182 down by Smithers
Re: 182 down by Smithers
trey kule wrote: Mon Nov 02, 2020 3:58 pm We are getting a bit off topic here, but yes to the cowlflaps. I don’t have the numbers for a 337, but IIRC, in the Navajo you could get about 50 extra feet of climb per minute with them closed. Both sides with an engine failure.
The problem with the 337 cowl flaps is they don’t have limit switches, and rely on the professionalism of the pilot. Dozens of burned out cowl flap motors from pilots who forgot. The same issue with the standby flaps in Caravans.
For the life of me I don’t understand the OEM thinking on these things.
You don’t understand the system. Neither did the pilot who taught me how to fly it and told me to leave the knob half a knob from full closed. Amazingly, neither did all of his previous AMEs who went through the cowl flap system and weren’t able to get it to work properly. And yes if you went to limits you’d pop the circuit breaker or shear the roll pin or burn out the motor.
So then I opened the Service Manual.. and found out that the cowl flaps are pretty much identical to a Cessna flap system. There are limit switches and about four pages of literature and diagrams for how to rig it. And like rigging anything; there are no shortcuts. You have to take it all apart and start at the very beginning. It took me hours but in the end, I had cowl flaps that could be abused by the most ham-fisted pilots and work perfectly normally.
So I stand by my opinion of the 337. The extra engine just means you are twice as likely to have an engine failure. You are OVER twice as likely to have an engine failure due to the possibilities of fuel mismanagement in an environment where you are distracted by constantly dodging obstacles, looking for fires/wildlife/etc, on trips that can last 7 hours. And due to the high altitudes, remote areas, and that the rear engine always runs hot.. the possibility of making an airport with that engine still running is not guaranteed. Then you have to deal with the other liabilities like higher turn radius, higher stall speed etc which makes forced approach in extreme terrain less survivable.
trey kule
Post by trey kule »
Well, Ifly.
I had written a response to you post. Then reread your latest posts.
I think there is little point in discussing this anymore with you.
Your mind is made up. No need to confuse things with the facts, or try to brush off your attacks to defend your position.
Accident speculation:
Castorero
Post by Castorero »
I have flown over the Babine River more times than I can remember in the past 35 years, kayaked it once and floated it twice.
It is not an inviting landing option at the best of times unless you have a death wish.
I can see why the pilot in the 182 could have chosen the trees, if indeed he had a choice.
I am perplexed about the apparent inverse relationship between Power and Carb heat that PilotDar describes.
If one has spent a lot of time in a non carburated machine, going back to a carburator is a real PIA for a lot of hours, until it becomes second nature.
My experience in the -2 is that Carb Heat increases and decreases directly with power changes and that you have to visit the CAT lever every time you change power settings.
It helps immensely having a CAT Gauge for keeping the Temp in the green as the lever adjustment is only about 3/16" between too hot and not useful hot.
I am sure there is a reasonable physical explanation for the situation PilotDar describes.
cncpc
Post by cncpc »
iflyforpie wrote: Tue Nov 03, 2020 9:16 am
We've both flown the same type in the Monashee and the Selkirks on fire patrols and bug mapping. Generally, yes, the extra engine means you are twice as likely to have an engine failure. I don't think anybody is surprised by the math of that. What that means in a side by side is that while you may have quite a bit of time to pick where you are going to land, including at an airport, you do have the requirement to always maintain control and that is more difficult than in a single, or a 337. In a side by side, the running engine can, and has, killed many people. That doesn't happen in a 337. There is no VMC roll.
I forget which one it is, but there is still sort of a "critical" engine on a 337. Not related to p factor on the running, but its a bit worse to lose one than the other purely in terms of performance. Okay, I researched it, and on pre 1973, you got 50 fpm less with the rear failed than with front stopped. After that, not much difference.
I know some talk about cooling difficulties on the back engine, but I don't recall it running at a significantly higher temperature. Conversely, it does seem that the rear needs a top sooner than the front.
If you are in the BC mountains, and you're in a situation in a 337 where anything whatever depends on the difference in turn radius, you're probably gone already for something you may have done minutes before when you allowed an airplane to descend into a situation where turn radius was all that was going to save you. I suspect IFly is talking about the specialized work of fire spotting for the BC Forest Service and what they called "mapping" the fire, where it was presumed that a pilot's licence included some special ability in assessing fuels and risk and I forget what else. I do remember that it was a task that in many situations could not be done safely. So I didn't do that. I told them there was a fire, it was spreading, crowning, whatever, and to send tankers if that was obvious. They were going to send a chopper anyway. My job is not to be down doing steep turns in gulches and canyons trying to identify the species of shrubbery that was burning, or whether the squirrels were nervous. You can do everything they require, which is providing information, orbiting at 500 feet above the fire and never worrying about turn radius.
