Cargojet stll hiring
SAR_YQQ
Re: Cargojet stll hiring
Post by SAR_YQQ »
Must be a union thing, but why does it matter if it is WB or NB? Is a WB Jet harder to fly, requires more piloting skillz?
Can’t be a responsibility of passengers thing - since Cargo Jet WBs carry zero PAX.
SAR_YQQ wrote: Mon Apr 06, 2020 12:58 am Must be a union thing, but why does it matter if it is WB or NB? Is a WB Jet harder to fly, requires more piloting skillz?
Productivity.
How much more do you carry on in a 767 vs. a 727. How much faster and further do you carry it.
rudder
Post by rudder »
CJ pay rate applies to both 757 and 767.
CJ starting FO pay well above what AC (or anybody else) pays.
CJ top scale CA rate around $200k.
Work schedule 14 days in a 30 day month and 15 in a 31 day month.
Far from perfect but CJ is in a different segment of the industry. Not sure that Morningstar is close to this. Morningstar pilots also in the process of voting on switch from UNIFOR to ALPA representation. CJ pilots are UNIFOR.
RippleRock
Post by RippleRock »
Look Junior (Telex), go to www.airlinepilotcentral.com and look for yourself. If you haven't checked out the pay scales yet, you have no idea what you're even asking.
Why not compare worldwide compensation? Its the same job. Are Americans worth more than Canadians? Are they better than you? Should we have fewer dollars in our pockets after the taxman hits? Should our self worth be considerably less because we live north of the 49th parallel?
On what basis are you justifying -significantly lower- compensation?
Time for you to answer a few questions.
telex
Post by telex »
RippleRock wrote: Mon Apr 06, 2020 8:37 am Look Junior (Telex), go to www.airlinepilotcentral.com and look for yourself. If you haven't checked out the pay scales yet, you have no idea what you're even asking.
I'm not justifying lower compensation. I never even suggested it. But you have determined that is my position.
So, same question.
What do you consider minimum salary for a widebody skipper in Canada?
Zanzibar
Post by Zanzibar »
I wonder how many they need to hire? Did anyone get offered a position? I saw they mentioned a start date of today in the ad.
CFM Symphony
Post by CFM Symphony »
RippleRock, the flaw in your thinking is that it's based on self-righteousness. You value a socialist system when it comes to a pilot wage standard, but despise it when it comes to taxation ("socialist Liberal handout"). You can't hold these two opposing ideas simultaneously except if by doing so, you stand to benefit.
doiwannabeapilot
Post by doiwannabeapilot »
The WB is way harder to fly; takes twice as much muscle to flare since the plane is heavier.
mad skillzzzzz
Picesprick
Post by Picesprick »
To be fair, the senior guys at cargojet do quite well for themselves. Hence the low starting pay for new captains.
The last negotiating committee along with the unifor rep, strong armed the last agreement though where a good chunk of the membership didn't get a chance to vote as they were on the road working or on vacation. 3 days of voting will do that.
So now senior guys are making 200k, fly maybe 40 hours a month, spend a lot less time on the road ( 15 days of work but the 2255 check ins and 0045 finish times make that a breeze), easy flying ( day flying) get all the overtime they they want or available if money is the target where senior captains are
pulling in 300k, Fos 150-200k.
So not that bad for a wide body skipper, if your senior 😉
Yycjetdriver
Post by Yycjetdriver »
Picesprick wrote: Mon Apr 06, 2020 8:06 pm To be fair, the senior guys at cargojet do quite well for themselves. Hence the low starting pay for new captains.
Could just be a smart bet on the companies part. Dangle the carrot for high pay once you become senior so you can under pay “junior” captains. Then they may hope that before they have to dish out the bigger bucks the night flying takes it toll.
Picesprick
Yycjetdriver wrote: Mon Apr 06, 2020 8:20 pm
There certainly seems to be some truth to that unfortunately.
Gabe_to
Post by Gabe_to »
Hey everyone!
Kind of a random question but I'm hoping you can shed some light.
I see many pilot jobs that will send you all over the country and you're far from your base for a few days.
Is there such a job (FO or captain) in this industry where you're home everyday with a decent schedule?
Or does the entire industry requires you to have garbage sleep patterns?
Thanks in advance for your replies!
ayseven
Post by ayseven »
Kind of a troll-like question, but here goes: I am only going to comment on my own experiences. People fly because it is too far to walk. Most flying jobs involve some kind of travel - sometimes 1/2 hour away from home base, other times a time zone or two away. I have never had a schedule; when the boss says GO! I said YESSSSS!. Sometimes you get home every night, but it is not 9 - 5, M - F, anywhere I know of, instructing excepted. I always slept well, but apart from the job, I was good at keeping myself busy. Home is wherever you end up. You need to be adaptable, no matter where you end up working, but that probably should go for any job. For myself, I was never bored, not one single hour.
