Commuting @ Jazz
Commuting @ Jazz
Just wondering, do the folks at Jazz allow commuting, or do you have to live at your posting base. Thanks
flyer 1492
flyer 1492
giligan,
The farther you commute the more you will pay. I know of some pilots who live in the Edmonton area and drive to their base in Calgary just because it is easier for them. You can ask for the jump seat, it is up to the captain if it is granted. I personally will not turn away a commuting pilot, unless we are over weight or it is already spoken for.
Hope this helps.
Flyer
Hope this helps.
Flyer
Find out how many flts per day from your house to base. Find out how many other pilots in your city work for Jazz, to determine whether you have a good chance of getting bumped by a more senior pilot. Apparently, you can't get in trouble if you miss a flight if you've tried to get on 2 flights prior.
Good Luck
Good Luck
- Jaques Strappe
Jazz has a commuting policy. As bede said, if you have allowed yourself sufficient back ups ( I believe 2 flights ) and you still cannot get to work, you can drop your cycle with no credit and attempt to make it up later in the month without disciplinary action.
Standby for new atis message
wallypilot
Gurundu the Rat
Jazz pilots have priority over AC pilots only for the jumpseat on Jazz aircraft. AC pilots have jumpseat priority on AC aircraft. Date of hire dictates your priority if the jumpseat is not available reguardless of who operates the flight (I think). Lots of pilots commute from YHZ to both YYZ and YUL. From what I hear they can both be tough to get on unless you have a good seniority number. Apparently YYZ has more flights though.
Good luck
Good luck
RidersRule
Another question on commuting, does anyone commute out of Regina or Saskatoon and how is it. Seems to be a fair bit of selection now that mainline no longer serves here(more Jazz flights).
Also, this no passes for six months, does that mean no passes for you to commute or no pass privelages for family and friends. Thanks
bobcaygeon
[quote="bobcaygeon"]No passes at all for 6 months!!!! Nada, zippo, zilch
quote]
It is pretty hard to commute in your first 6 months at JAZZ. Its A really good place to work for, but you had better move as soon as you get the job.
OR find another way of commuting.
quote]
Yes you need passes to ride in the jumpseat, Yes there is a charge for it. For all intents and purposes its the same as riding in the back. Same charge etc. The only reason you will sit up there is if the flight is full in the back. It will save your bacon on occasion if you are the only Jazz guy on the standby list for a Jazz flight. You will have priority for the jump over anyone that works at AC. However as was mentioned earlier that is on Jazz flights only. If its a AC flight then you are below AC pilots and Flight Attendants.
Interesting, I would have thought that to charge for the jumpseat would mean it was earning revenue, even if it was an employee at a reduced rate. In the past I have rode jumpseat on other airlines and been given a refund as they were not able to charge for it. Oh well.
thanks.
giligan
thanks.
giligan
I was talking to the Asst. CP for YYZ today about this issue. As of current, you CANNOT commute prior to six months. Crew sched. cannot give you a pairing if you are somewhere other than YYZ and unsure you will make it. However management is in discussion right now as to allow it.
bobcaygeon
