New TC Cannabis rules
Capt. Underpants
Re: New TC Cannabis rules
Post by Capt. Underpants »
bcguy2004 wrote: Sun Dec 15, 2019 6:19 pm Although I could indulge in a whole medicine cabinet of substances and alcohol and still be legal to fly the next day.
You may want to read the regulations again.
101.01 (1) In these Regulations,
fit for duty, in respect of a person, means that their ability to act as a flight crew member of an aircraft is not impaired by fatigue, the consumption of alcohol or drugs or any mental or physical condition;
602.02 An operator of an aircraft shall not require any person to act as a flight crew member or to carry out a preflight duty, and a person shall not act as a flight crew member or carry out that duty, if the operator or the person has reason to believe that the person is not, or is not likely to be, fit for duty.
Alcohol or Drugs — Crew Members
602.03 No person shall act as a crew member of an aircraft
(a) within 12 hours after consuming an alcoholic beverage;
(b) while under the influence of alcohol; or
(c) while using any drug that impairs the person’s faculties to the extent that the safety of the aircraft or of persons on board the aircraft is endangered in any way.
Blowin' In The Wind
Post by Blowin' In The Wind »
Capt. Literal
Capt. Underpants
Whatever mate. :roll: It's all there in black and white.
bcguy2004
Post by bcguy2004 »
Capt. Underpants wrote: Wed Dec 18, 2019 11:52 am Whatever mate. :roll: It's all there in black and white.
You missed my point but that’s ok.
It’s my understanding you can use Cocaine and a myriad of other banned drugs and it will be undetectable very shortly thereafter. Which is the joke about having such a hard line on cannabis, including CBD.
This is commonplace in the oil and gas industry. Many workers will indulge in hard drugs on their brief time off and still pass the piss test.
Capt. Underpants
I didn’t miss anything. I was responding to a claim that one “could indulge in a whole medicine cabinet of substances and alcohol and still be legal to fly the next day.” The regulation “literally” says you can’t. The responsibility is on the individual and I get that some see this as inadequate, but since random drug and alcohol testing has been frowned upon by Canada’s courts, there’s little else the regulator or an operator can do until a higher level of suspicion is raised.
indieadventurer
Post by indieadventurer »
It was clear to me he was using hyperbole.
OldInstructor
Post by OldInstructor »
No one has mentioned ICAO, as a signatory we have international responsibilities. For Canadian pilot licenses to be accepted operating Canadian aircraft outside of Canada I suspect a very conservative policy was required.
RatherBeFlying
Post by RatherBeFlying »
The published research on pilot, and driver, performance with cannabis is pretty sparse. As before mentioned, one paper determined that it takes a maximum of 28 days for cannabis metabolites to leave your system. Lower initial dose and BMI may result in a shorter THC elimination time. Minister Garneau used this to require an abstention period of 28 days.
A UK study of accident involved drivers showed a correlation of significant increased risk with higher levels of blood THC, but not with a lower level. This indicates that there is likely a non zero blood THC level that is not impairing, as is accepted for alcohol in drivers.
Some decades old simulator studies showed impaired performance 24 hours after consuming an entire joint, supplied from a US government source. Missing are results for 48, 72, 96 hours. I suspect that normal piloting performance would be restored in a fraction of 28 days.
Where alcohol is concerned, there is a substantial body of peer reviewed science describing:
1: impairment correlated to blood levels
2: time it takes for alcohol levels to be eliminated.
So far nothing anywhere near for cannabis.
The problem is that an unknown number of pilots who have been long term consumers of cannabis are performing their own secret trials. This number may increase now that cannabis is legal.
Far better would be studies of pilot performance over several days after partaking in a joint passed around.
losercruiser
Post by losercruiser »
As expected, it will take time before the studies are done and we know more about impairment. 28 days is likely not the final outcome, it will be much less. But until we have the data, they are being extra conservative with the rules.
I expect within 10 years we'll be down to an hours/days limit.
And I also expect as the testing systems are improved, CBD will be unrestricted. As it should be.
2R
Post by 2R »
Better shave your head if they start hair tests as those tests show everything , the keratin quality can accurately assess you sexual activity as well . They can even tell if you are an onanist without looking at the hair on the palms of your hands ;)
L39Guy
Post by L39Guy »
RatherBeFlying wrote: Sat Dec 28, 2019 3:16 pm Some decades old simulator studies showed impaired performance 24 hours after consuming an entire joint, supplied from a US government source. Missing are results for 48, 72, 96 hours. I suspect that normal piloting performance would be restored in a fraction of 28 days.
The issue is the THC residing in fat cells for up to 28 days then being released during periods of stress, just when you do not want to be getting high.
AZ382
Post by AZ382 »
What you are referring to is 11-nor-9-carboxy-Δ⁹-tetrahydrocannabinol (THC-COOH). This is a non psychoactive metabolite that is lipid soluble. When stressed your body does not turn this back into the psychoactive THC which got you high in the first place. The THC-COOH is what drug testing looks for solely because it stays in your system longer than the THC which is broken down much quicker. It gives confirmation of past use, not impairment.