Ash Ketchum
Post by Ash Ketchum »
Does anyone know if Cargojet is still considering FOs without a 767 type rating or are only guys with type ratings getting interview calls? Thanks
Kaykay
Post by Kaykay »
Ash Ketchum wrote: Tue Apr 14, 2020 11:12 am Does anyone know if Cargojet is still considering FOs without a 767 type rating or are only guys with type ratings getting interview calls? Thanks
I don’t know for sure but my assumption would be only the rated folks at the moment. There’s probably lots who are qualified and the current posting implies they want rated people only.
Ash Ketchum
Kaykay wrote: Tue Apr 14, 2020 1:16 pm
That's, what I'm thinking too, not many other options out there for all the laid off airline guys at the moment.
complexintentions
Post by complexintentions »
RippleRock wrote: Sun Apr 05, 2020 11:56 pm When a wide body Skipper position is paying slightly more than —half— the Canadian industry standard.........that’s a garbage wage.
Don’t even try to compare it to US cargo carriers cuz it’s 40% worse than half of garbage.
There comes a financial break point where the responsibility, cost of attaining the position and keeping it doesn’t make financial sense.
Yes, these are extraordinary times, but they don’t justify poor compensation. To do so gauges ones self worth.
I’m entitled to my opinion.
The amusing part is the ones pissing on the job and wage generally don't have the rating or anywhere near the experience to remotely qualify for a DEC widebody position.
Yet, aren't shy to state how it isn't enough for them. Good for you, holding out for the big bucks! :mrgreen:
NotDirty!
Post by NotDirty! »
complexintentions wrote: Tue Apr 14, 2020 2:32 pm The amusing part is the ones pissing on the job and wage generally don't have the rating or anywhere near the experience to remotely qualify for a DEC widebody position.
I don’t think it’s necessarily bad from an academic perspective to criticize wages. I may not be qualified for said position, but I have an idea of what an appropriate salary is.
Improved wages and working conditions at any company help all of us. I believe that the pilots at my company are worth more than we are paid, but as the overall pay scale is better than most other equivalent Canadian operators, it is difficult to make gains.
People often point to the much better wages south of the border. These came about because each pilot group fought to match or beat the competition’s pay scale.
At a previous company, I worked to make real improvements for the wages for the junior pilots; it didn’t improve my career, but it had a positive impact on the newer pilots, the company, and the industry as a whole. That should be the goal of every pilot!
ayseven
Post by ayseven »
Wages: companies pay what they can, to get and retain the best people they can. Costs for non-type rated people are very high, hence the low (ish) starting wage - they have to make the money back before they can give it to you. I would assume fairly small profit margins for places that demand training bonds. And later on, the more money the airplane makes for the carrier, the better the pay - size is often part of the equation but not always. Air Canada, and every other carrier in the world does this. One way or another, they have to make money on you before you can get any money from them. It is just simple business math. I always thought this was obvious.
Zanzibar
Post by Zanzibar »
As of this morning they are still looking for type rated only from the HR lady.
Gabe_to
Post by Gabe_to »
ayseven wrote: Tue Apr 14, 2020 10:08 am Kind of a troll-like question, but here goes: I am only going to comment on my own experiences. People fly because it is too far to walk. Most flying jobs involve some kind of travel - sometimes 1/2 hour away from home base, other times a time zone or two away. I have never had a schedule; when the boss says GO! I said YESSSSS!. Sometimes you get home every night, but it is not 9 - 5, M - F, anywhere I know of, instructing excepted. I always slept well, but apart from the job, I was good at keeping myself busy. Home is wherever you end up. You need to be adaptable, no matter where you end up working, but that probably should go for any job. For myself, I was never bored, not one single hour.
Thanks Ayseven! I hear ya. I have a pretty tight family and it's hard to stay away for too many days but I love flying.
From what I read, in some cargo companies you're home almost everyday but as you said, flexibility is necessary and I'm sure every so often you'll get stuck somewhere!
florch
Post by florch »
Gabe_to wrote: Tue Apr 14, 2020 9:17 pm
There is a variety of flying at most companies. Thankfully not every pilot wants the same flights, but generally the better schedules go senior of course. There is no chance of not paying your dues in terms of lifestyle. You will pay it by being away from home, working or being stuck in a hotel on weekends and holidays, and working very early mornings (up at 3 is common), nights (cargo especially) or split shifts. I happen to love long days because it equals more days off at my company. You WILL miss some birthdays and Christmases. You may find a job that works for you and that is awesome, most of us have. We all know people that have decided to forego an upgrade, better job or bigger airplane because they finally got a livable schedule. Everyone is trying to find a work life balance, and if you have some mental flexibility maybe you can make it work. Your family needs to be supportive because it does take a toll on them. They may learn to love your lifestyle too: big chunks of days off and never have to shop on a weekend again. But you need to wrap your head around paying some dues early in your career.
Jerry Boyle
Post by Jerry Boyle »
To each his own. One person's "Garbage" is another person's treasure. There are many reasons we are not all fighting over the same jobs.
If you can mark an X you are my kind of people.
JohnnyHotRocks
Post by JohnnyHotRocks »
I understand that initial training is down in Atlanta and those sims are not currently available due to the pandemic.
schnitzel2k3
Post by schnitzel2k3 »
Hence only type rated flight crew need apply until this pandemic is over.
