Dinny wrote: ↑Thu May 30, 2019 9:51 am
Someone with the name Appame posted the questions he remembered from the exams above, I was mentioning him because it matched the questions I recieved during my exams.
Which book did you use for AME-M and CARs ?
For the M exams, I used handed down notes from people who had done the exams with the jeppesen study test prep book.
On its own, the jeppesen book isn't enough for the canadian exams.
Send me your e-mail in a PM and i'll send you the study notes I used
CARS is super easy, going through the study guide CARS for AME is all you need to pass.
Hi Dinny,
I am working so hard on tech exam. it would be very very helpful, if you can send your notes to me. page0705@hotmail.com
Hi can I send you my email I need the study nots for m1 technical exams and which study guide should I follow, thank you Alialattar10@outlook.com
Laraujo wrote: ↑Sun Jul 05, 2020 8:47 pm
Hi Dinny,
Could you send me your material? I am studying for Powerplant exam. Thank you! leandrovaraujo79@gmail.com
Hello Dinny. Greetings. Can you please send me the study materials. I'm currently preparing to do all three exams. m_a_beharry@yahoo.com is my email.
Hi Dinny,
If it is still available, could you share the study notes? xorud00@gmail.com
Thanks bro
Maplejet wrote: ↑Wed Dec 11, 2019 10:45 am
Hey, Dinny would you be able to send me your study notes I'm Preparing to write the ame exams and anything you have would be greatly appreciated. maplejet@hotmail.com
hey dinny would be awesome if you would be able to send me study notes. im not too good with exam stuff im more hands on.. thanks my email is robi_99_7@hotmail.com
Hey, donny would you be able to send me your study notes I'm getting ready to write my airframe and standard practices. Coltonabel87@gmail.com thanks
pls send me any notes for side notes you have so i can take the M2 AME writtens. I came from USA and im struggling to get info on what the m2 writtens contain... jalalp@hotmail.com
Wondering if anybody out there still uses Avcanada, I am writing my AME tech exams next week and I am studyin from the Jeppenses test guide and ASA text guide books (They are basically the same by the way). I've seen a lot of people posting that this are the books to study but, has anyone passed the exams just by studying this books? I am aware that you pretty much have to know the entire book cover to cover but, do they even cover what transport canada is asking?
I am FAA A&P licensed and studying for that licensed was way easier since in the U.S study material is published, but in Canada they pretty much leave you on your own, Yeah I know they have that guide that tells you the Topics that you will be tested on but there is no Trasport Canada study material like you find with the FAA.
Dinny wrote: ↑Fri Mar 15, 2019 5:48 pm
Just did my standard pratice last week and airframe today for the M exam i can tell you that my exam questions almost matched 100% with what APPAME posted.
Mbg as for the S license exam i talked with the S guys at work and he said the standard pratice was simliar to the M license, but that a lot of Airframe questions were from AC 43.13
Hi Dinny.
Do you still have copy on those notes for the TC AME tech exams? if you still have them,
can you send them to my email Matutinaf@yahoo.com ? thank you.
Can you guide me these Question are related to TC Technial exam?
They are multiple choice questions with the usual 4 options, the question are on an archaic computer system, you'll need to bring a calculator, they'll provide scrap paper and a reference sheet of all approved aviation acronyms so don't waste your memory on those…
Here's some questions I can remember from the exams, they should give you an idea of the kind of questions you could see,
Standard Practices:
Number of faces in an isometric drawing?
Title block location in engineering drawings?
Sharpest bend permitted in aluminium sheet?
Bearing that can take radial loads?
Tool to find center of a shaft?
Bend radius allowance is what % of original diameter?
Which flared fitting can be identified by a shoulder between thread and flare cone?
Shear strength of a 2017T3 ‘crack free’ rivet?
Instrument air identification marking?
The diagram that demonstrates principal of operation is a what?
Aluminum forming without annealing should be done immediately after what? Ageing - heating - quenching - anodising.
NDT with least surface prep?
Acceptable time slot to test ELT’s?
Volume of a cylinder?
1 microvolt =?
Pascals, daltons, and Boyles laws?
Understand Ohm’s law and power (watts) and their calculation.
Electrolyte in a NI-Cad?
AC power in a capacitive circuit, current or voltage, leads or lags by how much?
Working voltage of a capacitor in an AC circuit should be how many time (or not) the actual voltage?
