Raymond,Raymond Hall wrote: ↑Mon Jul 13, 2020 11:09 pmI am not suggesting that you should not have access to and post on this Forum. All I am saying is that with the dozens (hundreds?) of posts that you have made on this Air Canada Forum, especially about all of the issues of mandatory retirement and seniority in respect of the Air Canada collective agreement and in the posts that you have been openly critical of my viewpoints and actions in regard to same, you now disclose that you are not even an Air Canada pilot. A total absence of transparency, to this point.
With respect to your speculation that I may have at one time or another breached my obligations to meet my own employment obligations re fatigue, given my external involvements, why don’t you throw some more spaghetti at the wall to see what sticks.
My record in meeting and exceeding the employment requirements speaks for itself, including the total absence of any disciplinary or other incidents whatsoever. So, try some other form of defamation, if you must. Don’t you think that, given my public condemnation of the senior Air Canada management’s actions when I was MEC Chair, the management would have loved to find some peccadillos in my operational performance? It didn’t happen, for good reason. I did my job to the required specifications and greater.
One thing that differentiates me from almost every other single contributor to this Forum is that I post in my own name and stand by my record, which is obvious for everyone to see and criticize. You are clearly not willing to do the same.
I think you may have mixed me up with another poster, I went back and here is a post of mine regarding fly past sixty directed to you,
Here is another,“Re: No Clear Winner in FCA Mandatory Retirement Decision
Edit Report Quote
Post by mbav8r » Mon Feb 22, 2016 6:23 pm
Raymond, I am not involved in this but have been following it for a long time, maybe even right from the outset. Some questions if you don't mind.
When you originally started the fight, for lack of a better term, was it illegal or in your opinion, illegal?
You mentioned that it had to be the normal age of retirement and at the time federally it was age 60, I believe. The reason I mention this is because it had been considered normal to retire at 60, therefore it was likely a matter of opinion that what was going on, at least at the time, was completely legal.
So, I get what Fanblade is saying, if at the outset it was recognized the change was going to negatively affect a group that had expectations and instead of forcing change, approaching with a little give and take might have changed the response.
Do you honestly believe that if the fp60 group had approached with some type of compromise or acknowledged a compromise would be needed, instead of forcing the issue on them, that wouldn't have changed the response?
An honest question, not trying to antagonize”
“Thanks Raymond, didn't realize how far back that went, also quite interesting how the demographic shift caused the ratio difference to effectively challenge it.
Do you know when it was Jazz changed retirement to 65, is that when the ratio shifted?”