I'm not sure it was entirely the gear doors that complicated the engine out procedure on takeoff. I remember that part of the drag came from the gear transiting profile in which the wheel was broadside to the slipstream for a short time.
We are off topic about the Smithers crash. While I remain baffled about how some see a ditching on a shoreline as such a Doomsday scenario that they would prefer to fly into trees, in this particular case, I don't fault the pilot at all. He really didn't have any other choice. That he was aware of. When the engine lost power, he was within easy sight and gliding distance of the Silver Hilton strip. He didn't go there, it apparently wasn't in the GPS database, and that choice, although there, wasn't available to him. It does seem that the course he took up was mistakenly believed to be for the same strip he could see outside his window.
This crash was caused by issues with the carb heat capabilities of the unusual STC that was in the thing, and we can learn from that and some of the lads here are very knowledgeable on that and informing us. Not sure what can be learned from flying away from safety.
iflyforpie wrote: Tue Nov 03, 2020 9:16 am So then I opened the Service Manual.. and found out that the cowl flaps are pretty much identical to a Cessna flap system. There are limit switches and about four pages of literature and diagrams for how to rig it. And like rigging anything; there are no shortcuts. You have to take it all apart and start at the very beginning. It took me hours but in the end, I had cowl flaps that could be abused by the most ham-fisted pilots and work perfectly normally.
It seems to me that there must be limit switches on the cowl flaps of the 337. There is a neutral position for each toggle switch but sometimes it gets forgotten and I haven't seen the motor burn out. Could it be that the motor burns out if you forget to move the switch back to neutral and the limit switch has failed.
cncpc wrote: Tue Nov 03, 2020 6:28 pm So I stand by my opinion of the 337. The extra engine just means you are twice as likely to have an engine failure.
This may be true but the chances of a crash landing after an engine failure are 100% in a single while much less in a C337.
PilotDAR wrote: Fri Jun 19, 2020 5:50 pm I experimented again (factory C150M). At full power, 2700 RPM, carb heat cold, mixture rich = 53F, then carb heat hot = 71F, then peak lean = 77F. Reduce power to 2200 RPM, didn't touch anything else, carb air temp = 89F, repeated several times, same result. Then at 2200 RPM, carb heat hot, leaned more to peak, = 94F. Back to full power cold/rich, 53F again.
So, for that basic test, repeatedly, all other things being equal, I could get 12F more by reducing 500 RPM, and yet still having enough power for level flight. That 12F could make quite a difference if melting ice were marginal and critical.
I'll be interested to hear Pelmet's results, factoring in MP...
I had a chance recently to check out one of the C182's I fly. At a low power setting of 15", I could get 7 degrees additional temperature increase from carb heat cold operation as compared to the amount of temperature increase I could get at cruise power from carb heat cold operation.
Is this common for various aircraft.
CpnCrunch
Post by CpnCrunch »
PilotDAR wrote: Thu Jun 18, 2020 9:21 am
That is a very counter-intuitive result
Yes, though not so much if you're considering the induction air as "cooling" air - more air = more cool = more heat required to warm to deice.
You are also getting more evaporative cooling in the carb from the extra fuel that is being sucked in at higher throttle settings. Most of the time I only see carb ice in the C150 at full throttle. Normally a few seconds of carb heat clears it up, but sometimes a reduction in throttle is needed to make the engine run smoothly. Occasionally I'll have the carb ice continually re-appear during cruise, and I just leave either partial or full carb heat on for the entire flight.
Quick question, I didn't see any more mention of this on the TSB report.
and the propeller control was fully in (full fine pitch).
Wouldn't a 182 glide further with the prop in full coarse?
Quick question, I didn't see any more mention of this on the TSB report. Quote from 1.13
Post by ahramin »
co-joe wrote: Fri Nov 06, 2020 9:37 am Quick question, I didn't see any more mention of this on the TSB report. Quote from 1.13
Yes, but I don't think it's part of the Cessna emergency procedures.
I don’t think that with zero power and the prop windmilling you’ll get enough RPM to get the blades off the full fine stop, wherever the prop lever is set. I’ll give it a try though.
photofly wrote: Fri Nov 06, 2020 8:43 pm
Yes, you will improve the gliding distance by moving the propeller pitch to full coarse.