Terminal lug of a 20 gauge wire is what colour?
9 in binary?
A metals ability to be deformed is called what?
Monel consists of what % of nickel and alloys?
Hydraulic identification label?
Flash point is what?
AN bolt with 2 dashes?
Jo-bolt is what kind of fastener?
How many threads should be showing on a turn barrel?
A Skydrol hose can be identified by what?
Airframe:
Air flowing in thin sheets over a wing with no disturbance between layers is?
As airflow moves to trailing ege, boundary layer becomes?
Form drag can be classified as?
Chord=100” fwd CP is located what % from leading edge?
Aspect ratio 144sg.ft, span 24’, width?
A winglet does what?
Type of load when FWD press on elevator causing centrifugal force in opposite is??
Wing loading formula?
A difference in wash-in/out between wings is used to compensate for?
In differentially rigged ailerons which (up or down) moves more?
Doped patch repairs may be used on fabric covered surfaces if it doesn't exceed what size?
What would you clean bead seats with?
Compensating valve on a master cylinder does what?
Oleo initial shock is absorbed by?
Sluggish, jerky brakes on a multi-disc brake could be caused by?
2 major shimmy damper components?
Micron filters filter to what micron?
Type of pump used for high press (hyd)?
In a hydraulic system the relief valve with highest press setting is?
Manual control, cabin press to 3500’ at 8000’ climbs 500’ cabin alt now?
AC gens charge batteries through?
Static test leak down rate (ft/min)?
Fully integrated auto pilot controls around how many axis?
2 functions that can be selected to control alt?
A helicopter in forward flight changes course by?
Coriolis effect is associated with?
Helicopter artificial feel comes from?
Conical bearing are capable of what types of loads?
Moveable h/stab on a helicopter do what?
Vibration type associated with an out of track condition?
Constant amplitude vibration despite RPM change is associated with?
Tail rotor could fail to compensate if?
How would a tail rotor be dynamically balanced?
Powerplant:
3 primary factors affecting gas turbine thermal efficiency?
Highest press area in a turbine engine?
% energy absorbed by fan on a turbojet/fan?
Ball bearings on a shaft absorb what loads?
variable inlet guide vanes are actuated by?
Increase oil temp with no power change indicates what on a jet?
Oil in a turbine picks up most heat where?
Oil temp reg on a dry sump is located between which components?
Erratic oil press indication could be?
Starting sequence (turbine)?
Inflight flameouts are usually caused by what?
When does the starter disengage?
Turbine ignition systems are rated in?
Tacho-gen consists of?
Electronic tq ind. system includes cockpit indicator and?
4 lobe cam ring on 9 cylinder radial will rotate at?
What measures temp increase compared to a reference?
Oil in had lifter comes from where?
Compensator cam in radial mags operate at?
Cowl flap on ground should be in what position?
What component is distinctive of high tension mags?
How is an exhaust cabin heater inspected?
A radial with #1 at TDC #3 holds no press on compression tester, indiction of?
Excessive blow by on new rings is probable what?
Least likely to occur in direct fuel injection?
0.003 oversize stud prefix P003, colour of stud?
Front cone of prop consists of?
[/quote]
Not sure why you would want to start the arduous process of getting a licence to work in such a garbage industry. But I seem to recall a few questions based on a Beech 18 and a 727. Those are two super relevant aircraft in 2022 so it is why Transport Canada through their infinite leadership and genius like qualities feel you should know about. They also like the colour red, not sure why. Have you thought of pursuing any other trades? Give it a few years you’ll know why I asked. Good luck.
-42 wrote: ↑Sat Apr 30, 2022 8:10 am
We know why some do it. I can honestly say I’ve never seen the industry in worse shape than now in the decades I’ve been in it. Globalization has killed any hope of Canadas industry ever improving. That and the red tape around every and anything that could feed the industry the feds have wrapped things in since 2015.
Good afternoon noon Dinny,
I'm interested in your notes for the tech exams. I'm studying for the tech exams for the M1 license.
I just registered to use this the avcanada forum. This forum will not let me private message you till I have made enough posts on this forum. Could you private message me your email address. My they will let receive messages.
Thank you
Good evening everybody,
I'm in need of help as well could any of you kindly send me notes for Airframes or Powerplant? I'm having a little trouble attempting them.
