Mig 23 crash at Oshkosh
- Tubthumper
The worlds only civilian operated Mig-23 is no more.
https://youtube.com/shorts/1G2cnUqX7Mc?feature=share
TeePeeCreeper
Re: Mig 23 crash at Oshkosh
I’m surprised… I thought civilians weren’t allowed to have hot seats? Perhaps I am mistaken?Tubthumper wrote: ↑Sun Aug 13, 2023 6:45 pm The worlds only civilian operated Mig-23 is no more.
TPC
I don’t think there is a rule about civilians not having hot seats.
How is this any different than BRS from a technical standpoint or any number of uncontrolled crashes from a collateral damage standpoint or simply dying in a Cold War jet from a personal risk standpoint?
It’s just that often the cost is prohibitive or the support isn’t available. Perhaps Mig-23 systems have an unlimited shelf life or there are lots of spares or it was easy to engineer an equivalent solution?
sportingrifle
More surprising to me was that there was a passenger in the airplane during the airshow. Very lucky nobody was hurt on the ground.
Is possible even in Canada but with strict rules to be followed, including by the military. I have seen this on one aircraft that used to be on the airshow circuit.TeePeeCreeper wrote: ↑Sun Aug 13, 2023 8:01 pmI’m surprised… I thought civilians weren’t allowed to have hot seats? Perhaps I am mistaken?Tubthumper wrote: ↑Sun Aug 13, 2023 6:45 pm The worlds only civilian operated Mig-23 is no more.
TPC
DHC-1 Jockey
It didn't happen at Oshkosh. It happened at the Thunder Over Michigan Airshow in Ypsilanti, near Detroit.
I've read somewhere that the owner was paying around 25000$ per year, per seat to keep them "hot"
- Tubthumper
Re: Mig 23 crash at Thunder Over Michigan
….correction to my post title, this was not at Oshkosh, but Michigan.
I have no doubt that number is correct, but do you happen to know what makes it so expensive? I figured it would just be changing a cartridge and done. But probably not...
Worth every penny now
goldeneagle
Apparently that airplane had other issues in Oshkosh, read some comments about it having lost part of the canopy there.Tubthumper wrote: ↑Mon Aug 14, 2023 7:28 am ….correction to my post title, this was not at Oshkosh, but Michigan.
My back hurt just watching the videos. A big bang from a 37mm cartridge. Looks like it could be one of these.
https://www.tara-aerospace.com/PK-16
Generally speaking and depending on the type of seat, there are usually more than one charge in the various systems within the seat, as well as systems such as aneroids and such the will activate various safety features and sequences. They all need to be tested and/or replaced. There is also the rocket motor in the seat and the charges for removing the canopy and chute inspection plus repack. All this has to be done (at least per FAA) by qualified people, and usually the only place to do that is the military.digits_ wrote: ↑Mon Aug 14, 2023 7:31 amI have no doubt that number is correct, but do you happen to know what makes it so expensive? I figured it would just be changing a cartridge and done. But probably not...
In the early 2000's I knew a gentleman that restored a TA-4J and he had the seats hot....the nightmare of getting and keeping the seats hot was quite high. He could only get the charges from the Navy and had Navy personnel do the work. Having the work done not withstanding - trying to find charges for older, out of production seats in next to impossible.....hence the reason most older Western jets have cold seats. Try finding explosives for an F-86 for instance....not going to happen. Since most eastern block aircraft are still operating - I imagine (at least parts wise) they are easier to keep going.
