Comorant crash
Re: Comorant crash
I predict the RCAF will try to hide any detail of the event, and some sharp CBC investigative reporter will get to the bottom of it. Same as happened in the Mediterranean, same as the Cormorant lost off Halifax.
Training accident that destroys the very assets that are intended to be deployed, a la Blackhawks in the snow. Sack the training staff and management, roll the dice with someone else. Day, good weather, over a huge runway at a major airport. If you can't train safe in those conditions, you're doing it wrong.
Re: Comorant crash
Unless it was mechanical.karmutzen wrote: ↑Thu Mar 10, 2022 8:32 pm I predict the RCAF will try to hide any detail of the event, and some sharp CBC investigative reporter will get to the bottom of it. Same as happened in the Mediterranean, same as the Cormorant lost off Halifax.
Re: Comorant crash
I predict that you have no idea what you are talking about. Both those previous accidents have open and transparent flight safety investigations that outline to the very fine detail exactly what happened and why. Zero cover up. To even suggest such BS and insinuate any malfeasance is libel. CBC did not “get to the bottom” of anything - if any reporting was done, it used the report from DFS as source.
There is already a working theory on the 5Ws - we got this….
- Old fella
Re: Comorant crash
Very glad to hear no fatalities amongst the crew and hopefully a speedy recovery from any injuries incurred and back on duty soonest. SAR is a vital service through the dedication and professionalism of the servicemen/women.
Re: Comorant crash
That’s a costly mishap, sometimes training for emergencies become emergencies. Hopefully the crew mend quickly and the machine isn’t a complete loss, but if it’s on its side I suspect it’s BER
Re: Comorant crash
Looks like the preliminary report says the pilot seat…
https://rcaf.forces.gc.ca/en/flight-saf ... r/l15jmm95
Let’s Go Brandon
Re: Comorant crash
"I predict the RCAF will try to hide any detail of the event..."
Stay away from meteorology and the stock market...
Re: Comorant crash
Did the Google to see if I could find a photo of the Comorant seats. How do they raise and lower? Did that mechanism break, allowing the seat to drop?
Re: Comorant crash
Hmm, more questions. Always two trained pilots at the controls on a Cormorant, training flight so presumably an instructor pilot in the other seat that never made any attempt at recovering the aircraft. The upset came from a controlled yaw right to an uncontrolled left with no collective or cyclic correction ( raising collective with have put them further from the ground, cyclic would have corrected the roll, pedal would have corrected the yaw). Any one correction could have prevented the crash. Why would a seat dropping full stroke cause so much left pedal input?
Preliminary doesn't pass the smell test.
Re: Comorant crash
How many seconds would you have had to correct from their pre-accident position?karmutzen wrote: ↑Fri Apr 08, 2022 9:36 pm Hmm, more questions. Always two trained pilots at the controls on a Cormorant, training flight so presumably an instructor pilot in the other seat that never made any attempt at recovering the aircraft. The upset came from a controlled yaw right to an uncontrolled left with no collective or cyclic correction ( raising collective with have put them further from the ground, cyclic would have corrected the roll, pedal would have corrected the yaw). Any one correction could have prevented the crash. Why would a seat dropping full stroke cause so much left pedal input?
I could see someone fully stretch their leg when they think they are falling down. Seems like a natural reflex if you think you're falling (=seat collapsing). I've had seats move in a fix wing aircraft, it can be quite disorienting. Don't know about rotary wing, but I doubt basic reflexes change.
Re: Comorant crash
You weren't there so why would you make such an idiotic comment.
Your comments don't pass the if you have any brains test
