Summer/winter weights
Can anyone tell me where I will find the dates for the beginning and end of summer/winter weights? Thanks.
Only our good buddies at TC would be so beauocratic as to put dates on something like this. I would use common sense and say that it depends where your are and what time of year it is. Canada is a big place with extremely different weather in every region. Take a look at your PAX. If they are bundled up, use the winter weights. If you're looking for this info for the sake of studying for an exam, I don't think I've ever seen it but please let us know if you find it. Then I'll laugh. I'm not trying to mock you, just looking for a laugh at TC's expense. Cheers.
"Yeah. There is a problem. You...because you're dangerous. You're dangerous and foolish - and that makes you dangerous! Now, let's cut the...crap. We've got a plane to fly. Let's try to be on time, okay?"
~Val Kilmer, Saturday Night Live
I don't recall seeing any dates for the use of these weights in Canada (although that guidance may be around somewhere)...
TC AIM - RAC 3.5 Weight and Balance Form
Now, the FAA on the other hand, does publish dates for when these weights are to be used:
An operator may use summer weights from May 1 to October 31 and winter weights from November 1 to April 30. However, these dates may not be appropriate for all routes or operators.
AC 120-27E Aircraft Weight and Balance Control
This industry is no place for "common sense."
We'd all be much safer if there was a published date when everyone gets heavier. Not a minute before. Not a minute after.
Most operators have this date published in their Ops Manual. I think the dates were formerly in the AIP. Don't know if or where they'd be now.
The definition of Summer and Winter was removed, intentionally or unintentionally, from the published weights when TC changed the weights. There is no definition for summer and or winter in the CARS so one might suppose it is now up to operator discretion.
Of course the safest thing to do is to use actual weights...
Snoopy
Snoopy
Over the Horn