Heliian
Post by Heliian »
AZ382 wrote: Tue Dec 31, 2019 6:23 am What you are referring to is 11-nor-9-carboxy-Δ⁹-tetrahydrocannabinol (THC-COOH). This is a non psychoactive metabolite that is lipid soluble. When stressed your body does not turn this back into the psychoactive THC which got you high in the first place. The THC-COOH is what drug testing looks for solely because it stays in your system longer than the THC which is broken down much quicker. It gives confirmation of past use, not impairment.
Get out of here with your factual information. This post is about fear and pitchforks, we need demons to focus our rage on so we don't look inward at our own misgivings.
It's been over a year now since Canadian legalization with no adverse effects.
stillflying
Post by stillflying »
It sucks. We can't smoke weed. But at the end of the day, for 99% of us, it's not worth pushing it. You career is worth significantly more than getting high. If you really hate life and want to drown your sorrows, you can always drink. If that's not enough, you might as well go for coke and whatever else people are doing today.
Izamarfeat
Post by Izamarfeat »
I don't understand why cannabis is considered more dangerous than, for example, tobacco smoke or alcohol. I believe that cannabis harms the body much less than beer and sometimes helps the body. For example, I use chewing gum with cannabis to calm down during stressful situations and concentrate my attention when preparing for exams. And I don't understand why marijuana is still banned in some states, even for medical purposes, although doctors have long proven the beneficial properties of marijuana for some patients.
newlygrounded
Post by newlygrounded »
Izamarfeat wrote: Thu Jun 09, 2022 1:36 pm I don't understand why cannabis is considered more dangerous than, for example, tobacco smoke or alcohol.
It’s not the danger but the difficulty in testing. I don’t feel it’s fair though
ICUP
Post by ICUP »
Mainstream consumption of cannabis is relatively new, and like anything in aviation, regulators take their precautions and time to catch up. The current 28 days policy (which includes CBD) is just a very comfortable liability cushion.
newlygrounded
ICUP wrote: Mon Jun 13, 2022 6:57 am Mainstream consumption of cannabis is relatively new, and like anything in aviation, regulators take their precautions and time to catch up. The current 28 days policy (which includes CBD) is just a very comfortable liability cushion.
It’s weird despite also being regulated by TC railways don’t have a 28 day rule
DanWEC
Post by DanWEC »
From what I know, the current guidance in Canada comes from blanket research by NASA. It's not a performance issue, but rather a testing weakness and therefore a liability cushion.
When consuming, THC and CBD compounds are absorbed into lipid tissue. During a stressful event, such as an incident or accident, fat can be metabolized to the point where there is actually a measurable concentration of partly metabolized cannabanoid compounds in the blood.
This has absolutely zero effect on performance, but it'll come up weakly positive in blood tests, which causes all those associated liability issues.
To me, what is contradictory is that they already know it's such a weak concentration that it won't affect performance, yet they still want to cover it with an extended period of abstinence.
redbusdriver
Post by redbusdriver »
One shouldn't be getting stressed during an emergency. It's why we practice those and are paid the big bucks to remain cool and do the procedure. If you're getting stressed in sim or during these events then you shouldn't be flying a plane. So it should make it a moot point about THC in fat cells during stress. And like how much are we talking about? Not enough to get you high I'm sure.
newlygrounded
DanWEC wrote: Fri Aug 29, 2025 12:41 am From what I know, the current guidance in Canada comes from blanket research by NASA. It's not a performance issue, but rather a testing weakness and therefore a liability cushion.
I remember reading this, but trains probably have more incidents than planes, if you count the dozens of minor derailments every month. It's weird TC doesn't care about liability in that case but they do for planes. They also seem to stress the airlines can have any (more) strict policy than they do, which makes it even more confusing.
redbusdriver wrote: Fri Aug 29, 2025 8:59 am One shouldn't be getting stressed during an emergency. It's why we practice those and are paid the big bucks to remain cool and do the procedure. If you're getting stressed in sim or during these events then you shouldn't be flying a plane. So it should make it a moot point about THC in fat cells during stress. And like how much are we talking about? Not enough to get you high I'm sure.
It's easier to stay cool in an equipment failure related emergencies vs an unknown 3rd party. I think most pilots would rather deal with an engine failure vs a fire or highjacker where you have no idea what their next move might be.
nohojob
Post by nohojob »
I am ready to bet that anyone getting an engine failure in real life will be getting stressed.
It is a normal and expected reaction.
Just common sense.
Hangry
Post by Hangry »
nohojob wrote: Fri Aug 29, 2025 3:40 pm I am ready to bet that anyone getting an engine failure in real life will be getting stressed.
Just common sense.
Seriously. Very bizarre to say you’d be cool and totally calm when the s*it hits the fan.
I don’t think most posters on here have any kind of real time or experience.
nohojob
Post by nohojob »
Hangry wrote: Fri Aug 29, 2025 3:51 pm
Just common sense.
I second that ! I don't think I will trust someone who isn't getting stressed during an emergency, I certainly would and it happened to me before.
mantogasrsrwy
Post by mantogasrsrwy »
I had an engine fire once. I was a bit stressed. I think I was entitled to be though.
