Finally finished reading the report. One has to shake their head when they see a training captain with 30,000 hours not pick up that they had so much of a tailwind or as it appears....any tailwind at all. On a 737-800, which seems to have a reputation of being more challenging to get to a stop, one would think that in wet snow conditions on a relatively short runway, they would be carefully checking the wind conditions. Perhaps he somehow mistakenly got in his mind earlier on that runway 14 had a headwind component and nothing was able to subsequently change that belief. It can be difficult to change a mistaken frame of reference sometimes.
As far as I'm concerned, the idea somehow the runway will not have poor braking when the conditions are reported as only a trace of snow with the temperature at zero and the visibility is down to 1 1/4(and sometimes down to 1/2)miles in frozen precip should be tossed, especially when the runway report is almost 40 minutes old. In active precipitation conditions, the runway report should be considered reliable for a very short period of time.
Of course it is likely to be poor braking and assuming anything better is highly risky on a performance limited runway. And the visual segment that the pilots get just prior to landing can be misleading. We had an incident one time in similar conditions where the view presented to the pilots was mostly dark asphalt transitioning to snow accumulation close to the the runway edges. The runway appeared as mostly wet. It was but it was wet slush with snow around the edges of the runway. The pilots were looking at bare runway through the clear slush. I know it sounds odd, but perhaps the runway edges tend to be slightly cooler and the snow doesn't melt quite as fast. Anyways, beware of a runway in wet snow conditions that appears bare and wet with a transition to snow around the edges(different in this case where there it was reported that there was an 20 foot wide strip of intentionally unplowed snow at the runway edges that was relatively deep).
Westjet itself seems to be well aware of slippery runway hazards as the report says that they have an in-house publication called an Active Conditions Modification Table as part of a procedure requiring the pilots to use a more conservative runway condition value than what is reported.
Obviously, the unecessary increased approach speed just made things much worse. One would think that the pilot would have at least selected the autobrakes to Max to show awareness of the threat of a short runway for type in these conditions(although that apparently would not have helped), especially when the approach speed is over 160 knots, which should be setting off some alarm bells.
I have always been suspicious of this idea of good braking in thin slush condition(based on falling on my ass few times while walking in such conditions) and brought the question up a few years ago in the thread linked below. People seemed confident in their replies and perhaps that was their experience. But I would assume the worst, especially in active conditions and on an ungrooved runway.
viewtopic.php?f=54&t=110996&p=977586&hi ... sh#p977586
Here is an important quote from the report....
"When the TSB investigators arrived on scene a few hours after the occurrence, the runway conditions had changed. The investigation was unable to determine the actual conditions at the time of the overrun. However, the difference in braking action between a trace, and greater than a trace, of wet snow varies from “good” braking to “medium to poor” braking. This shows a small change in runway condition can have a great variance in braking."
Another thing I think can be useful is a briefing reminder in such conditions to resist the habit of automatically reducing full reverse thrust when hearing the 60 knot call as happened in this incident. It is done so often, that it seems to be an automatic response and I have read several reports, such as this one, where the reverse is cancelled just when it is needed the most. And then a few seconds later, the pilot is desperately trying to spool up the engines again to get as much reverse thrust(the only slowing down option left) as possible while standing on the brakes with full anti-skid rendering them mostly ineffective.
The best bet would have been to continue the originally planned approach to runway 05(if allowed) with minimums slightly higher than the ceiling and hope to get the required visual references.
