QOL for commuters
Re: QOL for commuters
Air Canada does not have a commuter policy. AC has a letter on your file if you don’t make it to work policy.
If you want to commute I suggest an airline that has a viable policy. AC does not have one.
If they won’t pay a livable wage for the city you are based in, AND won’t provide a proper commuting policy as a substitute. What does that tell you?
Commuting, good luck with that in the long term.. AIF's tripling, flight reductions.
From my hometown there use to be 3 daily flights to the closest hub, now it's 1...
There are a ton of Calgary commuters. AC travel passes are based on seniority, so if another pilot is trying to commute on the same flight as you, they will have priority over you for getting the flight. Junior NB FO’s based in YVR are doing days 18-20 days a month. WB is more right now, but could come down if/when China opens back.Anonymouse wrote: ↑Sun Nov 13, 2022 7:00 pm Whats the QOL like for AC pilots who commute? Any insight from anyone living in Calgary would be appreciated.
And what are the upgrade times like? How many hours do you need to upgrade?
The best gig right now for Calgary Commuters is YVR 787 RP, as there are direct FRA and LHR pairings that start and end with a DH from YVR to YYC. As a commuter, you can cancel and bank your DH and just drive to the airport in Calgary for your flight. However, to get any of these flights you’ll need at least 3-4 years of seniority. There are 787 RP’s with 7-8 years that have effectively made YYC a base, as all of their pairings start and end out of YYC.
Keep in mind that if you are commuting on AC metal you are first in line for the JS. I’ve done more YVR-YYC/YEG and YYZ-YOW/YUL than I’d like to admit and we rarely have anyone in the JS.
Is there a flight attendant JS that you can usually take as well? If they're doing training and won't let JS in the cockpit or there is a more senior pilot? It would be nice especially if there's a couple pilots looking to commute on a full flight
I am wondering, with all the hiring going on, have there been cases of pilots being fired for things like missing a reserve because they didn't think they were going to get called out etc? Or do people just not do that?
There are enough commuters that odds are someone on the FD commutes and thinks it’s a dick move to deny the jumpseat. I’ve even had jumpseaters during my own training, though I suppose there’s no guarantee anyone else would extend the courtesy. As far as extra FA seats go those are available too on some equipment though I’m not sure what the hierarchy of priority there is, maybe a standby FA gets it before a pilot.
I haven’t heard of anyone doing that recently. In the past reserve was pretty predictable but with best fit it’s pretty hard to figure out who’s going to get what. It’s definitely not advisable. As for the consequences, my guess would be a couple strikes and you would be out.
I’ve used a flight attendant jumpseat. Pretty rare occurrence.
I recommend that anyone who wants to be respected and compensated properly in aviation steer clear.
There is a full on WACON nightmare going on that isn't going away anytime soon
Today’s new hire class included candidates from Westjet, Transat, Sunwing, Flair, Lynx and Swoop. Until that changes, things like a Commuter Policy and Flat Pay will not change.
All three positions, CA, FO and RP, on the YYC to LHR/FRA start with a DH between YVR and YYC. But beware, on a memo from “higher up” Crew Scheduling has not been granting releases from the DH. So YYC commuters have had to commute from YYC to YVR to DH from YVR to YYC to begin their pairing!Curiousflyer wrote: ↑Sat Dec 31, 2022 11:29 am The best gig right now for Calgary Commuters is YVR 787 RP, as there are direct FRA and LHR pairings that start and end with a DH from YVR to YYC. As a commuter, you can cancel and bank your DH and just drive to the airport in Calgary for your flight. However, to get any of these flights you’ll need at least 3-4 years of seniority. There are 787 RP’s with 7-8 years that have effectively made YYC a base, as all of their pairings start and end out of YYC.
Also, the YYC-LHR flight is a week long marathon that adds LHR-BOM to the adventure.
It works both ways though. Apparently, some YYC commuters who were a ready resource for IRROPS out of YYC are now demanding their “draft” starts in their base, (YYZ or YVR). As they are saying to C/S, you can’t have it both ways!
