Air Sprint Questions
AirSprintInc
Re: Air Sprint Questions
Post by AirSprintInc »
hamstandard wrote: Mon Feb 10, 2020 12:09 pm
AirSprintInc wrote: Mon Feb 10, 2020 10:33 am
hamstandard wrote: Sun Feb 09, 2020 8:29 pm Hi,
I am not sure I have ever seen how many days in a row one can consistently have off using the various schedules(probably 14/14).
It would be helpful in some decision making.
We try to make the schedule as flexible as possible and the number of consecutive days off can be as little as 3, with no limit on the other end. If you are on the 14/14 schedule then you have 14 days off to play with in any given 28 day block. There is a max of 8 consecutive work days at a time (up to 13 if you sign an optional waiver), and generally the longer you're available to work, the longer the stretches of days off can be. Commonly we see 7 on and 7 off for the 14/14 folks. But, some like to run longer shift.. example: 13 days on, 14 days off and and then back into work.
Thanks for the information,
Is one able to consistently get 14 in a row off similar to a rotational job.
In order to consistently get 14 days off in a row you would need to consistently work longer stretches (say 13 consecutive work days). There would certainly be some less off day stretches, simply based on the system trying to keep everyone happy, but you would probably see an 85-90% success rate assuming that's all you were asking the bidding system for.
- Adam
hamstandard
Post by hamstandard »
Hi,
Is the company still hiring to expand the eastern bases?
AirSprint HR
Post by AirSprint HR »
hamstandard wrote: Wed Mar 18, 2020 7:16 am Hi,
We are going to take a breather for the next 45 days and see what the environment looks like after. Regrettably, this week we did have to cancel some expected hires as we will be unable to train them (Simulators in the US). We do expect to see continued growth and hiring as the world gets back to normal.
James Elian
President
AirSprint
hamstandard
AirSprint HR wrote: Wed Mar 18, 2020 8:56 am
James Elian
President
AirSprint
Thanks,
Does that mean all vacant positions in the recent ad have been filled?
AirSprint HR
hamstandard wrote: Wed Mar 18, 2020 9:38 am
James Elian
President
AirSprint
Thanks,
I would say that there are no longer currently any vacant positions and when things turn around we will look at posting the positions again.
Thanks,
James
hawker driver
Post by hawker driver »
Is AirSprint going to follow the model that Flexjet is putting into place in the US?
https://www.businesswire.com/news/home/ ... gram-Limit
AirSprintInc
hawker driver wrote: Fri Mar 20, 2020 7:46 pm Is AirSprint going to follow the model that Flexjet is putting into place in the US?
Hi Hawker Driver,
We have had some fairly significant changes in the past two weeks as we have been diligently working at significantly reducing airline travel and we continue to look at all options to ensure the safety and well being of our owners and crews.
Matt Rolleman
cjp
Post by cjp »
Looking forward to speaking with you when all this is behind us.
Stay safe mes amis.
BCM123
Post by BCM123 »
'97 Tercel wrote: Fri Sep 08, 2017 9:51 pm Average days worked per month is 14?? That's a lot in the corporate jet world.
14 days may seem like a lot but some months a lot of that is sitting around not to mention I have met corporate guys who fly a lot more than we do not knowing when they will actually be home. The company provides the ability to have a schedule that you are bidding for and from my experience I have gotten my bid every time.
Sky_Conqueror
Post by Sky_Conqueror »
Greetings to all,
I hope all is well and everyone is staying safe from this crisis.
I had a small question for HR. What would happen if we were put into a pool for future positions. With this crisis; does that blow us out of the water for any future positions when this thing subsides or do we remain in the pool? Thanks to all:)
ayseven
Post by ayseven »
Yes, I second the question; enquiring minds want to know!
AirSprintInc
Hi Sky_Conqueror and ayseven,
Anyone that has been placed into the pool for future considerations will remain there. Only applicants that we feel would be a good fit for AirSprint are placed into the pool. When new positions open up we often look to the pool first, but entertain new applications as well.
That said, our main priority will be returning our inactive pilot group back to active status first as we transition out of the pandemic.
I encourage both of you to contact either myself or Matt Sanders directly for hiring updates as we are both happy to provide them at any time.
