PreBuy
PreBuy
Hello all,
I've done some searching but have not really found what I'm looking for. I find Google is not much help either in sourcing AME's for doing a prebuy. It seems you need to know someone to ask for a referral but when I'm looking at something in AB and I live in Eastern ON not sure word of mouth travels that far.
Is there a resource to look up and contact AME's in different areas of the country?
Re: PreBuy
Easiest way I found is just to call around at the airports close to where the plane is located and find an AME who is not currently working on the plane. Ask them if they are familiar with the airplane type and if they would want to do a pre buy on the plane.
It is very impractical and expensive to get expert AME A from province B to check out airplane C.
Re: PreBuy
Cost effective (cheapest) PreBuy is not recommended. Presently dealing with an aircraft that was imported; recent annual inspection discovered a previous Gearup landing with significant structural issues that were never rectified. Very painful & expensive decisions to be made. Prebuy not only involves mechanical issues - but structural as well. More experience then just a rookie AME- non structures might have. Previous history & major repairs to be scrutinized. Pay me now or pay me later.
Re: PreBuy
The irony is that it's usually the new-to-the-industry 'rookie' AMEs building up a client base that are willing to travel. Not the expert established ones running an AMO...edmanster wrote: ↑Mon Mar 21, 2022 7:25 am Cost effective (cheapest) PreBuy is not recommended. Presently dealing with an aircraft that was imported; recent annual inspection discovered a previous Gearup landing with significant structural issues that were never rectified. Very painful & expensive decisions to be made. Prebuy not only involves mechanical issues - but structural as well. More experience then just a rookie AME- non structures might have. Previous history & major repairs to be scrutinized. Pay me now or pay me later.
Re: PreBuy
All due respect, I didn't ask for cheapest I simply asked how to source the contacts to have a discussion with them to then choose someone to do it.edmanster wrote: ↑Mon Mar 21, 2022 7:25 am Cost effective (cheapest) PreBuy is not recommended. Presently dealing with an aircraft that was imported; recent annual inspection discovered a previous Gearup landing with significant structural issues that were never rectified. Very painful & expensive decisions to be made. Prebuy not only involves mechanical issues - but structural as well. More experience then just a rookie AME- non structures might have. Previous history & major repairs to be scrutinized. Pay me now or pay me later.
If I need a auto mechanic they're mostly listed (not all) when I search for auto mechanic, NOT the case with an aircraft mechanic.
Re: PreBuy
I support the notion that a prebuy should be really indepth. It should really be about an annual inspection, other than replacing things. When I have done them, I have used the annual inspection checklist for the type, and looked for hidden/repaired damage. A few clients have, over the years, contacted me for repair approvals for major repairs later found to have been done [poorly] for which there was no logbook entry. A type familiar inspector would have found the repairs or damage.
So... consider paying an AME to actually sign the plane out for an annual inspection for you, should you buy it, that will cause them to think about the service they will provide for you.
As to how to find a person, it really does come down to word of mouth. A more junior AME can do a fine PPI, if you brief them as to what you're looking for (the equivalent of an annual inspection signout), and assure that they are using a suitable checklist, which will be completed with comments and photos for you. If you have a local AME you trust, it may be worth paying them to travel if they're willing, and the value of the plane is sufficient to make the great cost proportionate.
Re: PreBuy
I have sent an engineer across country as I’m familiar with his work. Sure you pay a lot more, but it has saved me in the long run.
Re: PreBuy
An annual (CAR 625 App B) is a pretty bare bones inspection IMO. When I purchased a plane for commercial operations, it was the 200 hr + AD's + S/B's + out of phase. That way when it was put on the OC, it was ready to work right away. Yes it's a long and expensive inspection, but better find defects now... In the contract of sale I always state that buyer pays for inspection, seller pays for repairs (especially if they warrant that there are no defects).
Re: PreBuy
To try and answer the OP question...
You can search AMOs on TC website using various filters. It won't give you private AMEs but its a start.
https://wwwapps.tc.gc.ca/saf-sec-sur/2/ ... ture=en-CA
You could also try contacting the AME association for the relevant region to see if they can help.
