King Air / B1900 - IATRA?
Doodlebugger
Just wondered can someone confirm the King Air 200/350, and B1900 for that matter are still all designated single pilot ?
Just curious why every operator seems to require the IATRA or ATPL's to be written as a prerequisite for an FO position on these aircraft? Obviously flying them multi-crew, maybe that's why, but pretty sure not required?
- schnitzel2k3
Re: King Air / B1900 - IATRA?
Only ones that aren't to my knowledge are the 1900 B/C. Not too many of those around anymore.
D's and all King Airs are SP certified.
I wonder if it has to do with a knowledge barrier the operators expect. IATRA requires some basic turbine and weight and balance stuff beyond the CPL exams.
I believe that they changed the other 1900 models to also be single pilot in Canada, if I’m remembering correctly.schnitzel2k3 wrote: ↑Fri May 20, 2022 10:16 pm Only ones that aren't to my knowledge are the 1900 B/C. Not too many of those around anymore.
I suspect the IATRA requirement is just a way to filter out all the low time guys that haven’t found the time/are too lazy to write it - the exam itself is a joke.
Blackdog0301
B's and C's are also single pilot certified. I believe they started out as 2 crew originally, but that was changed to single crew maybe 8ish years ago.schnitzel2k3 wrote: ↑Fri May 20, 2022 10:16 pm Only ones that aren't to my knowledge are the 1900 B/C. Not too many of those around anymore.
Caterpillar
Keep in mind as well, if you plan to jump to a 705 carrier with your IATRA and you flew the 1900, your IATRA hasn't been "activated". Make sure to look out for the expiry of your exam in that regards.
Since I’m flying the King Air, does that qualify me to fly the Queen of the skies?
- schnitzel2k3
Shows you how long its been since I've flown one of those clams.Blackdog0301 wrote: ↑Sat May 21, 2022 7:57 amB's and C's are also single pilot certified. I believe they started out as 2 crew originally, but that was changed to single crew maybe 8ish years ago.schnitzel2k3 wrote: ↑Fri May 20, 2022 10:16 pm Only ones that aren't to my knowledge are the 1900 B/C. Not too many of those around anymore.
I wonder if it has to do with filling a knowledge gap the operators expect. IATRA requires some basic turbine and weight and balance stuff beyond the CPL exams.
I always thought you needed it if it's listed on the AOC??
If you're asking about Alberta specifically requiring an ATPL, "Contrails" and their unique brand of BS strikes again, and requires the ATPL or IATRA written to be SIC of a King Air and 1900.Doodlebugger wrote: ↑Fri May 20, 2022 7:29 pm Just wondered can someone confirm the King Air 200/350, and B1900 for that matter are still all designated single pilot ?
