Westjet Delta JV
chromeuser
Westjet Delta JV
What sorts of expansion may we be expecting once everything is said and done? Will Encore see changes to accommodate this partnership?
seriousflyer
Re: Westjet Delta JV
We need the max for alot of Westjet network growth, but what we will see through the JV is alot of growth in our load factor on our wide bodies to international destinations. We already have exceeded our widebody loadfactors targets for an intial launch. With that being said, flying 10 widebodies full time throughout all seasons and markets takes good solid feeds and alot of feeds. If Westjet orders another 10 WB, think about the feed required, thousands of travelers, canadians and americans, to fill those seats to make the load factor consistenly full, is what the JV is primarily providing WJ. One perspective.
AC is did the same with United JV.
Commonwealth
I see in the ALPA magazine Delta pilots have asked the DOT to consider scope protections if the JV is approved.
As they should.
I don't want to see WJ pilots doing what used to be Delta flying for 1/5th the cost.
goingnowherefast
AC should pay Delta rates, SWA rates are for WJ.
We should all be seeking to earn what our colleagues to the South are making. They are still making gains while we wallow in Canadian mediocrity.
We’ll be getting Delta rates now that ALPA is here.......oh wait, never mind....
Duke Point
You're nuts if you think a well organized pilot group like those at Delta are going to let WestJet siphon off long haul feed. WestJet expansion at the cost of Delta jobs just isn't going to happen. Dream big though.seriousflyer wrote: ↑Tue Feb 18, 2020 9:53 pm We need the max for alot of Westjet network growth, but what we will see through the JV is alot of growth in our load factor on our wide bodies to international destinations. We already have exceeded our widebody loadfactors targets for an intial launch. With that being said, flying 10 widebodies full time throughout all seasons and markets takes good solid feeds and alot of feeds. If Westjet orders another 10 WB, think about the feed required, thousands of travelers, canadians and americans, to fill those seats to make the load factor consistenly full, is what the JV is primarily providing WJ. One perspective.
They're way to savy for that.
DP.
[/quote]
DP.
[/quote]
I would agree. Ask any former Canadian pilots how the distribution of flying worked out with the AA pilots.
DP.
[/quote]
No one at WestJet has dreams of taking flying away from Delta.
The JV gives Delta a competitive response to the Air Canada/Rouge encroachment into the US, which hasn’t gone unnoticed by the Big US3.
In the past 5 years, Air Canada added 30 or so more widebodies over the Atlantic. The US3 don’t like that and with the JV, Delta can fight back.
'97 Tercel
goingnowherefast
It makes sense. All 6th Freedom stuff. Want to fly Seattle to JFK? Book on AC connect through YYZ. The big US 3 are right to be pissed.
AC is also feeding US travellers through YYZ and YUL to Europe and through YVR to Asia. Problem is AC needs to serve a ton of US cities. Delta wants to feed it's international routes with WJ as the feeder from the Canadian market. Want to fly from Saskatoon to Asia? Go YXE to YYC on WJ then connect on Delta to Seattle and on to Asia. Benefit is Delta doesn't need to serve as many Canadian cities, everything gets fed into a few key Canadian cities and off one of their international hubs. They've got that Canadian feeder network outsourced and piggybacking on WJ.
Sharklasers
Except your first scenario is cabotage and is illegal and doesn’t happen. The booking software won’t allow it.goingnowherefast wrote: ↑Wed Feb 26, 2020 4:08 pm It makes sense. All 6th Freedom stuff. Want to fly Seattle to JFK? Book on AC connect through YYZ. The big US 3 are right to be pissed.
I don't see cabotage there...
SEA-JFK via YYZ?
You could do that whole trip on an American or Canadian carrier or a combination of. That's all 3rd and 4th freedom stuff...
Cabotage would be AC operating SEA-JFK direct.
SEA-JFK via YYZ?
goingnowherefast
I didn't believe it either until I tried to book that on AC's website. It didn't let me, so Sharklaser is correct. You could make 2 seperate bookings. That's a PITA and nobody will do that.
Still permitted to book SEA - YYZ - LHR on AC where the big US 3 want you to book the trip with them.
The Delta JV will allow you to book on WJ to go YXE - YYC (switch to DAL) - JFK - LHR. WJ gets a domestic passenger and Delta gets international passenger. The other option would be to book on AC and go YXE - YYC - YYZ - LHR
Well actually the options on AC are YXE-YYZ-LHR or YXE-YYC-LHR
Interesting. Maybe it is as a single itinerary. Or is that a limitation of the booking sight? Or an agreement to not allow bookings like that? Connecting through your home country should exclude it as cabotage I would have thought.goingnowherefast wrote: ↑Thu Feb 27, 2020 9:09 am I didn't believe it either until I tried to book that on AC's website. It didn't let me, so Sharklaser is correct. You could make 2 seperate bookings. That's a PITA and nobody will do that.
Why would Delta be trying to use WJ lift to fly overseas?goingnowherefast wrote: ↑Thu Feb 27, 2020 9:09 am I didn't believe it either until I tried to book that on AC's website. It didn't let me, so Sharklaser is correct. You could make 2 seperate bookings. That's a PITA and nobody will do that.
It makes zero sense.
It makes more sense from AC's perspective to use the regional lift to access the USA market and bring them to Canada. But for Delta to be the lift that brings Americans to fly on Canadian aircraft overseas doesn't' make sense to me.
goingnowherefast
That's not what I said. Fly from Canadian city to Canadian city on WJ. Hop on a Delta plane to fly from CanadiancCity to US city. Continue on Delta plane from US city to international city. WJ isn't doing anything international. Example: with WJ, fly YXE - YYC. Then change to Delta to fly YYC - JFK - LHR.derateNO wrote: ↑Thu Feb 27, 2020 12:05 pmWhy would Delta be trying to use WJ lift to fly overseas?goingnowherefast wrote: ↑Thu Feb 27, 2020 9:09 am I didn't believe it either until I tried to book that on AC's website. It didn't let me, so Sharklaser is correct. You could make 2 seperate bookings. That's a PITA and nobody will do that.
That way Delta doesn't have to send a plane to YXE for the limited demmand that they would get. Outsource that to piggyback on WJs domestic network.
Ok that makes more sense. Delta is trying to do what AC is doing. Get Canadians to go to the USA to fly overseas. The only problem I see with that is often that means 2 connections. Whereas AC is able to access a lot of the large markets with direct flight to YYR/YYZ/YUL and funnel overseas so it works well.
Time will tell if people go for it. At the end of the day 99% of customers care only about price so it will need to be competitive.
And here we are now, March 23, 2020 and the real question is: how many jobs will be left after the virus is defeated (IF) and how long will it take to get back to square "1"?
goldeneagle
chromeuser
The virus will be defeated. There is no doubt about that. This will be a long drawn out recovery...this pandemic is of a scale that is new to the smaller modern world with intertwined markets and economies. The situation is fluid and changing everyday.
Survival mode is the name of the game now. With that in mind, it will be atleast a year imho. Minimum.
It's humbling to discover that now your previous skills are worth 1/5 the cost of what WJ was paying you to drive for Uber.
