the published MSA, you should clear obstacles and terrain until an approach can be commenced WHEN ON RADAR VECTORS.
I fixed it for you... you are referencing radar vectoring altitudes. ATC clearing you below safe IFR altitudes does not absolve you for your own (ie. published) terrain clearance if you're not on radar vectors.
Even being recleared laterally by ATC without a descent clearance doesn't absolve you of your responsibility.
ie. you're level on an airway or transition below sector and you get cleared off the airway/transition direct to the IAF. You are responsible to request a new altitude that provides terrain clearance or reject the clearance.
lostaviator
Post by lostaviator »
None of this is relevant. ATC never cleared either of the Swoop planes direct the IAF.
Even with the absence of MSA on the charts, a pilot with any IFR experience would ask "am I safe doing this?". If there are no MSA's, the 100 nm is your next best safe place. They took their plane out of a safe environment, and pointed it towards terrain.
Two sets of pilots, two days in a row. Scary.
But CAE instructors and Swoop procedures are better. :rolleyes:
AuxBatOn
Post by AuxBatOn »
altiplano wrote: Sun Dec 29, 2019 5:38 am When you're cleared for an approach, in Canada, your clearance is to descend only to the lowest published IFR altitude, unless you're being radar vectored.
Where do you see when on radar vectors in that sentence?
It says that ATC may assign you altitudes down to the MRVA and they will ensure you miss terrain and obstacles. If they meant when on radar vectors, the sentence would have started with: When an IFR flight on radar vectors is cleared [...]
For the Swoop incident, they deviated from their previously cleared route because they were cleared for an approach (which is fine) however they should have, at that point, meet the published minimum safe altitudes since ATC could not have expected them go direct the IAF given they were on a STAR.
AuxBatOn wrote: Sat Dec 28, 2019 9:38 pm
AIM RAC 1.5.5
Uhhh... Yes, it does... take a look where it says it.
Your quote is under:
1.5.5 Obstacle Clearance During Radar Vectors ................. 182
AuxBatOn
Post by AuxBatOn »
The paragraph above and below duly note “radar vectors” in sentences where it applies. It is not mentioned in this one, therefore applicable to all IFR flights assigned a lower altitude.
Example: “You are cleared to YAB, descend to 4,000 feet”. ATC is then responsible for terrain/obstacle clearance.
Subsequently, “You are cleared for the RNAV Y runway 25”. You become responsible for terrain/obstacle clearance.
Post by ahramin »
The entire section (1.5.5) is for aircraft being radar vectored. It only applies to aircraft being radar vectored, even if each sentence doesn't specify radar vectors.
However, in Canada radar controllers are not permitted to clear you to an altitude that has a terrain or traffic conflict. Even on a STAR they aren't allowed to do it which is why "Descend via STAR" was such an obvious disaster from suggestion to implementation to retraction.
dialdriver
Post by dialdriver »
http://www.navcanada.ca/EN/media/Public ... 444-EN.pdf
Air Traffic Management (PANS-ATM)
1/11/01
8.6.5 Radar vectoring
8.6.5.2 When vectoring an IFR flight and when giving an
IFR flight a direct routing which takes the aircraft off an ATS
route, the radar controller shall issue clearances such that the
prescribed obstacle clearance will exist at all times
until the
aircraft reaches the point where the pilot will resume own
navigation. When necessary, the minimum radar vectoring
altitude shall include a correction for low temperature effect.
Note 1.— When an IFR flight is being vectored, the pilot
may be unable to determine the aircraft’s exact position in
respect to obstacles in this area and consequently the altitude
which provides the required obstacle clearance. Detailed
obstacle clearance criteria are contained in PANS-OPS
(Doc 8168), Volume I, Part VI, Chapter 3 (Altimeter
Corrections) and Volume II, Part II, Departure Procedures,
Part III, 24.2.2.3 (Procedures based on tactical vectoring),
and Part VI (Obstacle Clearance Criteria for En-route).
AuxBatOn wrote: Sun Dec 29, 2019 4:29 pm The paragraph above and below duly note “radar vectors” in sentences where it applies. It is not mentioned in this one, therefore applicable to all IFR flights assigned a lower altitude.
The entire section is under "radar vectors", they don't have to explicitly say "radar vector" in every sentence for it to apply to that... this is basic linguistic construction.
Look at the subject at the top of every clause you guys are quoting:
8.6.5 RADAR VECTORING
1.5.5 Obstacle Clearance during RADAR VECTORING
I can't believe this is an issue with a group I assumed are professional pilots.
So for the new IFR pilots reading this, and to summarize:
Every ATC altitude clearance does not guarantee terrain clearance.
Every ATC lateral clearance does not guarantee terrain clearance.
When you aren't being radar vectored, you are responsible for your own terrain... if you don't get that you're a hazard and should go talk to your local IFR guy and see if he can sort you out.
AuxBatOn
Post by AuxBatOn »
Part of my job is to write flight rules and interpret others. My guess is that they put that blurb in this section because they define MRVA in that section (related to radar vectoring) and its applicability to other situations. Why would they explicitly put “radar vectors” in other sentences but not this one? Also, the ATM supports my interpretation. In Canada (this incident happened in Canada yes?), ATC will not assign you an altitude below the MRVA, guaranteeing obstacle and terrain clearance.
LOL... I like that it's your 'guess"...
It's explicitly written under, and applies to the subject.
Just to be clear, in your view, does every ATC clearance guarantee terrain separation?
What statement in the ATM supports you? The part under RADAR VECTORING?
AuxBatOn
Post by AuxBatOn »
Yes. Sounds like they consider giving a clearance direct to a fix a “radar vector” for that purpose...
route
“Cleared direct XYZ, descend to 4,000 ft” will guarantee obstacle clearance.