[/quote]
[/quote]
Unreallllllllll. Everyone thinks AC is the end all be all, but when they pull stunts like this, it just really makes you question your decisions. Like what purpose does this serve other than to piss off every commuting pilot?? I don’t see any benefit to this. This would never happen at WJ.
[/quote]
Why on earth would someone who is in YYC have to commute on their own dime to YVR, to then have the company DH them back to YYCCrewbunk wrote: ↑Tue Jan 03, 2023 12:07 pmAll three positions, CA, FO and RP, on the YYC to LHR/FRA start with a DH between YVR and YYC. But beware, on a memo from “higher up” Crew Scheduling has not been granting releases from the DH. So YYC commuters have had to commute from YYC to YVR to DH from YVR to YYC to begin their pairing!Curiousflyer wrote: ↑Sat Dec 31, 2022 11:29 am The best gig right now for Calgary Commuters is YVR 787 RP, as there are direct FRA and LHR pairings that start and end with a DH from YVR to YYC. As a commuter, you can cancel and bank your DH and just drive to the airport in Calgary for your flight. However, to get any of these flights you’ll need at least 3-4 years of seniority. There are 787 RP’s with 7-8 years that have effectively made YYC a base, as all of their pairings start and end out of YYC.
What interest or benefit does crew sched get from forcing someone to DH from YVR? That's the most non sensical thing I've read in a while. It doesn't benefit any party (at least in my mind it doesn't)
I'm not aiming this at you by the way, I'm just trying to understand the logic here
Technically, it is well within their right to insist you start and finish your pairing in your home base, as written. I agree, it makes no sense. I think the company is pissed off at the last vote.
But, as I said, their are repercussions. Now, when Crew Scheduling comes calling asking for favours, the answer has been Foxtrot Uniform. Including calling up a Calgary guy to “rescue” the YYC-FRA flight and he insists he will only start in YVR.
It does work both ways. When a FRA-YYC crew (for example) is looking to be released from the YYC-YVR DH and C/S refuses. You know it won’t end well.
Also makes me wonder what would happen if people just stopped doing that. And show up in YYC for their required flight. Let's say this ends up in a court room somewhere. What possible reason could the company bring up to fire the pilottwa22 wrote: ↑Tue Jan 03, 2023 12:40 pmWhy on earth would someone who is in YYC have to commute on their own dime to YVR, to then have the company DH them back to YYCCrewbunk wrote: ↑Tue Jan 03, 2023 12:07 pmAll three positions, CA, FO and RP, on the YYC to LHR/FRA start with a DH between YVR and YYC. But beware, on a memo from “higher up” Crew Scheduling has not been granting releases from the DH. So YYC commuters have had to commute from YYC to YVR to DH from YVR to YYC to begin their pairing!Curiousflyer wrote: ↑Sat Dec 31, 2022 11:29 am The best gig right now for Calgary Commuters is YVR 787 RP, as there are direct FRA and LHR pairings that start and end with a DH from YVR to YYC. As a commuter, you can cancel and bank your DH and just drive to the airport in Calgary for your flight. However, to get any of these flights you’ll need at least 3-4 years of seniority. There are 787 RP’s with 7-8 years that have effectively made YYC a base, as all of their pairings start and end out of YYC.
Are there other industries that have similar nonsensical rules?
Yea, I do get what you're saying, but it's still frustrating to hear or read that these things happen, saying it's non-sensical is wording it nicely...Crewbunk wrote: ↑Tue Jan 03, 2023 1:27 pm Technically, it is well within their right to insist you start and finish your pairing in your home base, as written. I agree, it makes no sense. I think the company is pissed off at the last vote.
The Jazz commuting policy definitely does help.
[/quote]
[/quote]
This EXACT thing happened at WJ during covid. I had several friends who bumped from YYC to YYZ in the layoffs, and had to change YYZ-YYC DHs to something closer than YYZ and then fly standby on their own dime to catch a DH to YYC. Otherwise no pay for a DH day. ALPA managed to get them to drop that shit pretty quick, and from then on you were still paid if you didn't take the DH. If there's something that can be done to spite the pilot group, WJ is way ahead of AC.