Re: PreBuy
An inspection carried out on a small airplane IAW CAR 605.86 & AWM 625, appendix B, and presumed to be an "annual" inspection, is required to be done IAW a "checklist", which must be appropriate to the type, include AD's and ICA's for mods, and generally call up the airplane manufacturer's inspection checklist and standard industry practice (AC34.13). If you've done all of that on a PPI you've had a pretty good look at the plane. Nothing prevents (and I certainly have done) more in depth inspections, when you're looking for something in particular, or type or mod specific.An annual (CAR 625 App B) is a pretty bare bones inspection IMO
Nothing defines what a PPI should include, and I have bought three planes with zero PPI. But, were I doing a PPI for someone else, an inspection to at least the airplane manufacturer's inspection checklist, all ICA's, and all AD's would be a minimum.
Re: PreBuy
Exactly .. seen many an inspection where annual on a Comanche 250 cost about $350. Discounts avail if u brought ur own Brake linings ..
Major Structures was always performed per AC43.13 less any specific details & its only an issue if it is an issue !
Bug_Stomper_01
Re: PreBuy
We’re a small community of as is, let alone ame’s that specialize on particular aircraft.Rich3791 wrote: ↑Sun Mar 20, 2022 2:17 pm Hello all,
It’s mostly word of mouth how you find us short of hiring the manufacturer or a manufacturer approved service Center to take on & handle the task.
A good pre buy consists of a thorough detailed panels off visual/tactile inspection with minimal disassembly by an AME with overhaul experience preferably. The AME needs access to all of the engine, airframe & all applicable logbooks as well as a current tracking report on site during the inspection.
In short I suggest you call the manufacturer and go from there, they’ll be able to guide you to someone locally.
Bug_Stomper_01
Re: PreBuy
I disagree, if you’re doing a pre buy you better know the AME and his capabilities before tasking him with a pre buy. Depending on the aircraft it could cost the buyer dearly if something is missed. Call the manufacturer and go from there.digits_ wrote: ↑Sun Mar 20, 2022 2:34 pm Easiest way I found is just to call around at the airports close to where the plane is located and find an AME who is not currently working on the plane. Ask them if they are familiar with the airplane type and if they would want to do a pre buy on the plane.
Re: PreBuy
Ideally, yes, but if that's the only way you want to buy a small airplane, it's unlikely you will find/would have found something in the current market.Bug_Stomper_01 wrote: ↑Sat May 28, 2022 6:01 amI disagree, if you’re doing a pre buy you better know the AME and his capabilities before tasking him with a pre buy. Depending on the aircraft it could cost the buyer dearly if something is missed. Call the manufacturer and go from there.digits_ wrote: ↑Sun Mar 20, 2022 2:34 pm Easiest way I found is just to call around at the airports close to where the plane is located and find an AME who is not currently working on the plane. Ask them if they are familiar with the airplane type and if they would want to do a pre buy on the plane.
Properly priced airplanes moved quite quickly. It would take at least 2 or 3 weeks to organize a pre buy like you recommend. By that time someone else would have bought it if it was a good deal.
Bug_Stomper_01
Re: PreBuy
I didn’t read every response in this thread but OP didn’t mention anything about a “small airplane” or any kind of timeline. I’ve been doing this a very long time and done countless pre buy inspections and I’ve never had a single complaint with everything I find / my cost.digits_ wrote: ↑Sat May 28, 2022 3:59 pmIdeally, yes, but if that's the only way you want to buy a small airplane, it's unlikely you will find/would have found something in the current market.Bug_Stomper_01 wrote: ↑Sat May 28, 2022 6:01 amI disagree, if you’re doing a pre buy you better know the AME and his capabilities before tasking him with a pre buy. Depending on the aircraft it could cost the buyer dearly if something is missed. Call the manufacturer and go from there.digits_ wrote: ↑Sun Mar 20, 2022 2:34 pm Easiest way I found is just to call around at the airports close to where the plane is located and find an AME who is not currently working on the plane. Ask them if they are familiar with the airplane type and if they would want to do a pre buy on the plane.