Hope that helps and that you both are staying safe and healthy!
Matt Rolleman
ayseven
Post by ayseven »
Thanks for that. It is not that often people take the time to communicate with prospective employees. It says something.
AirSprint HR
As an update, the last few months has seen a steady improvement in flying and several new clients. The Canadian quarantine is still holding back flying from traditional norms so I would not say that we are back to normal, but there has been significant improvement. All of AirSprint's employees who were on a temporary layoff are now back and the 20% salary reduction has now been amended to 10% with back pay for the difference from when it was first reduced on May 1st. We will be hiring in the near future for 1 pilot, 1 apprentice AME, and a few operations positions, with more hiring expected in the fall. For the remainder of 2020 we will likely be hiring between 5 and 12 pilots.
Take care.
James
delfinjetpilot
Post by delfinjetpilot »
What about the first group of pilots that got laid off? If the rumours in the FBO crew rooms are correct, there are at least 2 fairly senior pilots that haven't been recalled yet.
AirSprint HR
delfinjetpilot wrote: Thu Aug 20, 2020 5:28 pm What about the first group of pilots that got laid off? If the rumours in the FBO crew rooms are correct, there are at least 2 fairly senior pilots that haven't been recalled yet.
Very early in the pandemic in mid-March a few pilots from secondary bases were laid off. It would not be right to speak in more detail about former employees on a public forum but these initial layoffs were not temporary and came at a different time than the subsequent temporary layoffs in May.
James
'97 Tercel
Post by '97 Tercel »
CJdriver
Post by CJdriver »
'97 Tercel wrote: Fri Aug 21, 2020 6:33 pm Image
Its called cleaning house!
Radiohead
Post by Radiohead »
AirSprint HR wrote: Fri Aug 21, 2020 11:08 am
James
Unsurprising.
delfinjetpilot
Radiohead wrote: Tue Aug 25, 2020 3:18 pm
Unsurprising.
This seems to imply you have some more information? :wink:
Radiohead
Post by Radiohead »
delfinjetpilot wrote: Tue Aug 25, 2020 5:15 pm
About the two individuals specifically? Afraid not, thankfully I am not in touch with that organization directly anymore.
Even if I did, anything I say specifically will be cheerily rebuked by one of the upper management types that run the AirSprintHR account, so I will just have to allow their post on this matter stand for itself, as it seems plain enough.
AirSprint HR
AirSprint HR wrote: Thu Aug 20, 2020 3:47 pm As an update, the last few months has seen a steady improvement in flying and several new clients. The Canadian quarantine is still holding back flying from traditional norms so I would not say that we are back to normal, but there has been significant improvement. All of AirSprint's employees who were on a temporary layoff are now back and the 20% salary reduction has now been amended to 10% with back pay for the difference from when it was first reduced on May 1st. We will be hiring in the near future for 1 pilot, 1 apprentice AME, and a few operations positions, with more hiring expected in the fall. For the remainder of 2020 we will likely be hiring between 5 and 12 pilots.
Take care.
James
New Update. Flying has continued to increase over the last few weeks and as of September 1st, salaries for all employees are back to 100% of pre-April levels.
I hope that the rest of the industry sees a similar rebound that we have in the not too distant future.
James
ayseven
Post by ayseven »
That should be screamed from the rooftops. People need encouragement. Excellent news!
WCJetPilot
Post by WCJetPilot »
Great to hear things are starting to rebound. I may even throw my resume in the hat, although I'm sure they're getting hundreds of pilot resumes for laid-off airline folk these days.
Curious on why one of the Legacy 450's is up for sale?
www.controller.com/listing/for-sale/196 ... t-aircraft
Wonder if it's being replaced or if the demand for the larger aircraft isn't strong during the Covid-19 locked down world we live in, thus it's time to get an asset off the books.
AirSprint HR
WCJetPilot wrote: Tue Sep 01, 2020 6:57 am Great to hear things are starting to rebound. I may even throw my resume in the hat, although I'm sure they're getting hundreds of pilot resumes for laid-off airline folk these days.
This aircraft is currently part of AirSprint's core fleet and is being replaced by a newer one.
Thanks,
James
Return to “Corporate”
