Missing aircraft near Langley BC
boeingboy
Post by boeingboy »
A witness saw a plane crash into the Fraser river near Fort Langley BC. No mayday but Boundary bay airport reports 1 plane overdue. The flight plane had them no where near that area.
https://www.msn.com/en-ca/news/canada/r ... li=AAggFp5
AirFrame
Re: Missing aircraft near Langley BC
Post by AirFrame »
Sounds like it's a student and instructor missing in a school plane. If it was a lesson, the flight plan was probably "Local East" and that could mean anywhere in the Fraser Valley (or, I guess, the Fraser River :( ).
Capt. Underpants
Post by Capt. Underpants »
Which flight school?
bald seagull
Post by bald seagull »
yeah yeah
Post by yeah yeah »
Just bumping this thread. Any further news?
boeingboy
Post by boeingboy »
Not much - just that the last radar return was at 60 meters - eastbound over the river
https://www.msn.com/en-ca/news/canada/p ... li=AAggFp5
boeingboy wrote: Wed Jul 08, 2020 6:44 pm Not much - just that the last radar return was at 60 meters - eastbound over the river
On 06 June 2020, Cessna 172M (registration C-FCCV), operated by International Flight Centre
Inc., was conducting a local training flight from Boundary Bay Airport (CZBB), BC, with 1 student
and 1 flight instructor onboard. At 13:12 Pacific Daylight Time (PDT), the aircraft disappeared from
radar over the Fraser River at approximately 11 NM ESE of Pitt Meadows (CYPK), BC. The aircraft
was last recorded travelling eastbound at an altitude of 200 feet above water with a ground speed
of 80 knots. The aircraft remains missing and the fate of the crew is unknown; the RCMP is leading
the search.
The aircraft was last recorded travelling eastbound at an altitude of 200 feet above water with a ground speed
of 80 knots.
Which changed to x feet below the water, with a speed of 3 knots westbound with the current?
7ECA
Post by 7ECA »
Quite an odd occurrence, I mean the total lack of information around the time of the incident makes it seem even more bizarre.
At the time, the Fraser River was running high and fast with the freshet. During those times, it's got a ripping current.
I do find it hard to believe that a 172 went into the River, and there's been no trace of it seen since. Seems rather unlikely that it would have sunk right to the bottom and stayed there...
stabilizedapproach
Post by stabilizedapproach »
https://www.tsb.gc.ca/eng/rapports-repo ... P0060.html
Final report is out. Collision with a power line due to low level flight. Very unfortunate event.
7ECA
Post by 7ECA »
Bizarre, is about the only word I can come up with to describe this occurrence/accident.
How is it, that to this day, not a single piece - nor any trace of the aircraft or occupants has been found?
telex
Post by telex »
A bizarre event indeed.
But apparently there is a B777 that is also underwater that is still missing.
Schooner69A
Post by Schooner69A »
Never low fly in an area you haven't recce'd before. And never make a second pass... :D
Heliian
Post by Heliian »
telex wrote: Mon Jan 11, 2021 8:35 pm A bizarre event indeed.
They found pieces of that 777, probably all thats left after a high energy impact.
A 172 should be easy to find in a much smaller body of water.
The report mentions the heights required for obstacle avoidance, but doesn't mention the requirement to be more than gliding distance from shore. It's possible the investigators assume that the engine wasn't effected by the strike, or that the impact stalled the aircraft or otherwise rendered it unflyable I guess.
I also find it extremely odd that the aircraft hasn't been located.
Well... pieces of the 777 found civilization...
How far would a 172 drift in the current of the Fraser River? To the ocean? Would anything stop it? I once found a submerged body which we had been searching for 800 feet away the day before, and that was much less than one knot of current in a lake. The last time I flew floats off the Fraser river, the current was at the limit of my comfort level, I think eight knots or so? 30 NM to the ocean? How long would that take if nothing hung it up? 4 hours?
I found this paragraph interesting......
"Obstacle collision avoidance system
In 2008, BC Hydro implemented an obstacle collision avoidance system (OCAS) on spans of power
transmission lines along known aviation routes as a trial at 4 sites in the province, including the
occurrence site. The system used active radar, radio communication, and strobe lights to warn aircraft
if they were on a collision course with the monitored span. Because the system used radar, its
operation was independent of any equipment on board the aircraft.