The big problem would be if the pilot did not show up for his DH in YVR, Crew Tracking would post him as “no show” and start procedures to cover his YYC-LHR/FRA flight. The same thing on the reverse, imagine a crew member when flying FRA-YYC-DHYVR, did not DH to YVR as written on his block. He’d be in a world of trouble if he were reassigned and not contactable as he got off in YYC. Unless released, C/S expects you to be where your pairing says you’ll be.
But …. the company is starting to realize it’s a two way street, and things are returning to normal. It didn’t take long for word to get out on internal forums, and pilots stopped “doing favours”.
I like the “mood” among the younger pilots we have hired. (I’ve been here 35+ years). They still have the “yup, I can do it” gung ho attitude. But now, they don’t do it for free.
As ACPA’s “mood” too is changing, it’s all good for the pilots.
I understand that's how the system works at the moment, but here's absolutely no reason why it would need to be like that.Crewbunk wrote: ↑Wed Jan 04, 2023 9:00 amThe big problem would be if the pilot did not show up for his DH in YVR, Crew Tracking would post him as “no show” and start procedures to cover his YYC-LHR/FRA flight. The same thing on the reverse, imagine a crew member when flying FRA-YYC-DHYVR, did not DH to YVR as written on his block. He’d be in a world of trouble if he were reassigned and not contactable as he got off in YYC. Unless released, C/S expects you to be where your pairing says you’ll be.
Can you imagine hiring a contractor who lives 5 minutes away from your place, but you have him drive 2 hours in the wrong direction only to give him a cab ride on your costs to your house? And if he were to drive to your house right away, you'd fire him for not following your procedures
Let's say you have the deadhead YVR to YYC. And then a flight from YYC. If the pilot shows up in YYC, it would be hard for the company to claim you were unwilling to work, or did not attend work. You could even show up in YYC when you were supposed to report in YVR, and both sides would still come out ahead. You're ready to work where you are (early) and you don't take up a deadhead seat so a paying pax or commuter could use it.
Happy to hear the mentality is changing somewhat. I understand that 10 years ago companies would get away with this, but pilots don't grow on trees anymore. If you would all collectively stop doing those nonsense things (I know, big if), it would be unlikely the company would fire all off them.
It's a power play and a disrespectful attitude towards a pilot's time. Especially towards commuters. It should stop.
Oh I know all the theories. I’ve heard just about every permutation and combination. But …. the bottom line is that AC does not have a YYC base. If one wanted to live in Calgary, but work out of YVR, that’s your choice. However, you DO work out of YVR. Getting from YYC to YVR is on you.
Historically, AC has not been very friendly toward commuters. Not, unfriendly, just not terribly friendly. I have my theories why, stemming from duty day acknowledgement, but those are just my theories.
Also historically, as mentioned, a pilot was able to “bank” those unused deadheads for future use. Hopefully that cooperative spirit is returning. If however, it becomes onerous for the company and integrity of the operation becomes in question, they’ll just route the pairing from another base. For example YYZ-LHR-YYC-LHR-YYZ. No DHs and they now have full control over you for the 7 days or so it takes to run the pairing.
But …. just showing up in YYC for your YVR pairing without being released will not end well.
Btw, this is nothing new. It goes right back to when I was hired and odd pairings popped up. Things like YUL pilots deadheading to YYZ to do YYZ pairings while YYZ pilots were deadheading to YUL to do YUL pairings, at the same time. And ….. don’t forget when the A340 was based in YWG with all pairings starting/ending with a DH, and NO releases.
No one is empowered to make decisions in this goat show company. exercising discretion is highly frowned upon on the logistical sidetwa22 wrote: ↑Tue Jan 03, 2023 12:40 pm
The old "it's always been that way"Crewbunk wrote: ↑Wed Jan 04, 2023 1:53 pm Oh I know all the theories. I’ve heard just about every permutation and combination. But …. the bottom line is that AC does not have a YYC base. If one wanted to live in Calgary, but work out of YVR, that’s your choice. However, you DO work out of YVR. Getting from YYC to YVR is on you.
While ACPA played Tiddlywinks, ALPA & even CUPE played like adults and got their employees some respect and a subsequent commuting policy.
You get the respect you deserve. When your collective resolve is of a 6th grade playground, you get those results.
Fortunately, the tides appear to be changing. Finally.