What RPM change do you get?
photofly wrote: Fri Nov 06, 2020 9:26 pm What RPM change do you get?
No idea. I just know that there is a significant improvement in gliding distance. Something every pilot of a single engine piston aircraft should be aware of.
telex
Post by telex »
When all else fails consult the manufacturer's POH for guidance.
CESSNA MODEL 182Q
ENGINE FAILURE DURING FLIGHT
1. Airspeed -- 70 KIAS.
2. Carburetor Heat -- ON.
3. Fuel Selector Valve -- BOTH
4. Mixture -- RICH.
5. Ignition Switch -- BOTH (or START if propeller is stopped).
6. Primer -- IN and LOCKED.
FORCED LANDINGS
EMERGENCY LANDING WITHOUT ENGINE POWER
1. Airspeed -- 70 KIAS (flaps UP).
65 KIAS (flaps DOWN).
2. Mixture -- IDLE CUT-OFF.
3. Fuel Selector Valve -- OFF.
4. Ignition Switch -- OFF.
5. Wing Flaps -- AS REQUIRED.(40° recommended).
6. Master Switch -- OFF.
7. Doors -- UNLATCH PRIOR TO TOUCHDOWN.
8. Touchdown -- SLIGHTLY TAIL LOW.
9. Brakes -- APPLY HEAVILY.
No mention of prop.
The only constant speed single I ever flew was a 172 RG that I did some of my CPL time building on. I'm pretty sure we were taught to go full coarse for the forced approach, but the memory is foggy. I just find it odd that the TSB would mention the prop being full fine, but not mention that full fine might not have been the best place for it. Maybe they just don't want to contradict the POH. He turned away from the field and landed downwind, range likely wouldn't have helped, but I think it's still a good conversation to have.
Unless like you say photofly, with the prop out of the governing range, the pitch control would be ineffective.
Post by ahramin »
I was doing some glides for data gathering last month and the RPM drop in full coarse was about 200 RPM.
telex wrote: Fri Nov 06, 2020 10:44 pm When all else fails consult the manufacturer's POH for guidance.
CESSNA MODEL 182Q
4. Mixture -- RICH.
FORCED LANDINGS
No mention of prop.
Thanks,
I don't think that I have seen any single engine, constant-speed aircraft that I have flown mention that the prop lever should be moved to coarse. However, it will make a significant difference. One need only think about the aerodynamics, it is like partially moving the blade angle toward feather. This means less 'flat-plate' drag.
I would suggest open throttle as well to increase the glide distance.
ahramin wrote: Sat Nov 07, 2020 5:13 am I was doing some glides for data gathering last month and the RPM drop in full coarse was about 200 RPM.
Good data point - thanks.
Pelmet wrote:I would suggest open throttle as well to increase the glide distance.
If it increases RPM, it would be the wrong thing to do.
photofly wrote: Sat Nov 07, 2020 5:34 am
It will increase glide distance in combination with coarse pitch.
Therefore, I recommend this action in the event of an engine failure.
It's more complicated than that. Blades aren't flat. They have a leading edge and a trailing edge and they generate a different aerodynamic force (drag from the point of view of the aircraft, negative lift from from the point of view of the windmilling blade) depending on the blade angle.
How do you know?
photofly wrote: Sat Nov 07, 2020 5:57 am
I think that you may have come to a conclusion and are now coming up with complicated ideas to back up the conclusion. I suggest testing it out on an appropriate aircraft and then get back to us with the results.
Even NTS and Beta Follow-up are designed to coarsen blades to reduce drag on certain turboprop engines. The coarser the prop, the less the drag.
pelmet wrote: Sat Nov 07, 2020 6:09 am
I agree the drag decreases with a coarse blade. (There’s nothing really very complicated about looking at the aerodynamic forces on a propeller blade). My initial doubt was that In a piston single the prop speed control has any effect on the blade angle of a windmilling prop. But ahramin says it does, and he’s credible.
But why do you say that the throttle should be opened?
photofly wrote: Sat Nov 07, 2020 6:21 am
photofly wrote: Sat Nov 07, 2020 5:57 am It's more complicated than that. Blades aren't flat. They have a leading edge and a trailing edge and they generate a different aerodynamic force (drag from the point of view of the aircraft, negative lift from from the point of view of the windmilling blade) depending on the blade angle.
I agree with that. (There’s nothing really very complicated about looking at the aerodynamic forces on a propeller blade).
So you agree that selecting full coarse on the blades on a windmilling prop will increase the glide distance.