In 2014, the private company that was supplying BC Hydro with support for the OCAS equipment
ceased operation. Because OCAS relied on the real-time monitoring that the company provided, when
this ended, BC Hydro was forced to stop using the system and all 4 OCAS in the province were
deactivated. At the time, there were no other certified alternatives."
Has anybody had any experience with this system?
Scuderia
Post by Scuderia »
pelmet wrote: Tue Jan 12, 2021 9:17 pm I found this paragraph interesting......
The Peak 2 Peak Gondola in Whistler, BC has an OCAS although I have had a hard time finding specific information about it aside from on the information boards in the facility.
When skiing a few weeks ago I asked a technician at the gondola and was told that it broadcasts on all frequencies 118.000-136.975 "POWER LINES, POWER LINES". He didn't know whose system it is or its current status, so it very well could be out of service now like BC Hydro's.
Maybe someone from the local helicopter ops is familiar with it.
Yes, in 2009 I was doing some helicopter evaluation flying up and down the Fraser River east of Langley. As I approached the wires crossing at Mission, on any radio frequency turned, I could hear fading in to a crescendo, then fading out: wires - wires - wires - WIRES - WIRES - WIRES - wires - wires - wires ... It certainly gave enough warning to make a correction, and was an effective system. I don't know what one heard with radios off, I presume nothing, but I guess you'd not be NORDO there anyway. I didn't realize the system was not still in use...
PilotDAR wrote: Wed Jan 13, 2021 6:15 am
Does that mean that every IFR frequency into Vancouver hears this statement and if some helicopter was bussing around for fun for 20 minutes, that those frequencies would be blocked up with continuous 'Wires' transmissions?
goldeneagle
Post by goldeneagle »
pelmet wrote: Wed Jan 13, 2021 10:04 am Does that mean that every IFR frequency into Vancouver hears this statement and if some helicopter was bussing around for fun for 20 minutes, that those frequencies would be blocked up with continuous 'Wires' transmissions?
Here is a description of the system
https://www.aviationpros.com/home/news/ ... l-airspace
The message includes warning tones and a description such as "POWER LINES. . .POWER LINES." The OCAS system has the ability to simultaneously broadcast on several frequencies within the VHF range of 118-136 MHz. The FAA/FCC will determine acceptable broadcast plans based on the geographical location of the system.
Sounds like it gets a pre-determined set of frequencies based on location. From the other description above, sounds like it's very low power which gives the effect of 'increasing volume' as you get closer, then fades quickly as you go away. Typical of a system with only a few milliwatts of output.
I trust not. I have the sense that it was a deliberately low power transmission for very local traffic only. I am not expert in the system design, I was a user, not a designer.
Heliian
Post by Heliian »
PilotDAR wrote: Tue Jan 12, 2021 2:14 pm
No, the river bottom is probably so full of debris from logging that sonar would be useless, it would drift until it caught the bottom, it's probably only a few miles or less from the impact site. Most likely tucked into a bank.
They'll need to do an underwater mag survey during a dry season to find it.
MattW
Post by MattW »
My farm is right at that powerline crossing. The wires get hit every few years. The warning system has been inoperational for some time, the tower lights got shot out on New Years Eve several years ago. They've just now activated some good lighting on the towers again.
That crash was very weird. To hit the water and have only the one person see it, and disappear without a trace was incredible. The river was running very hard when it happened, 10 knots of current in the main channel easily. My feeling, observing the search, is that they didn't take the current into account sufficiently, they were too far upstream. But still, nothing ever seems to have floated up. My wife and kids were all in the yard when it is said to have happened, I don't doubt that they hit the lines but nobody saw or heard them do it, in past experiences you would see the lines rocking. When hydro investigated they found only very minor damage to one line, the crew working on the line deals with quite a few airplane strikes and said they were surprised to see so little damage had led to a crashed plane.
Sad all around
MattW wrote: Wed Jan 27, 2021 3:41 pm My farm is right at that powerline crossing. The wires get hit every few years. The warning system has been inoperational for some time, the tower lights got shot out on New Years Eve several years ago. They've just now activated some good lighting on the towers again.
I wonder if there might be a simple solution.....
Instead of spending huge amounts on fancy systems, could a larger version of this work.......
https://www.reddit.com/r/aviation/comme ... aplane_ad/