AuxBatOn wrote: Sun Dec 29, 2019 11:31 pm Yes. Sounds like they consider giving a clearance direct to a fix a “radar vector” for that purpose...
route
You are taking about a clearance while RADAR VECTORING though. "When vectoring"
Not all clearances constitute a radar vector and terrain responsibility by ATC.
Can you answer my question?
Do all ATC clearances guarantee terrain seperation?
You should try flying on an airway at the MEA, but below MSA and ask for a clearance direct to your destination or IAF or whatever... you'll get the clearance...
In fact I've had ATC offer it... on the west coast, at 10,000' with pressurization problems but continuing on the airway at MEA to destination on the North Coast... Van Centre clears me direct to the IAF through sectors with 16,000'+ MSAs while I'm at 10,000'... Who do you think has responsibility for terrain seperation there?
AuxBatOn
Post by AuxBatOn »
altiplano wrote: Sun Dec 29, 2019 11:42 pm
route
When ATC assigns you an altitude with a clearance, yes, it guarantees terrain separation.
The “and” in the ATM means it applies when on radar vectors and also when you are cleared direct a fix off airways. You cannot be on vectors and cleared direct a fix at the same time... that sentence would literally mean nothing if you had to be on vectors and direct a fix at the same time since these are mutually exclusive.
Yes but in your case you are already on radar vectors and now they are putting you in a position to go direct off their vector. It's like the wrap up of their vector, and part of that.
Going in circles here...
Once again, can you answer my simple yes/no question?
Post by ahramin »
Altiplano and AuxBatOn, the reason you two are going around in circles is that you are both correct. In Canada, which is where the incident happened, every altitude or lateral clearance from ATC should keep you clear of terrain. However, this is not true in other places in the world, and Canadian IFR training and the AIM reflect that. Even in Canada, there is nowhere in the AIM that relieves the pilots of the responsibility for terrain clearance except when on radar vectors.
I agree, there is no time, other than radar vectors, that the pilot is relieved from terrain clearance responsibilities.
I provided an example where an ATC clearance did not provide terrain clearance.
ATC will give you a direct, off airway, clearance below sector altitudes. It's not a radar vector and they aren't responsible for terrain clearance.
Everything being quoted above is right under the sections pertaining specifically to radar vectors.
The specifics of this incident are unclear, but it doesn't sound to me like it wasn't a radar vector they were on.
Post by ahramin »
altiplano wrote: Mon Dec 30, 2019 9:02 amATC will give you a direct, off airway, clearance below sector altitudes.
Not in Canada, as per the NavCanada MANOPs and AIC 19/17.
http://www.navcanada.ca/EN/products-and ... 19.pdf#top
AuxBatOn
Post by AuxBatOn »
altiplano wrote: Mon Dec 30, 2019 12:02 am You should try flying on an airway at the MEA, but below MSA and ask for a clearance direct to your destination or IAF or whatever... you'll get the clearance...
1- A controller in a radar environment will not clear you direct a fix if you are below their MRVA. They will ask you if you can climb VFR first at or above MRVA. Happens to me all the time. This absolves them of the responsibility of providing obstacle clearance in that case until you are above a safe altitude.
2- If you are above MRVA now but will get to a position where you are below MRVA, they will clear you to climb to an altitude at or above MRVA in your direct clearance.
In any case, their clearance will guarantee obstacle clearance. It is in the ATM that they have to do so.
As far as your question goes, it is to broad to answer with a simple yes or no.
For Swoop’s incident, they were on the STAR, were given an altitude to descend to (which guaranteed obstacle clearance as long as the step downs were respected), were subsequently cleared for the approach (which is the point where the aircraft was in a position to commence am approach) and instead of continuing down the STAR, elected to go direct to the IAF, which is absolutely okay. At that point, however, obstacle clearance is solely the responsibility of the crew and they failed to climb to a safe altitude given they were off the STAR.
lostaviator
AuxBatOn wrote: Mon Dec 30, 2019 9:14 am
I would argue that it is not "absolutely ok" in this case because the approach they were conducting (custom RNP) has specific instructions on how to execute the approach when cleared for it in the notes / set-up description.
ahramin wrote: Mon Dec 30, 2019 9:05 am
I don't read ATC manuals, but I know what my responsibility as a Pilot is.
The whole country, especially in the mountainous regions, is not radar airspace. Maybe it's changed, but as I said, I've been cleared direct on what was a stupid route and when I challenged the controller (Center) on the routing he said it was with my own terrain.
AuxBatOn wrote:As far as your question goes, it is to broad to answer with a simple yes or no.
It really isn't... it's pretty simple and the answer is No. You are responsible for your own terrain unless you are on radar vectors. These guys weren't on radar vectors.
But looks like these guys weren't even operating with a proper clearance.
Deciding on your own to just turn direct somewhere in a terminal environment because you were cleared an approach while on the STAR isn't reasonable either. You acknowledge that the controller wouldn't have cleared them direct because they were below his MRVA, so why did they do that? You acknowledge they weren't on vectors... so if you're going to try to cut the corner on your own, you better have your own terrain.
Ultimately it's a good thing they were in a terminal radar environment... how would that have worked out in the many other airports in those hills without a terminal controller watching them truck on down into the ground.
losercruiser
Post by losercruiser »
altiplano wrote: Mon Dec 30, 2019 10:09 am
You realize this entire conversation has been in regards to RADAR controlled airspace, right?
Obviously if you're cleared the kitimat beacon and 9000' you aren't going to go descend into a mountain....
Return to “WestJet”
